Ping I cant shake
Old June 20th, 2007, 10:35 AM   #1
Juggalo_X's Avatar
2001 Mustang 232/CBR600
14+@Slow
Ping I cant shake
hey guys most of you have read i got my beater Sunfire GT back on the road early this week and i got a ping that i cannot shake its driving me insane. It didnt have it before i parked it in January so its developed it from sitting. I have new plugs new boots on it (cuz its coil on plug) i changed the oil cleaned the TB and IAC and seafoamed it. the ping got better after the sea foam. which leads me to beleive its carbon in the combustion chamber causing the ping. what can i do to get that shit out! more seafoam? If i can fid where the damn maf is then ill clean that too lol ive never pulled the maf on this bitch before. also could this be relative to the fact that when i dropped the new engine in it, it was from a grand am so i had to custom fab the hole in the engine block of the Knock sensor off my old engine because the newer style one didnt match the harness? also the intake had to be swapped form the old engine to the new one because of The lack of EGR system on the new engine, and the egr system was fabbed and swapped over too because it was required to pass emissions they say since the car came with it stock it has to have it to pass. but the new engine out of the 2003 grand am was egr free. and lastly can this ping be egr related?(i hope not its electro and it is 400 bux to replace it) AHHHH HELP!
Old June 20th, 2007, 11:06 AM   #2
TurboLX's Avatar
1988 Mustang LX Turbo
run higer octane fuel, then it should go away
Old June 20th, 2007, 12:30 PM   #3
Juggalo_X's Avatar
14+@Slow
any other ideas? lol
i dont want to run jet fuel in this bitch lol
Old June 20th, 2007, 12:36 PM   #4
TurboLX's Avatar
89 91 93, pump gas buddy and some octane booster if needed
Old June 20th, 2007, 12:44 PM   #5
Juggalo_X's Avatar
14+@Slow
lol yes but the thing is i want to get rid of the ping so i can run regular 87 lol and i did throw some octane booster in there just cuz the gas has sat for like 6 months that in combination with the first sea foam helped out
Old June 20th, 2007, 12:50 PM   #6
TurboLX's Avatar
well then your timing is off problably
Old June 20th, 2007, 01:00 PM   #7
Juggalo_X's Avatar
14+@Slow
yah thats what i think but i didnt modify it so what could be throwing it?
Old June 20th, 2007, 01:12 PM   #8
TurboLX's Avatar
well you did change alot to it, and you proly had the belt off it
Old June 20th, 2007, 01:16 PM   #9
Juggalo_X's Avatar
14+@Slow
its a timing chain, and it had it replaced cuz it was a lil funky cuz the chain tensor was going. but i dont know what would have changed just sittin cuz it definitely did not have the ping untill after it sat all winter
Old June 20th, 2007, 01:43 PM   #10
TurboLX's Avatar
hmm i dont know then
Old June 20th, 2007, 01:52 PM   #11
Juggalo_X's Avatar
14+@Slow
well im going to sea foam it again and run some premium and see if its just carbon thats doing it.
Old June 20th, 2007, 02:01 PM   #12
DrHolliday is on a distinguished road
My guess is its just bad gas, run through that tank fill it up with one tank of premium and it should clear up.
Mustangless atm
2006 2500 HD Diesel. Built allison trans and other goodies
Old June 20th, 2007, 02:02 PM   #13
TurboLX's Avatar
ill look on ALL DATA and see if i can find something
Old June 20th, 2007, 02:16 PM   #14
Juggalo_X's Avatar
14+@Slow
thanks dude
Old June 20th, 2007, 02:17 PM   #15
Juggalo_X's Avatar
14+@Slow
thats what im thinking but i put some gas in it and a few bottles of octane booster in it
i wonder if the injectors are all fowled up
Old June 20th, 2007, 03:27 PM   #16
Juggalo_X's Avatar
14+@Slow
you guys think it might be because of the NGK's i put in it?
Old June 20th, 2007, 03:29 PM   #17
TurboLX's Avatar
ohhh that could be, the pistons are problably hitting them
Old June 20th, 2007, 03:31 PM   #18
Juggalo_X's Avatar
14+@Slow
ohhh that could be, the pistons are probably hitting them
how tho ive ran them before they are the correct type and i checked the gap its .06 like its supposed to be hmmmmmmmmmm i may have to go back to AC Delco something definitely isnt right to im going ot take it for a scoot after work and see if i can see any signs of detonation on the plugs. also piston slap would leave the plugs distorted and ill check for that as well.
Old June 20th, 2007, 03:50 PM   #19
TurboLX's Avatar
yea the plugs could be too much for the car
Old June 20th, 2007, 04:00 PM   #20
Juggalo_X's Avatar
14+@Slow
Ill pop the old plugs in and see what happens. ill see if i can get u guys a sound clip too
Threads Similar to: Ping I cant shake
Wheel shake MustangMatt 2005 - 2010 9 October 6th, 2007 10:17 AM
Ping Juggalo_X V6 Mustangs 3 June 6th, 2007 09:45 AM
Front End, Shimmy Shake tlwoody 94-95 5 November 6th, 2006 02:17 PM
Overheat and Shake! TorqueMonster V6 Mustangs 4 August 19th, 2006 08:25 AM
Ping My5point0Mustang 5.0 Mustangs 4 November 3rd, 2005 10:10 AM
