The George Forman of Keepers
Has your car ever had a problem?
If your car has ever had a problem, do you think it may have been from a certain modification? Also, do you think you would have had the problem anyway? I'm curious to know in order to learn what can be done differently. This way I might not make the same mistakes as I try to improve my car a bit.
So if you did have a problem, what would you do differently if you could do it all over? |
when i ripped out my stock airbox i had to plug some tubes cuz they were causing a vacuum leak and makin my engine idle rough
other than that.. never! lmao
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
Big timin' in a small town
Well if you have a 95 F-150 with a broken throttle body do not put a throttle body on there from the junkyard with an internal coolant leak it will fill up all the cyliners with coolant and hydro lock the motor then when you go and start it you will blow ther ring gear. i knw this from experience
besides usually matinence i havnt really has an issue its expected to get breaks, tires, ball joint or w/e engine & tranny wise not an issue
1999 Ford Mustang V6
14.79 @ 92.15
motoblue underdrive pulley. it was a 42% reduction pulley on the crankshaft, made of aluminum, warped with engine heat, lost its true circular rotation and cracked my harmonic balancer.
other than that, no.
#6 | |
Resident Bubblehead
i just spun a rod bearing in my car. had 102k on the ticker. don't know what cause it, but i know how much it's costing me so far.
#8 | |
1988 Mustang LX Turbo
The only problem that i have with cars is me getting my grubby hands all over it
1988 LX Coupe 2.5L, GT35R, 44mm WG, 32psi, C16. |
#10 | |
#11 | ||
Resident Bubblehead
Anatidaephobic
my dad bought a cobalt and everytime you took it around a sharp turn it sounded like something hitting the rear tire. we took it too the dealership twice before we discovered when it was built an assembler decided to play a joke on us by tieing a string with a nut onthe end of it inside the rear 1/4 panel. when we found it there was a note on it that read "took you long enough to find me"
![]() Pittsburgh Steelers/Penguins/Pirates FTMFW!!!!! |
#13 | |
Resident Bubblehead
#14 | |||
#15 | |
Resident Bubblehead
holy shit, i almost forgot! about 2 months after i got my stang, i shot a plug out of the drivers side head. the previous owner had gotten the extended warranty on the car and it carried over to me, so ford covered it all. they actually quoted me over 3 grand to fix it. fucking stealerships...
#17 | ||
14.79 @ 92.15
#18 | |
*taps foot impatiently*
Threads Similar to: Has your car ever had a problem?
| umm have a weird problem? idle problem? | blue03mach1 | 99-04 | 16 | March 4th, 2008 01:03 PM |
| big problem need help | 96gtponyred | 96-98 | 12 | August 22nd, 2007 02:36 AM |
| RIM Problem and Help | trueballerisme | 2005 - 2010 | 70 | August 21st, 2007 09:55 PM |
| t-5 problem | notsoslow50 | 5.0 Mustangs | 7 | August 17th, 2007 08:16 PM |
| TPS Problem? | 88Horseman | 5.0 Mustangs | 11 | November 14th, 2006 12:46 AM |
