Discussing help me quick in the The Clubhouse Forum. i just got done changing my oil. I did everything right. The drain plug was ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Captain Of Team Leg Hump
2006 Mustang GT
In the 13's
help me quick
i just got done changing my oil. I did everything right. The drain plug was tight, the oil filter threaded on right. The fill cap and dip stick went on right. But when I started the car is heard like a psshhhhh sound and i got out and looked and there was oil on the ground so i shut it off real quick and i popped the hood and oil had sprayed up on the hood liner and the rights side of the engine bay. I double checked everything. Could it be the o-ring on the oil filter was bad? Help please.
![]() Bassani Crew Member #1 Better to be judged by 12 then carried by six. |
2005 skittle
low 13's
with out looking myself i don't know. you had to have left something loose
4 banger club member |
2006 Mustang GT
In the 13's
Snug up the oil filter with my hands snug but not really tight. should i take pics?
#4 | |
MM Ninja / Site Moderator
2001 Mustang 232/CBR600
14+@Slow
Re: help me quick
![]() Modded Autos Join today, All makes all models ̿̿ ̿ ̿̿'̿'\̵͇̿̿\=(•̪●)=/̵͇̿̿/'̿'̿ ̿̿ |
2006 Mustang GT
In the 13's
And guys I feel like a total idiot right now so please dont laugh at me. I wanna beat the shit outta my self. I've never had this happen before.
#6 | |
14+@Slow
2005 skittle
low 13's
you should be able to tell where its coming from....if anything try and take it back to where ever you got it...cuss them out and make them give you free oil.....i always tighten everything pretty tight....i do the oil filter as tight as i can get it with one hand and then almost always have to use to and cuss to get it off....
2006 Mustang GT
In the 13's
Juggz
I just checked that was it. Is it safe to start it to get it back up on the ramps?
#9 | |
14+@Slow
2005 skittle
low 13's
yeah but your going to have to buy new oil....well i never look at the bottom of those motors but if the filter is at the bottom which it should be almost all the oil is going to come out....might as well change it all again if thats the case....
#11 | |
14+@Slow
14+@Slow
Get more oil, filter can be reused.
2005 skittle
low 13's
one hand tight isn't that tight....i heard something like that before......
#14 | |
14+@Slow
#15 | |
14+@Slow
2006 Mustang GT
In the 13's
I have another quart of oil here, so your saying to put that oil in to drive it up on the ramps and just deal with the oil that goes all over the place?
#17 | ||
2006 Mustang GT
In the 13's
#18 | |
14+@Slow
1) remove old o-ring and re attach oil filter so it wont leake this time. 2) Check oil level. 3) use your brain and figure out how much youve lost from your previous brain fart. 4) add oil as needed. 5) check for leaks make sure oil level is correct and then call it a day and go for a drive.
#19 | |
Stone Cold Mod
2007 Mustang GT
282 rwhp/292 rwtq
Location: I've got Rags in my bubble and I don't know what to do with it!
When installing your new oil filter, Red, always smear the o-ring on the filter with a film of oil. Then spin the filter on until it's snug, and then give it another 1/2 turn or so. It should be fairly tight, but not over tightened.
![]() Dyno Pull/MBRP's - The pee Test My Mods
#20 | |
Stone Cold Mod
2007 Mustang GT
282 rwhp/292 rwtq
Oh and by the way, even if you've lost a little oil, you won't hurt anything in the 10 seconds it takes to drive it up on the ramps. Just don't get all wound up and take it easy driving it up. It's when we're all wound up like this that shit happens.
Threads Similar to: help me quick
| quick hp | tweavtheboss | 2005+ | 31 | October 6th, 2007 11:17 PM |
| I need help quick | 2000Mustang | The Clubhouse | 32 | September 17th, 2007 08:05 PM |
| Some quick help please. | RockTheSVT | 99-04 | 5 | July 4th, 2007 03:24 AM |
| Quick Question. Help quick. | john0315 | 5.0 Mustangs | 7 | April 7th, 2007 05:33 PM |
| need some help quick! | Drgnracin72 | The Clubhouse | 1 | August 29th, 2006 08:41 AM |
