it's broken......
but progress is being made.
tomorrow the steam cleaner get used and then it's time to install...
you gonna put the engine/trans/k member in as 1?
btw whats all the specs on that stuff?
![]() Everything + Nitrous |
No, just ck'ing clearances for the headers and steering suspension. I'm gonna put the k-member in and then drop the eng/trans in as a unit.
It a 473, 12:1 comp, TFS heads, FRPP Victor, Comp solid lift cam,FRPP roller rockers, AED 950 carb, NX Nitrous kit, powerglide w/ trans-brake, JW bell and wheel, 4200 Edge converter and probably a lot more I'm leaving out |
OH its a big block? man do i have questions for you.....you have aim? or yahoo?
#5 | |
first, did you build that 460? or is it one of the ford racing crate ones?
2. I was thinking about buying one of the ford racing crate 460's for my swap, the better of the 2 466's. What do you think? How is the cam in this motor? http://www.fordracingparts.com/parts...tKeyField=6587 3. What kind of fuel system are you running, I was considering the aermotive carb kit, the universal one with an Aermotive FMU. 4. What kind of K-member/a-arms are you running? I wanted to do this as well, but I want a k-member that does not change any geometry, just replaces the stock one for means of weight reduction. 5. Manual rack or P/S? 6. How hard is the swap, I did the TKO swap myself, and I work as a mechanic, but I mainly do radiators, water pumps, starters, brakes, etc. But I am mechanically incline definitally. Btw, I will be running this with my current transmission, a TKO 600, which I have researched will line up with a SFI bell housing. Also this will be an ALL MOTOR setup. Give me all the info you can lol.
#7 | |
Im just nervous about building my own motor because it would be the first motor ive built and I dunno if I want this one to be my first.
Could you guess what the idle would be like on the cam in the ford racing crate motor? The peak HP is at 6k rpms, to give an idea. I just dont want a smooth idle....at all. lol.
it will be a choppy idle.
nice!!!! can't wait to hear her start up rick
#11 | |
good thats what i needed to hear, lol.
well, it's almost bolted in....Got it into the engine compartment and almost into place and found out that even though I have the small power brake booster, it still hits the valve cover so manual brake conversion here I come but the plus side is that w/o the booster in place it looks like I'll be able to do a 1" setback on the engine and trans.
Cant you just remount the brake booster?
be easier just to eliminate it.
nice motor man. what kind of exhaust you running or you just running open headers. im thinking about buying another project mustang when im done this one for my cousin. and im thinking about going with a 460 too. only i wont be building it thats for damn sure. def. keep us updated.
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!! |
hadn't finalized exhaust plans yet but it'll be a 3-1/2" x-pipe w/ some kind of mufflers w/turndowns.
Threads Similar to: it's broken......
| whats broken in your car? | crappy_head | The Clubhouse | 30 | September 23rd, 2007 06:09 PM |
| broken tranny | ByPopularDemand | V6 Mustangs | 16 | June 27th, 2007 06:40 PM |
| Broken nose | Steamboat 16 | The Clubhouse | 26 | May 19th, 2007 01:56 AM |
| Car Broken into | GreenFaleen | V6 Mustangs | 35 | January 15th, 2007 03:28 PM |
| Car Got Broken Into. Help! | White2000GT | 99-04 | 9 | September 6th, 2006 04:44 PM |
