Discussing The Beast in the The Clubhouse Forum. looks great matt....nice job...im sure you mother wanted to kill you walking into ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
#61 |
1998 mustang gt
12.6@110
looks great matt....nice job...im sure you mother wanted to kill you walking into the house that dirty lmao
1998 mustang gt- Jlt RAI: Steeda Pullies: PI intake: PI cams: 4.10's: Hooker longtubes: Mac Prochamber: Flowmaster: Pro-kit spings: UPR C/C plates: steeda upr&lwr rear control arms: MM subframes: Tokico shocks & strutsLeave rep for helpful posts |
#62 |
13.00 @ 105
its so weird seeing plug wires and a distributor
![]() looking forward to seeing the rest of this and the final numbers ![]() just out of curiousity.... does doing a PI swap change the compression ratio a lot? and what kind of numbers are you planning on putting down?
#63 |
1998 mustang gt
12.6@110
it raises the comp to about 10:1 i think i could be wrong dont hold me to that..and ive heard matt say hes expecting around 280-300 to the wheels....
#64 |
12.91@105.29 @ 5800 FT
im expecting about 300+/- 10 HP and monster TQ
Reason being is that the Comp 270 isn't as aggressive as i wanted, but i would have had to get fly cuts to get that done. ANd it raises the Compression to 10.4:1 or so with a stock head. But mine are ported so, it should be around 10.2:1-10.3:1
![]() We expect shit to break, look foward to realizing exactly when it is happening, and than obsess about dropping plenty of cash to rebuild stronger, so we can try to run it hard as hell and break again. We are sick individuals.
#65 |
1998 mustang gt
12.6@110
so you settled....shame on you!!
#66 | |
![]() About time matt. took ya long enough!!! Good job dude! PS pulleys FTL
http://www.moddedmustangs.com/forums/vehicle-classifieds/86839-wtt-90-lx-hatch-red-black-north-alabama.html#post1394801 |
#67 |
1996 Mustang GT Premium
15.2@91
Thanks for the help. My PI motor had one with the holes in it as well. Oh, and I won't be doing shorties because it's not in my budget. So far, I've spent
$300 - PI intake (d'oh) -$100 sold npi intake $100 - entire PI motor -$100 sold pi intake -$60 used IAC off new motor when mine took a dump... prolly saved me some money $170 - gaskets/head swap kit $0 - carb cleaner and scotchbrite pads --------------------------------- $310 for entire swap how much are shorties? $300? for 5hp? no thanks
#68 |
Ujslost ur the one saying I had to pull the damn thing. WHen all i had to do was drain the fluid and take the fitting off! LOL
I think the distruber is the coil pack bank instead of the COPs that shocker is talking about.
#69 |
2004 Mach 1
13.30 @ 104.47
You dont have to get flycut pistons for 270's. Im running stock pistons and as long as you degree them to the correct position you'll be fine, but whatever....... where'd you get your cams ground Matt?? and How much?
![]() EAGLE SCOUTS OR GTFO MyStangOpens (12:01:05 AM): honey nut for me |
#70 |
yeah the comp 270 will not need flycuts if degreed. Thats what im giong with. The cams i wanted were going to require flycuts. The cam i wanted was more agressive than the Comp 270.
Comp ground my cams with out the 5º advance though.
#71 |
2004 Mach 1
13.30 @ 104.47
oh ok. How much did you pay for those??
#72 |
2004 Mach 1
13.30 @ 104.47
BTW I'm going to tackle degreeing my cams today hopefully......I'm not looking forward to it. Its alright though i got Boomer to help me out.
#73 |
yeah degreeing the cams seem to be pretty easy! Boomer has helped me a lot though this process as has Ujslost. Thanks guys!
But I paid 675 shipped to my door for the cams.
#74 |
2004 Mach 1
13.30 @ 104.47
Word thats not too bad. What else are you going to be doing? I figured while everythings out I might as well replace the oil pump, waterpump, timing guides, chains, injectors, and all new cam gears, spacers, bolts, and what not. Oh yea I found out that all of comp cams take the 12MM bolt for the sprocket. Comp never told me that, so i found out the hard way gettin ready to install everything.
Did you get your wiring harness out the way??
#75 |
naw i have nothing to do on the car but clean up the engine bay for the day... My heads will be here tommorow hopefully.
I went with a Ported and Polished head, Hooker longtubes and these comp 270s. This thing should scream on the bottle. But im leaving everything else the way it was other than the bolts. I have ARP head studs going on. My comp cams came with gear bolts too. wierd. Next few weeks i should be getting 30 LB injectors and 255lph fuel pump. Water pump has less than 5000 miles on it, and the oil pump seems to work just fine.
#76 |
2004 Mach 1
13.30 @ 104.47
Sweet well let m eknow if you need any help with anything else.
#77 |
git-r-done
#78 |
I got the rear drag springs in. But they were very very hard to do. I cant wait for the heads to show back up... In the mean while im going to start cleaning the timing cover and the valve covers.
#79 | |
DO WORK SON. Looks like its comming along just fine. Dont rush, take time to fire one off everynight as well. Trust me it helps.
![]() Oh yeah...if you think the rear springs are very very hard to do...good luck with the fronts. So....question probably some others are wondering...how much for everything? Because i picked up heads, cam, intake, s/c and intercooler for 2300. Sell that junk 4.6 and pick up a nice 5.0. Just kidding. Good thing youre still running high compression, with the nitrous shot you have you'll be more than happy with the entire setup. Good job man...You've come quiet far with this car.
White99stang-
93 LX, H/C/I + Vortech |
#80 |
thanks man. I plan on blowing up the bottom end this summer. Not intensionally. Aswell as ruining my axles. Next on the list is 31 spline locker, and axles. And then a 12.5:1 compression forged aluminum short block! i say that should make decent power on a direct port 200 shot.
I would say I have about 2000-2500 in the swap. Been saving a while, and also been buying lots of stuff used...
Threads Similar to: The Beast
| beauty and the beast | Jucostud | 96-98 | 20 | March 18th, 2008 05:53 PM |
| LT and The Beast? | Frosstang00 | 99-04 | 0 | March 7th, 2008 04:41 AM |
| just got this new beast : ) | jat | The Clubhouse | 35 | January 24th, 2008 09:35 AM |
| New to this beast | theninja | 5.0 Mustangs | 25 | October 18th, 2007 07:00 PM |
| The Beast | fox trot | 5.0 Mustangs | 8 | June 16th, 2007 12:21 PM |
