still throwing codes :(
Old May 5th, 2008, 12:18 PM   #1
shadow5403's Avatar
shadow5403 is on a distinguished road
Send a message via AIM to shadow5403
Ok, a little while back i was throwing these codes:
P0135 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 1.
P0155 Upstream Heated Oxygen Sensor Heater circuit fault - Bank No. 2.
P0741 Torque Converter Clutch Circuit Perf/Stuck Off
Now i changed all four of my O2 sensors to Bosch Premiums, and i also flushed the tranny and drained the torque converter and put in synthetic ATF.
After this was done, i cleared the engine codes...then disconnected the negative on my battery to reset the comp.....and a few days later the same code came back. Could the wires be bad that connect to the O2 sensors...and could i have a bad solenoid that is getting stuck on my torque converter?
More people hang out in clubhouse....so i figure why not put it here
Old May 5th, 2008, 12:20 PM   #2
El Conquistador
whiteboycustom's Avatar
83 coupe
whiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nicewhiteboycustom is just really nice
Send a message via AIM to whiteboycustom Send a message via Yahoo to whiteboycustom
gas + match = solved code
Old May 5th, 2008, 12:27 PM   #3
El Conquistador
83 coupe
do u have a code reader or is this auto zone reading it
have u tried to let a dealership read the codes???
Old May 5th, 2008, 12:34 PM   #4
Trick Tuners's Avatar
KB'd GT
I would check all the fuses and wiring for shorts. Did the wires melt against the headers?
Old May 5th, 2008, 12:56 PM   #5
shadow5403's Avatar
yes i used my tuner to read off the codes. I dont think the wires melted, i will have to check.
Old May 5th, 2008, 01:00 PM   #6
1965 Mustang Fastback
nba1341 will become famous soon enough
another bitch ass response lol
I'm a good boy now.
[COLOR=red][B]slow car club - crew member 7 of 9
[COLOR=White]Mood: Cool :cool:
[/COLOR][/B] [/COLOR]
Old May 5th, 2008, 01:24 PM   #7
shadow5403's Avatar
what about this torque converter error? ive read that i could lead to the tranny itself going all together...
Old May 5th, 2008, 01:34 PM   #8
El Conquistador
83 coupe
shut your cock holster
Old May 5th, 2008, 01:37 PM   #9
El Conquistador
83 coupe
might want to have someone with a computer check it out, like a dealership or local mechanic that has a better setup then the hand held tuners
Old May 5th, 2008, 01:39 PM   #10
shadow5403's Avatar
No....my tuner reads the same codes that are posted here:
Ford OBDII trouble codes - FordPower.net
Im not gonna pay 50 bucks to have codes read, when i can read them myself. I need info on how to fix them.
Threads Similar to: still throwing codes :(
problems fixed, yet still throwing codes HELP shadow5403 V6 Mustangs 3 May 7th, 2008 10:26 AM
still throwing codes :( shadow5403 V6 Mustangs 0 May 5th, 2008 12:17 PM
Engien light on...throwing these codes shadow5403 V6 Mustangs 2 April 6th, 2008 09:42 PM
Engine light on, but throwing no codes? shadow5403 V6 Mustangs 10 April 4th, 2008 02:24 PM
Throwing Codes! Garhfer 99-04 2 March 7th, 2007 09:21 AM
