Building a motor
Old November 13th, 2005, 11:17 PM   #1
DirtyMach1 is on a distinguished road
Building a motor
If you could build a motor what would you build? ZTaking from DSSRacing pick a block, cams, heads, and ect. Give me some ideas to go with.
Old November 14th, 2005, 12:35 AM   #2
Bossman351 is on a distinguished road
Send a message via AIM to Bossman351
514 c.i.d. Big block
SVO block
Blue Thunder heads
FMS solid roller cam and lifters.
Roller rockers w/ stud girdles
Forged crank
Eagle H beam rods w/ JE pistons @ 13.5:1 compression ratio
Top it all off with a flying toilet.
Good for about 900 hp N/A
Old November 14th, 2005, 01:11 AM   #3
lemon's Avatar
1999 GT Rag
lemon is on a distinguished road
flying toilet...
gonna need them when the brownies start runnin :wink
Old November 14th, 2005, 02:19 AM   #4
Flying Toilet
Check it out. Its a mechanical fuel injection system and is good for gas, alcohol, works with N2O or you name it. Heres a simple explanation of it and how it works.
Carburetors mix the fuel load as they pull venturi vacuum. Injection however, provides instant fuel as soon as the throttle moves. The Flying Toilet is basically an air valve. The fuel is introduced into the engine near the bottom of the intake manifold runner closer to its final destination in the combustion chamber. Our unique cone shaped nozzles deliver the fuel in a fine mist.
Old November 14th, 2005, 08:49 AM   #5
Will that fit in my Mach 1? That is a huge motor.
Old November 14th, 2005, 11:50 AM   #6
like a glove. it's actually not as big as the 4valve'r ya got now
88 Mustang Coupe
www.rickscarcare.net
Old November 14th, 2005, 11:53 AM   #7
SVO block
Blue Thunder heads
Forged crank
If I was gonna use the BT's and the SVO block, I'd go for the 557 or 598 version w/ about 9.5 to 1 compression..........It would run on pump gas all day long and still spit out 700-800hp or so
88 Mustang Coupe
Old November 14th, 2005, 12:53 PM   #8
87vert is on a distinguished road
Send a message via AIM to 87vert
mmnnn you can also run some boost with that 9.5:1
'96 Exploder XLT 5.0 AWD
"turbos coming soon"
Old November 14th, 2005, 09:57 PM   #9
04COBRA is on a distinguished road
whatever you decide dirty, i'd set it up to beable to handle some boost.
Old November 14th, 2005, 11:36 PM   #10
Yeah right now I don't think I can even keep the car. I don't have the money for the motor and to be able to pay the patment and insurance. And I can't leave it on my driveway. I think I might have to turn it back in. I'm running out of options.
Old November 15th, 2005, 12:13 AM   #11
SVO block
Blue Thunder heads
Forged crank
Good call on the streetability.
Sucks man. I know how you feel. Ive been to the point that I was looking outside every time I heard someone coming up the drive to make sure it wasnt a repo man. Its not cool at all. I hope everything works out for the best for ya.
Old November 15th, 2005, 03:25 PM   #12
I can get a remaned 03 cobra motor for 3500. Complete with a 3 year 36,000 mile warranty. Sounds like the cheapest way to go so far.
Old November 15th, 2005, 03:28 PM   #13
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
really that cheap? i might need to look into a cobra motor, tranny, rear end, ecu, and tranny combo one day. i bet i could get out with under 10k in it.
ModdedAutos
1999 Mustang V6
Old November 15th, 2005, 05:03 PM   #14
Yeah maybe you could. They quoted me 1200 labor and 3500 engine.
Old November 15th, 2005, 08:54 PM   #15
Bill is on a distinguished road
does the blower come with it?
Too often, We lose sight of life's simple pleasures. Remember, when someone annoys you it takes 42 muscles in your face to frown, BUT, it only take 4 muscles to extend your arm and bitch-slap that Mother@#?!&! upside the head!!
Old November 15th, 2005, 11:03 PM   #16
Negative but I can get a blower and all the fixins off ebay for 500. So not that expensive of a change. Other than the hood might see if I can make it work with the charger. Atleast as a heat vent.
Old November 16th, 2005, 12:16 AM   #17
You should study very hard on a reman. I personaly wouldnt buy a remanufactured motor if the crank has been machined more than .010.. Ive seen more remanufactured motors come through for replacement than I have factory motors. In most cases the motors are put together in a hurry and not every aspect has been handled with care which usually ends in failure.
Old November 16th, 2005, 12:41 AM   #18
if it does fail hopefully it will fail before the 36,000 miles/ 3 years for the guy. hey dirty couldnt you've gotten an extended warranty for the mach when you bought it. for my bonneville and my GT i got a 3 year 36,000 mile warranty with the used car and they were through ford and GM. so my GT was warranteed till like 80 some thousand miles cause i bought it with 45,000 + back in 03. i dont have the GT anymore but it only costed like 1600.00
Old November 16th, 2005, 10:12 AM   #19
Yeah I could of but I was trying to keep my payment as low as possible. I just had my GT with 75k on it and never had a problem with it. Just my luck though. Yeah the warranty kind of makes me feel better about the motor.
Old November 16th, 2005, 11:10 AM   #20
The thing about warranty on a reman is that generally, it only covers parts and not labor. So if it were to fail, he would have to eat the labor cost. Not to mention, warranty usually only covers actual mechanical parts. So if he were to blow a head gasket or the block cracked he would be shit out of luck.
Threads Similar to: Building a motor
buy a crate motor or have the fun of building your own White Thunder 5.0 Mustangs 19 September 27th, 2007 09:40 PM
building a strock motor mustangrebuilder Classic Mustangs 5 May 12th, 2007 08:31 PM
Building my mustang motor Tmar2082 5.0 Mustangs 46 March 22nd, 2007 11:28 PM
building up a motor 87 G T 5.0 Mustangs 1 October 20th, 2006 05:45 PM
Building a Motor. bbrewer03 96-98 1 August 28th, 2006 10:38 AM
