Discussing Touch up paint in the The Clubhouse Forum. anyone used it? I bought some from Ford today and tried to apply it, but ... Modded Mustangs is the premier Ford Mustang Forum on the internet. We discuss all aspects of the Ford Mustang on the forum. Registered Users do not see the above ads. Please Register - It's Free! |
Editor
14.095 @ 99.60 mph Stock
Touch up paint
anyone used it? I bought some from Ford today and tried to apply it, but I had a hard time with it and ended up having to use isopropyl alcohol to get it off because it looked like shit...
Any tips on applying this stuff? |
Moderator
2007 Mustang GT
282 rwhp/292 rwtq
Shake the ever loving shit out of it, and less is more.
But it will never look like it's not there. It's called touch-up paint for a reason brother. lol
![]() Team Ricer GT's Co-Founder Dan: NOT A PROBLEM.
Crew Founder |
Yep. I tried and failed aswell, haha. It will never look like factory. It's going to be splotchy and all the good stuff, haha.
Editor
Alright because wen I put it on a long scrach that came from a rock on a newly paved road it actually made it look WORSE because the color dried oddly and it made it more noticeable. So I took it off with the alcohol and then rewaxed that area...
You could try buying a brush with a flat edge such as...
...well, I can't find a picture, but the kind that are made of one object instead of bristles. Lay paint down and spread with said brush. Might work better than the one that comes with it, but might not, haha. |
The Crow Flies Straight
'02 GT
This is how I repair rock chips. I have also used this method on scratches but it is alot more time consuming. I know some will call bs but i have done it like this many many times and 95% of the time you can't notice it unless your right on top of it. If you want to make sure the color will match, you can go to you local paint jobber and have them use "the magic eye" on your car to eliminate the cahnce of having the paint not match. What i mean by magic eye is, it is a box that you hold on the paint on your car and it reads the actual color to account for fading, color variences, already repainted surfaces that do not match the factory color perfect, etc... I have painted many cars that when i went to mix the formula there will be nine or ten different color variences from the factory, so just because you have the same paint code as the car next to you, it doesn't mean that you have the exact same color from the factory. That is the main reason pre packaged touch up paint doesn't match exactly most times. I also use one of my old pinstriping brushes(0000) to apply the paint.
Get some single stage paint for your cars color. Then just clean the area real good, you can use wax and grease remover and a fibrglass prep pen if you want to get real picky about it. After you clean, apply the single stage to the chip putting just enough paint on there to have it slightly raised above the surfacce of the paint. After the paint has fully cured take some 2000 grit wet or dry sand paper and wet sand the "bump" smooth with the surface of the paint. The easiest way to do this would be to find a small piece of wood or something to use as a tiny block. I take coffee stirrers and cut it into about a 1" piece. Then cut s small piece of paper to wrap around the block. Don't press to hard, just place enough pressure on the block to sand the bump down. Just don't get in a hury and pay attention and you can block it down with barely sanding the origanal paint surface, which in turn will make it easer to buff . (Always let your paper soak in the water for at least five minutes before use) After you have sanded it down, the area will be small enough that you can buff it by hand(or with a buffer if you have access to one and can use it. I have a 3" air buffer i use) with a soft cloth and compound, it will take a couple times with the buffing but if the color is a good match then once you have buffed the shine back you will barely notice it
BBK CAI, 75mm BBK TB, Trick Flow plenum, U/DP, spec clutch, short throw shifter, adj. upper cntrl arms, lower cntrl arms, 50/50 shocks, MAC exhaust, 4.10s, SCT flip switch
Threads Similar to: Touch up paint
| Touch up paint.. | ItaliStang | Visual | 4 | May 8th, 2008 11:04 AM |
| New progress, touch yourself afterwards! | WAR-PARTY | The Clubhouse | 26 | April 28th, 2008 05:16 PM |
| Touch up paint.. | 97GT4.6 | Visual | 3 | March 24th, 2008 07:37 PM |
| Ipod touch | Breakout | The Clubhouse | 15 | January 25th, 2008 07:10 PM |
