![]() iTrader: 1 reviews
what it takes for a realible 200mph stang
ive heard this question asked several times on this site and i have even asked it myslef a few months ago
typically the question ive heard is from somebody wondering just if its possible and the answer is clearly yes from an article in the new 5.0 maginze this car started off as a 06 sixxer and now puts 870hp to the wheels but is detuned for realibitly according to the article it is going to be raced in september on a 90 mile strip in the las vegas area Engine and Drivetrain Block - dart machinery bore - 4.125 stroke - 3.750 displacement - 400i crank - scat rods - eagle pistons - je custom compression ratio - 8.5:1 cam - jones racing cams, roller cam specs - 0.666/0.646 lift at 0.50, 260/263 duration heads- afr 225 intake - trick flow box r series power adder - procharger f-1r @ 15psi t/b - accufab 90mm injectors - rc engineering fuel pump - dual, in atl supercell 32 gallon fuel cell headers- custom exhuast - custom 3 inch with spin tech mufflers tranny - tremec T56 clutch - tilton 7 1/4 in rearend - 8.8 in,torsen diff, moser axlers, setrab rearend cooler (would not say what gear ratio) Electronics engine managment - fast xfi ignition - msd 6al gauges - auto meter Front Suspension k member - MM control arms - MM struts - dynamic suspensions coilover springs - Dynamic suspenions coilover streering rack - frpp reduced-assist brakes - ap racing, 14.5in six piston wheels - fikse, 19X10 in tires - michelin pilot sport cup Rear Suspension shocks - dynamic suspensions springs - dynamic suspensions control arms - steeda upper and lower brakes - ap racing, four piston wheels - fikse, 19X10in tires - michelin pilot sport cup
Just Another Bolt on GT [IMG]http://i45.tinypic.com/54f5ua.jpg[/IMG] Stock Longblock - 287/276 Low 12s NA! 10s on the spray? |
One Man Wolf Pack
I think this was in MM&FF a while back.
![]() ΜΟΛΩΝ ΛΑΒΕ
The Razor's Edge
thats not a 6er buddy
well the owner of the car says it currently only has 200 miles on it so idk
The Razor's Edge
lol
he had a termie in the 150mph class but he wanted "a new weapon in order to launch an assualt on the unlimited class"
The Razor's Edge
i've had my car up to 160
proven fact
skittlz faster than mustang
[SIGPIC][/SIGPIC] [SIZE="5"][FONT="Arial Black"]OBEY THE FACE![/FONT][/SIZE] Edited By Moderator. Next time will be a ban. |
02 GT
2002 GT Flowmaster 40's K and N Air Intake |
well i belive the biggest challenge isnt being able to reach 200 but rather get there and hold it at a constant speed for 20+minutes (90 miles)
#12 | |
Glorious PC gaming master race
where the hell r u gonna find 90 miles of track?
i figured that ticket woulda taught u somethin
![]() MILITARY CREW - USAF E-4
02 GT
You could try a test track, they are desinged to test a cars top speed.
#14 | |
but r they 90 miles? i doubt ur gonna be at top speed for 20+ minutes
#15 | |
I Post Entirely Gay Too Much
1988 GT VERT (Sold :(
'Cause she's got a... GRRRREAT ASS!
[edit] Engine specifications
Type: Koenigsegg aluminium V8, 4 valves per cylinder, double overhead camshafts. Carbon Fibre cam covers. Engine displacement: 4.7 litres. Compression ratio: 8.6:1 Weight: 215 kg (474 lb)[citation needed] Lubrication system: Dry sump with under-piston oil squirters; oil cooler. Motor oil: SAE 10W60 synthetic. Oil tank capacity: 12 litres (10.6 imperial quarts) Induction system: Sequential multipoint fuel injection. Dual Rotrex centrifugal intercooled superchargers with maximum 1.4 bar (140 kPa) boost pressure. Fuel: 98 RON unleaded. Ignition system: Electronic Coil on plug (Direct Ignition - DI). Engine redline: 7,600 rpm.[citation needed] wiki needs all the help they can lol
02 GT
Well you mention you're car has 88hp, and I'm not shure on the numbers of the SRT4, but it's alot more than you're car. I'm just providing info.
#18 | |
02 GT
I'm pretty sure the only time I've seen that question legitimently asked was by you...
Threads Similar to: what it takes for a realible 200mph stang
| Is 200mph in 96-98 Cobra possible? | noyz25 | 4V / SVT | 128 | August 1st, 2008 05:25 AM |
| Over 200mph On The Highway | gofastride | Videos | 11 | December 22nd, 2007 12:30 PM |
| Heating Takes Forever | dr.gonzo! | 5.0 Mustangs | 16 | November 21st, 2007 07:59 PM |
| this takes balls AND skills | BWAL | The Clubhouse | 4 | August 11th, 2007 08:25 PM |
| Top Secret Skyline 1200bhp 200mph + run | Mellon | Videos | 5 | November 24th, 2006 02:20 PM |
