my sixxer went BOOM
Old August 24th, 2008, 03:10 PM   #1
BostonPerformance's Avatar
99 Cherokee sport/87 5.0
not tested
BostonPerformance is a jewel in the roughBostonPerformance is a jewel in the roughBostonPerformance is a jewel in the rough
my sixxer went BOOM
I've finally had it with this car. I was on my way home from the gym and it started making a rattling noise. completely different from the knocking the FIRST engine I replaced made (spun rod bearing on that one). From advice and reading a bit it's either the timing chain or a piston..
it rattles real bad after it warms up, and overheats (not the thermostat, replaced it and flushed the radiator a week ago), the ac won't blow cold, and i get no throttle response. this all happens after it warms up a bit, about the time it takes to drive halfway around the block.
I'm tired of this car. I already put a new engine, suspension, and brakes into it, along with rebuilding the tranny and replacing the radio.
so I'm probably gonna be getting a white 2000 gt hardtop on monday. Can I take the 17" gt alloys w/ toyo proxes off of my sixxer and put em on the gt?
[CENTER]"Not the victory but the action; Not the goal but the game; In the deed the glory," -Hartley Burr Alexander
Old August 24th, 2008, 03:18 PM   #2
MEMBER #334
stangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of lightstangfreak is a glorious beacon of light
Send a message via AIM to stangfreak
1994-up should use the same bolt pattern
[SIGPIC][/SIGPIC]
[SIZE="4"]"This just in....14.79 @ 92.15 is not fast"[/SIZE]
Old August 24th, 2008, 03:19 PM   #3
Dansby's Avatar
Dansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of lightDansby is a glorious beacon of light
Send a message via AIM to Dansby
Good call and yes, you can. It SHOULD have the same spacing...
Old August 24th, 2008, 03:23 PM   #4
not tested
good. I hate the plastic ones that stangs come with. my gts are the only stock stang rims I like.
Threads Similar to: my sixxer went BOOM
More pics of my 98 sixxer 98stangv6 Pictures 7 August 7th, 2008 05:12 PM
New Sixxer 00v6newbie New Members Introductions 19 May 19th, 2008 10:46 PM
help a sixxer out? tsp_2177 2005 - 2010 13 February 12th, 2008 07:11 PM
Wheels For My Sixxer! burin_rubber V6 Mustangs 15 December 8th, 2007 01:49 PM
