you might be a ricer
Old December 12th, 2006, 05:11 PM   #1
mustangklint95's Avatar
mustangklint95 is on a distinguished road
Send a message via AIM to mustangklint95
You Might Be A Ricer If:
-You have more exhaust decibels than your engine has horsepower.
-You have aftermarket FRONT wheels for racing but stock rear wheels.
-Your engine makes twice as much horsepower as torque.
-You have 17" rims up front, 13" out back on your FWD.
-You ever painted your wheels to match the same color of your car.
-You put your automatic car in neutral at every stoplight in order to roll it back and try to fool other people into thinking you have a manual transmission
-DuPont gave up trying to figure out the shade you were asking for.
-Your mod list includes stereo equipment, shifter handle, MOMO steering wheel, PIA driving lights, exhaust tip, but no REAL engine parts.
-A chameleon lizard undergoes fewer shade changes than your custom paint scheme.
-Your rims and tires are so large, that you have to install the tire / wheel from underneath the car because it simply won't fit in the wheel well going in from the side.
-The dealer laughs when you bring your car back in for service under warranty, and you've only had it 6 months...
-Your tires / rims stick out from the lip of your car by more than 1."
-Your paint job is from the WRONG end of the color spectrum.
-You installed spacers on your STOCK wheels and tires to get them to stick out past the fender.
-You see cars like yours in a Shriner's Parade for Children and clowns are driving them.
-You bring an empty Maxwell House coffee can with you to compare size when you shop for an aftermarket exhaust system.
-Your Eclipse GS-T hardtop has a "SPYDER" emblem on the rear...
-Your sum knowledge of suspension is: "the more negative camber, the better the handling."
-You push your car through the staging lanes. That way, maybe you can break into the 16s by keeping the motor cool between runs.
-You add a super tall rear wing, and a hundred pounds of aftermarket ground effects, neon and stereo yet you gut the interior and yank out the rear seat for weight savings.
-Your rear wing AND your rear window have a third mount brake light...
-The back lighting in the gauges in your A-pillar gauge pod work long before the actual gauges are hooked up.
-You cut 4 coil springs and scrape the chassis on the ground. Sparks are cool when you corner at normal traffic speeds!
-You have to find a way to drive AROUND speed bumps in a parking lot.
-You install colored bulbs in your aftermarket clear lenses.
-You ever put neon on the bottom of your car, and then busted it on the first speed bump you went over.
-You painted the UNDERBODY of your car to match
-If your rear spoiler is taller then you are.
-If you can fit fist fuck your exhaust tip
-You have more stereo WATTS than engine TORQUE!
-If your tailpipe extension is the most expensive mod you’ve done to your engine yet.
-Your tailpipe extension fell off during a quarter mile race and you went three tenths of a second faster due to weight savings.
-EVERY car in your class has a turbo pushing double digits worth of boost.
-You spent $5,000 on the engine and you can not out run a stock Camaro, Firebird, or Mustang
-You want the 'wastegate' sound, but don't want to install a turbocharger system.
-You think Nitrous Oxide on your Hyundai Sonata puts you in the same performance league as the Chevy Corvette.
-The automatic version of your car runs 2 seconds slower in the 1/4mile.
-If the 1970 Plymouth Daytona Superbird has a smaller spoiler than your car does.
-You think the Del Sol is a sports car...
-A torque converter does NOTHING for your car.
-You think a deep farty noise = the sound of high performance
-If you think that horsepower is far more important than torque
-If you have ever claimed that switching to a cone filter has given you more than 5 HP.
-If you have ever considered installing more than one set of fog / driving lights.
-If you claim that the aftermarket cold air intake system you just installed doubled your horsepower or took 2 or more seconds off of your E/T.
-You spent all night on the Internet trying to find a company that makes a turbocharger system for your Hyundai...
-If you removed your side view mirrors and put them at the TOP of the door / window frame.
-If you think the Fugees are 'speed' music.
-MOMO is 'absolutely required' to go fast.
-Your four cylinder has a dual exhaust system installed.
-Your four cylinder has four exhaust pipes ("Hey, one for each cylinder!")
-The color of your interior upholstery hurts the cones and rods in other people's eyes.
-If you cannot drive your car in snow as the ground effects create a plow effect.
-If you have installed driving lights to compensate for headlight blackouts / tape.
-If you think that 180 horsepower and 185 lb/ft of torque are impressive for a ‘mildly’ modified engine.
-If you have stickers on your car for parts that you could not point out if asked where those parts are installed.
-You think pushrods are a bad thing…
-Your car has more decals than you do the quarter in seconds.
-Every Honda you EVER owned, all the way back to your 1978 Accord was either a V-Tec or a TYPE-R.
-If you gutted the interior to save weight on a car that you will never take to the track…
-You lean your seat so far back when you are driving, that every time you hit a bump, its your back and not your butt that hurts.
-You have hydraulics and sixteen switches on a car you claim runs low 10s on the street and corners better than a Porsche.
-If you can estimate that your car makes more than 250 HP without ever running it at the track or getting a dyno reading.
-You claim that you can get a titanium block for your engine.
-If you have ever thought Hyundai and "performance" went hand in hand
-If you've ever gone to a parts shop or speed warehouse and asked for a 1" to 6" exhaust adapter...
-If you've ever contemplated adding "TYPE-R" stickers to your Sonata…
-If you've removed more than 1/2 of the coils from your springs by cutting them yourself ...
-If you have more neon lights on your car than a strip club...
-You put Kanji on your Ford ZX2, Ford Probe, or Mercury Cougar ...
-You own a "TYPE-R" Hyundai or Mazda.
-You claim that polishing your intake gave you 5hp.
-You ever claimed that high gas mileage made your car superior in performance to V8s.
-If it takes you 8000rpm to reach 30mph from a dead stop
-You think yellow plastic interior trim makes your car cool
-You spend $500 for a giant hand welded tube for a muffler with the weld marks extremely visible
-If you paint your drum brakes to simulate Hi-po calipers
-If you install fake hi-po caliper / disc simulators
-If you lower your car and add ground effects but retain the stock 14inch wheels with disc style wheel covers
-If you equate the sound of performance with the sound of a Weed Eater™
-If you think bolting a fake muffler to one side to simulate dual exhaust is cool
-If you think colored head lights work better
-If you take mom's 4 door Honda accord and do any kind of mod to it
-You claim you lost the race because you had a passenger in the car.
-You claim how if you went from a roll you would have beat him.
-You claim you lost because you missed a shift... and your car is an automatic.
-You claim you lost because he must have been on the juice..
-Flying past the person who is 10 car lengths in front of you after they have put on their brakes.. and claim a victory.
-After losing you flip your opponent off... rev your motor and fail to break the wheels loose even around a corner.
-You tell everyone about how you lost the cop because of your "driving skills."
-You drive around in a $20,000 import with $10,000 in mods.. and still live with your parents.
-You take offense when I say.. "your sister is like your car.. small, tight and hard to get into."
-You've spent more on graphics and decals than you have in gas, for the whole year
-You sound like you're going 90, but you're creeping past 25
-You upgraded to the "big bore" 2 inch exhaust
-You lose 2 mpg by installing a body kit
-Your wing is so large that if you go faster than 65, your bumper drags
-You think "displacement" is something that happens to homeless people
-Yugo's give you a run for the money
-You continuously run red lights because they are invisible thru your red window tint
-15's are considered HUGE rims
-You can reach back and defrost the rear window by hand
-You will race anyone, anytime, and already know that you will lose
-You spend all your money pimping it out because spending money to make it faster is a waste
-Your little sister is the only one impressed with your car
-When you win a race, you don't really win, it's just that the other guy felt soooo sorry for you
-You think your mom's Corolla is fast
-The cross section of your exhaust tip is bigger than the contact patch of your tires
-Your aftermarket tach is bigger than your fist
-You bought the big ass tach to try to scare off the fast cars, but all it does is let people know how hard you have to push it to exceed the legal speed limit
-You buy and install custom rims a pair at a time
-You've entered a 12 step program called "How to come to terms with your limitations"
-You go to the auto paint store and pick out the most retina burning color you can find
-You buy race gas to drop you from 17.02 to 16.9 in the quarter, and then tell all your friends how fast you went
-You add a second battery to power all the neon, and the mini disco ball
-You add a wing on TOP of your car, 'cause wagons need down force too
-You've ever painted bare, raw fiberglass black and said "Look! It's just like carbon fiber!"
-You still only get dates from high school girls
-You purchase and install a body kit, one piece at a time
-Your brother is pissed cause you stole the muffler off his dirt bike (it was a direct fit!)
-Your dad is worried cause you bought a car with less displacement than his lawnmower
Old December 12th, 2006, 05:14 PM   #2
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
97Cobra will become famous soon enough
yeah we allready have a post for this but nice anyways!
Modifications and pics in my Garage...
Reps Appreciated!
Old December 12th, 2006, 05:18 PM   #3
oh my bad
Sometimes you got to feed a little speed to your ride
Old December 12th, 2006, 05:20 PM   #4
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
no prob. just look a lil more.....lol
Reps Appreciated!
Old December 13th, 2006, 07:18 AM   #5
Classic Moderator
Horseshoeing's Avatar
Horseshoeing is on a distinguished road
Its a good post. I like to may fun of ricers
Classic Mustangs are the best! Get one.
Old December 18th, 2006, 02:04 PM   #6
Slicey is on a distinguished road
Send a message via MSN to Slicey
lol sexy.
Official MM Zeppelineers. Crew member #3
Old December 18th, 2006, 06:58 PM   #7
Mod of the Year '11
2021 Mustang V12
Quad Turbo with nawz
BWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond reputeBWAL has a reputation beyond repute
Originally Posted by cherry99gt
lol sexy.
ROFL at that "NOS" coke bottle in the window of the second one
Old December 18th, 2006, 07:58 PM   #8
Classic Moderator
I seen that one too. lol
Old December 19th, 2006, 01:21 AM   #9
thats good stuff
Old December 19th, 2006, 05:52 PM   #10
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
LMFAO thats some funny shit!
Reps Appreciated!
Old December 19th, 2006, 08:36 PM   #11
1995 BMW 325i
232stang is on a distinguished road
Send a message via AIM to 232stang
Originally Posted by Cesar2cool
lol i use my car for speed
Old December 19th, 2006, 08:39 PM   #12
1995 BMW 325i
what kind of cruel, cruel person could do this to such an innocent horse?
AND WTF IS THIS?!?!?!!?
Old December 19th, 2006, 09:50 PM   #13
87foxbodylx's Avatar
1987 Mustang LX
13.9@102.43
87foxbodylx is on a distinguished road
I saw a car with exhaust sticking straight up, kinda like the hummer snorkeler on the front of the air breather.. except in the rear.. the tip of his exhaust stood straight up like a woody and was higher then his whole damn car
Old December 21st, 2006, 12:54 AM   #14
MM's Coffee Addict
96Snaker's Avatar
1999 SVT Cobra
441rwhp/393rwtq
96Snaker has a spectacular aura about96Snaker has a spectacular aura about
Send a message via AIM to 96Snaker
It's not terrible, considering some of the stangs out there (most of which have probably been made fun of on MM before, lol)
...just lose the spoiler on this one; hell the Cobra R spoiler is a bit rediculous but at least it's a nice alternate to Honda-ing your Ford. If I found a R wing fit for an SN-95 it'd be hard for me to resist buying it, but nothing like the one pictured here, ugggh.
Vortech V2, intercooled @ 10psi. Maximum Motorsports supsension goodie bag car less roll cage. Built '04 IRS. Hodge-podge of Roush/Stalker panels.
Old December 21st, 2006, 01:12 AM   #15
1995 BMW 325i
the wheels need to go, the euro lights, wing, and that gay ass decal.
the difference between the cobra r and ricer wings. the cobra spoiler has a purpose, better stability at high speeds.
Old December 21st, 2006, 04:21 AM   #16
MSTGGT00 is on a distinguished road
Send a message via AIM to MSTGGT00
Mustang abuse should be outlawed. If I see one more person driving a stang with a gay decal on the side I'm going to get out of my car, yank them out of theirs and then back of them with their own car.
Originally Posted by texas_mustang
MSTGGT00 wrote:
If my kids try and drive hondas. Ill send them to mexico in a basket.
Old December 21st, 2006, 07:18 AM   #17
Classic Moderator
I don't mind Bi girls
Old December 21st, 2006, 12:24 PM   #18
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
lmao where did that come from???
Reps Appreciated!
Old December 21st, 2006, 01:00 PM   #19
Classic Moderator
From the post just above mine.
Old December 21st, 2006, 03:38 PM   #20
97Cobra's Avatar
1997 Mustang Cobra
1/8 - 8.89@86mph
oh ok "gay decal" triggerd Bi chicks. lol gotcha
Reps Appreciated!
Threads Similar to: you might be a ricer
ricer cams-shelbycobra07 The Clubhouse 53 November 5th, 2007 11:05 AM
Gay Ricer 00vabchgt The Clubhouse 22 April 29th, 2007 10:30 PM
ricer pack01 8 Multimedia 17 April 14th, 2007 01:37 PM
Ricer or not? neckbonekat 99-04 26 January 11th, 2007 03:54 PM
You Might Be A Ricer If: mdvaldosta The Clubhouse 131 December 5th, 2006 09:46 AM
