#121 |
Proud American
here is a sample list... not very descriptive, but a rough Idea...
at 11.00-11.50 need a 5 point harness, fire jacket, helmet, driveshaft loop, 6 point roll bar at 10.00-10.99 you need a SFI approve flywheel/flexplate, need tranny shield SFI approved, SFI engine damper, and other odds and ends... so ill only tech down to 11.50s and thats it
#122 |
Proud American
Here is the work I got done today...
Pedal assembly swap, now Automatic ![]() Sealing the Firewall ![]() What I made today ![]() Dash back in place ![]() I dropped probably around 45-50 pounds with all the stuff I took out. And its going to be really easy to wire up those gauges now too without all the bulk behind there.
RIP Travis Billings ![]() Special Thanks to: Andrews Racing Transmissions Baseline Suspensions 25.3 SFI Chassis Build Never Lift Racecars Last edited by MustangMatt96GT; April 13th, 2009 at 12:37 AM. |
#123 |
insane matt... looks really cool man... to see what this car was 3 years ago...hell even longer than that when you first started with it...to now..just amazing...
#124 |
Proud American
Thanks!, it sure has changed...
but I got a battery in the car, and will be doing quite a bit of work on it tommorow... i also have 3 boxes coming tommorow of parts.
#125 |
can i have those seeds to grow that money tree???
#126 |
Proud American
Well... The Manual Brake Master Cylender is in... now I got to plumb all the fittings for it, and put in a pressure brake light switch, I cannot use the stock one with this kit. But it drops quite a bit of weight and cluster.
Before: ![]() AFter: ![]() ![]() I also got my gauge panel completely done and repainted. Here is what it looks like now. ![]() And I have gotten a little of the wiring done. Explained in the Videos. I now no longer need a key to roll up the windows or down. And I can now use the radio wires and heat/ac wires to power my switches and gauges. Oh all with the factory chassis harness! Thanks for the Help commandersafi
#127 | |
Safud: MM's Resident Hadji
#128 |
Proud American
Thanks man
#129 |
looks so sweet man.. i like that whole keyless shit... i wonder if that would pass state inspection
#130 |
Damn matt that thing sure has changed from a week or two ago..
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
#131 |
Proud American
Got the steering colum back in and my blinkers, flashers, head lights, tail lights (off the switch, got to put a pressure switch in for my manual conversion), wipers and all of that works! I got the hardest part of the car done! Now its to the easy wiring which I should finish today, and then plumbing of the car!
#132 |
Proud American
Everything is wired up, except the Nitrous/Transbrake and the fuel pump. Everything also works, well I cant test the ignition, but everything else works...
Here is the Line Lock mounted and wired ![]() Here is the Purge and Nitrous noid mounted and purge wired ![]() Here is the MSD 6AL mounted and wired ![]() and here is the gauge mount and steering wheel back in ![]() And here is the back with the fuel cell vent hose on, and no nitrous bottle back there, moving it to where the passenger seat was...
#133 |
are you going to clean everything up?? like keep wires tucked in/neat and keep everything hidden?? that would look so nice... but i know you sorta cant wait to get this thing on the track so im sure that stuff will come later down the road
#134 |
Proud American
It will be hidden the best I can... But these pictures are of it just wired up, not finished, and looking nice.
#135 |
¡ʇsnq ɹo uʍop ǝpısdn
just a reminder, if you hide wires that makes them a tad harder to get to... on some occasions. Just saying, encase you have a short in your MSD, but all the wires are tangled up and hidden and you can't change it fast enough...
and, i'm done talking.
#136 |
i understand that too...and when your at the track you want it to be as easy as possible...but there IS a neat way to hide the wires... just sayin
#137 |
Proud American
Fuel System was started...But I need a few more fittings. Did Test it and it does not leak, and it pumps the fuel pretty damn fast.... (made a mess everywhere)... Its kinda wierd though, after the fuel pump has been shut off, fuel still would come out of the OUTPUT line as a dribble. I think the regulator will take care of that.
![]() Jeff is going to make an Airbag Delete for the passenger side, and then mount my Window switch in the center of it. ![]() And here is the nitrous put together now... ![]() Just have to wire up the trans brake and nitrous, which I got all the parts for now, so ill try and do that tommorow. My engine's Pistons should be here tommorow, and I pick up the tranny tommorow! I am really getting excited with this car... looks like were about two weeks from completion. I plugged my fan in to make sure it worked, and sure enough it worked! So all that is left is the nitrous/transbrake. Also going to try and get the brake lines for the line lock finished. Anybody know where I can get steel line and a double flare tool? I figured out that I have all the fittings I need right at work..
#138 |
zippeewannabee
looking good matty
![]() Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount |
#139 |
13.1@105
![]() ![]() iTrader: 7 reviews
Hey Matt, what's done to the rear other than gears? Also, are you still running on stock control arms?
2009 Super-Stangs Fantasy Football League Champion
Thanks Brees! |
#140 | |
Proud American
Oh and stock suspension others than springs. I pulled 1.64 last year, but I think I'm going to have problems hooking up off the transbrake.
Threads Similar to: The Beast Part 3
| The Beast Part 2 | MustangMatt96GT | The Clubhouse | 126 | July 14th, 2008 02:31 PM |
| New beast here, A handsome Beast i might add | 562cobra | New Members Introductions | 13 | June 2nd, 2008 08:19 PM |
| The Beast | MustangMatt96GT | The Clubhouse | 436 | May 4th, 2008 12:51 AM |
| LT and The Beast? | Frosstang00 | 99-04 | 0 | March 7th, 2008 04:41 AM |
| just got this new beast : ) | jat | The Clubhouse | 35 | January 24th, 2008 09:35 AM |
