Question for a friend. Radio problem.
She drives an '07 Honda Civic and the other night, her battery died and her dad jumped it, but when it came back on, the radio is giving an error message. All it says is Error Code. I've looked through the hand book and couldn't find anything.
Anyone know what it might be? It's almost like you have to punch in a code using the 6 presets. |
Fashion Guru
From the page titled "Radio Theft Protection" in my 2008 owners manual.
"Your vehicle's audio system will disable itself if it is disconnected from electrical power for any reason. To make it work again, you must enter a specific five-digit code in the preset buttons. ... You should have received a card that lists your audio system's code and serial numbers. ... If you lose the card, you must obtain the code number from a dealer. To do this, you will need the system's serial number. If your vehicle's battery is disconnected or goes dead, or the radio fuse is removed, the audio system will disable itself. Use the preset buttons to enter the five digit code. ... When it is entered correctly, the radio will start playing. If you make a mistake entering the code, do not start over; complete the five digit sequence, then enter the correct code. If you are unsuccessful in 10 attempts, you must leave the system on for 1 hour before trying again." (If you have a navigation system the code is four digits instead of five digits.) With my vehicle I got a booklet titled "2008 Honda Service History." On the first page of that booklet is the audio code. (It also has the "key code" which you want to make sure you keep in your records in case you ever want a spare key made.) |
^^ A+
myspace.com/garrettstarnes 2004 4.6 engine. Cold air intake. Stage2 clutch. Spec Flywheel. Intake spacer. Throtle Body spacer. More to come! |
Threads Similar to: Question for a friend. Radio problem.
| Strange Ignition/Radio=WTF? Problem | superpede1 | V6 Mustangs | 12 | June 19th, 2008 01:02 AM |
| radio problem | terribleonexx88 | 5.0 Mustangs | 7 | April 6th, 2008 01:16 PM |
| Electrical problem (isolated to the radio circuit) | throwedoff | Audio/Video | 7 | June 25th, 2007 09:32 PM |
| radio problem | ks_emt | Audio/Video | 15 | June 14th, 2007 11:28 PM |
| Fuse, problem with radio HELP!!! | stingydonut | 5.0 Mustangs | 2 | February 21st, 2007 05:50 PM |
