Shelby GT500 Cooling Upgrades
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > D'Agostino Racing Inc.
Old May 13th, 2008, 01:32 PM   #1
Derek@DRI is on a distinguished road
Just wanted to pass along some products that will help benefit cool down your Shelby GT500 better. The number one enemy that hurts the Shelby's performance or any forced induction application is heat. Heat absolutely kills a vehicle's performance and can also cause damage to your engine. It becomes even more important when modifying your vehicle to create more power, whether its from turning the boost up or doing an intake. You want to keep your intake air temps under control. Even in stock form their is room for improvement. So here are some key modifications to achieve lower temps.
Moroso Intercooler Reservoir(Click here for more info or to order)
Doing this modification allows you to hold more fluid than stock, more fluid will equal faster and more efficient cooling times. Stock tanks holds 1.5 qts, this tank holds close to a GALLON. Not only that but it definitely helps in the looks department.
AFCO Dual Pass Heat Exchanger(Click here for more info or to order)
The best and most efficient way to reduce temps is with an upgraded Heat Exchanger. The AFCO Dual Pass is the ticket. It has a dual pass design, and it is much larger than stock. With this upgrade intake air temps can drop as much as 10deg, which is a HUGE difference especially when doing back to back spirited driving, or racing.
Canton Coolant Expansion Tank(Click here for more info or to order):
One of the last modifications I would suggest is a Canton Expansion Tank. While this is for the engine coolant temps, its still a good idea to maintain engine coolant temps down. This is more important for those who do a lot of driving, or do road racing.
All these are parts are available at D'Agostino Racing Inc, we are actually having a sale on all these items. Specifically we are currently running a GP on the AFCO Heat Exchanger so don't miss out as its good until the end of the month. So give us a call to get better pricing. For more information on these products just click on the links.
Old May 14th, 2008, 04:40 PM   #2
We have put together some cooling packages that will save you MONEY.. Here you go:
CLICK HERE FOR COOLING PACKAGES
Threads Similar to: Shelby GT500 Cooling Upgrades
Shelby GT500 Cooling Upgrades Derek@DRI 2005 - 2010 0 May 13th, 2008 01:32 PM
Shelby GT500 Coltdog The Clubhouse 922 April 20th, 2008 04:21 PM
New Shelby GT500 Coltdog 2005 - 2010 48 January 9th, 2008 10:20 PM
shelby GT500 barksdaleammo Modular Mustangs 8 April 2nd, 2007 10:35 PM
