LinkBack (1) | Thread Tools |
#1
Zone 5 Mega Driver Module In Stock!
Zone 5 Fuel Pump Mega Driver Module [Z5-MDM] - $599.00 : Performance Parts - Ford Mustang - Cobra - Dodge Viper - Chevy Corvette - C6 - LS1
![]() Looking to run aftermarket fuel pumps, or Fore Precisions Triple Fuel Pump Hat? Well look no further as you will need a Fuel Pump Driver Module capable of the task. Ford utilizes a Fuel Pump Driver Module (also referred to as FPDM) to drive the Fuel Pumps, in some instances such as the GT500, Ford uses 2 FPDMs(one for each fuel pump) for maximum efficiency. Of course when running aftermarket fuel pumps, or 3 Fuel Pumps the stock FPDMs are not feasible and will not give the results desired. For example in a 03-04 Cobra the stock fuel pumps (with no Boost-A-Pump, or any Fuel Pump Voltage Booster) draw 18amps which is plenty fine for the stock FPDM, however when you add a Boost-A-Pump or aftermarket pumps such as the Ford GT Fuel Pumps it can draw more than 20amps which is beyond the capabilities of the stock FPDM and will therefore overheat and cause it to go into thermal shutdown. Once that happens all fuel supply is cut-off until the FPDM cools down. We offer Zone 5's Stage 2 FPDMs to help eliminate that problem, but those will not work with 05+ Models, and will not work with the 99-04 Models if you are trying to run Fore Precision's Triple Fuel Pump Setup. Come in the Mega Driver Module. This bad boy can run 3 Fuel Pumps, or even a single or dual fuel pump setup more efficiently than the stock FPDM by itself. It comes complete with all the hardware and instructions for an easy install. Features: * Simple and clean install. * Can drive one, two, or three Ford GT pumps for enough fuel to support up to 1000rwhp. * Can supply 40A of current continuously with less than 0.5V internal voltage drop. * Operates at twice the output frequency of the stock FPDM for better fuel pressure regulation. * Built-in wiring upgrade and high current relay. * 8AWG, high flex, stranded input harness for battery /chassis connections. * Individual 14AWG output harness for each pump. * Beautiful CNC Machined Housing by "Fore Precision Works" * Designed to work seamlessly with the Fore Triple Pump Fuel Hats. |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/dagostino-racing-inc/80743-zone-5-mega-driver-module-stock.html
| Zone 5 Mega Driver Module In Stock! | This thread | Refback | July 19th, 2008 08:09 PM | |
Threads Similar to: Zone 5 Mega Driver Module In Stock!
| supercharger or a turbo its a daily driver and stock engine | Ataylor | 2005 - 2010 | 45 | July 22nd, 2008 02:16 PM |
| Zone 5 Mega Driver Module In Stock!! | Derek@DRI | 2005 - 2010 | 0 | July 18th, 2008 01:10 PM |
| How do you guys like mega bite jrs? | ujslost | 5.0 Mustangs | 0 | April 1st, 2008 07:37 PM |
| running mega rich? | BlueOval | 5.0 Mustangs | 2 | August 4th, 2007 12:10 AM |
| Cobra Fuel Pump Driver Module | chaoscreature | 99-04 | 1 | September 8th, 2006 02:46 PM |
