Kenne Bell Dual Boost-A-Pump Kit
Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > D'Agostino Racing Inc.
Old August 14th, 2008, 03:46 PM   #1
Jonathan@DRI is on a distinguished road
You've been asking about these so here are the details.
Features:
• 1000HP with OEM in tank production pumps.
•Increases fuel pump flow up to 50% on ANY electric pump(s).
•Available for single or dual pump applications.
•Easily installed. Uses stock feed wire & fuel lines.
•Eliminates expensive fuel lines and pump upgrades.
•Exclusive built in regulator stabilizes voltage regardless of battery voltage (down to 11V).
•Compensates for reduced voltage/pump delivery from voltage drops by lights and accessories.
•Proven reliability and concept. Tens of thousands sold since 1995.
•Used on all Kenne Bell Supercharger Kits (street & competition) and some of “World’s Most Powerful Production Cars.”
•Adjustable from 1% to 50% ON DEMAND from driver’s seat. Dual BOOST-A-PUMP™ is not adjustable. Set at max flow.
•Does not affect pump life. Actually increases life of returnless pumps.
•Activated by boost switch (supercharged, turbocharged) or vacuum switch (naturally aspirated).
•Ideal for Nitrous applications.
•Fused circuit protection.
•Attractive anodized red aluminum.
•Easily installed.
As always these bad boys are in stock and ready to go. Call to order or click on the link below
Kenne Bell Dual Boost-A-Pump Kit [KB89064] - $469.99 : Performance Parts - Ford Mustang - Cobra - Dodge Viper - Chevy Corvette - C6 - LS1
Old August 14th, 2008, 04:26 PM   #2
Al Guapo's Avatar
08 Bullitt Blk
N/A
Al Guapo is on a distinguished road
So with two factory pumps they'll be able to support 1000 hp with this kit?
If so, how much is it?
Thanks.
Blk 08 Bullitt #4751
PowerHouse Turbo @9psi, #60 inj, GT500 pumps, Center Force DF, MGW, Koni (Yellows) adjustable
BULLITT CREW #09
Old August 14th, 2008, 05:05 PM   #3
Correct, the GT500, Ford GT, KR or SS can all support 1000hp with this BAP, or is you are running twin FPDM's. Price is $469.99
Threads Similar to: Kenne Bell Dual Boost-A-Pump Kit
Kenne Bell Dual Boost-A-Pump Kit Jonathan@DRI 4V / SVT 4 August 21st, 2008 09:18 AM
Kenne Bell Dual Boost-A-Pump Kit Jonathan@DRI 2005 - 2010 0 August 14th, 2008 03:42 PM
