New 800+hp fuel system kit......
It is finally here, a complete fuel system for your 03-04 Cobra. This fuel system is designed to support 800HP safely and includes everything necessary for a complete fuel system swap. From the electronics to the injectors it is all here!!
To start the piece of the puzzle we have the Fore Precision Works Billet Fuel Hat and Ford GT Pumps. We chose the Fore Hat because it is the best way to run Dual Ford GT Fuel Pumps. This Fuel Hat allows a -8AN Fitting to be used without having to weld or modify your stock Fuel Hat which can lead to leaks, and other unecessary failures. We then opted for the Ford GT Fuel Pumps as they are the highest flowing fuel pumps for a returnless style fuel system and thus the reason Ford uses them on the Ford GT Supercar. Coming out of the Fuel Hat we run a -8AN Stainless Steel Braided Line to a Magnafuel High Flow Fuel Filter. This ensures any dirt or debris is kept out of your engine. We then contine running the fuel line all the way to an aluminum Y-Fitting. From the Y-Fitting the fuel line will then be run to each fuel rail. The Fuel Rails we use are again of the highest quality, are billet aluminum and are also made by Fore Precision Works. Attached to these high flowing fuel rails are Siemens Deka 63lb/hr USCAR Injectors. These injectors do not require any injector harness and will clip right into your factory harness. To complete the fuel system we have included a Zone-5 Stage 2 Fuel Pump Driver Module and Kenne Bell Boost-A-Pump. The Zone-5 FPDM replaces the stock FPDM to prevent it from going into thermal shutdown. We also included a Kenne Bell Boost-A-Pump, this will allow maximum flow out of your Ford GT Fuel Pumps without causing any reliability issues but still giving you an extra window of safety to achieve your goals. Kit Includes: * Fore Precision Billet Fuel Hat * Ford GT Fuel Pumps * Fore Precision Black Fuel Rails * Magnafuel Fuel Filter * Siemens Deka 63lb/hr USCAR Injectors * Kenne Bell Boost-A-Pump * Zone-5 Stage 2 Fuel Pump Driver Module * (25ft) -8AN Stainless Steel Braided Fuel Line * (2ft) -6AN Stainless Steel Braided Fuel Line * Black Aluminum -8AN Y-Block Fitting * Assortment Black Hose-Ends * Assortment Black Fittings * -8AN Cushion Clamps These bad boys are ready to go and can be ordered by clicking on the link below or giving us a call. D'Agostino Racing 03-04 Cobra 800HP Fuel System (Black Fittings) [DRI-0304C-FS800B] - $2,075.00 : Performance Parts - Ford Mustang - Cobra - Dodge Viper - Chevy Corvette - C6 - LS1 |
Threads Similar to: New 800+hp fuel system kit......
| New 800+hp fuel system kit...... | Jonathan@DRI | 4V / SVT | 0 | August 21st, 2008 03:35 PM |
| Fuel System?! | 1997Stang | 96-98 | 7 | January 8th, 2008 08:09 PM |
| Fuel System | izze01 | 99-04 | 6 | December 5th, 2007 05:34 AM |
| Fuel System Help! - 89 LX | Super Stock | 5.0 Mustangs | 30 | October 21st, 2007 11:54 AM |
| fuel system | Iownastang | 5.0 Mustangs | 1 | July 2nd, 2007 01:29 AM |
