Go Back   Forums at Modded Mustangs > The Marketplace > Authorized Vendors > DIYAutoTune.com
Discussing Megasquirt For 88 5.0 Mustang in the DIYAutoTune.com Forum. I would like to get a Megasquirt System for my 88 Mustang and I would ...
Old November 2nd, 2008, 11:43 PM   #1
ridebmxfbm's Avatar
1988 Mustang GT Vert
I would like to get a Megasquirt System for my 88 Mustang and I would like to know more details about and if it will work good with a 347 setup etc... I want to keep my car SD thanks alot
1988 GT Vert- 306 AOD built Trans, K&N Cold Air Intake, Mac Catback, many more mods... MAC Long Tubes Coming soon, Dr. Gas Custom X Pipe, 347 Stroker Kit Coming Soon...
Old November 3rd, 2008, 09:48 AM   #2
Authorized Vendor
Hi,
There are a couple MAF based Megasquirt installations, but the majority of them are speed density. The Megasquirt uses a MAP sensor inside its own case, as opposed to the Ford external MAP sensor. The Megasquirt can have its settings adjusted for practically any engine size - we get nearly as many people asking about stroker motors as stock 5.0s.
The biggest difficulty is that there's a lot of options for this car. I'll go over the main choices to consider when planning a Megasquirt installation.
Choice #1: Do you want to build one from a solder it yourself kit, or buy one ready made? This of course depends on your soldering skills and whether you're looking to save time or save money.
Choice #2: Megasquirt I vs Megasquirt II. Either one can work pretty well. The biggest advantage MS-II will have will be that it has more precise injector pulse width resolution. If you're thinking of running giant injectors, this can help smooth out the idle and give you more precise fuel control. If you're running a set of 24 lb/hr injectors, this isn't so important.
Choice #3: Rewire the car vs using an EEC-IV adapter board. Usually I'd recommend the adapter board as it makes installation a lot faster - you don't even have to cut any wires. But if your wiring harness is in bad shape or missing, rewiring may be your best option.
You can email us at websales@diyautotune.com if you'd like to quote us for a package with parts specific to your car.
Old January 20th, 2009, 12:24 AM   #3
ridebmxfbm's Avatar
I cant solder at all, so I want to have the kit, the Megasquirt II system since it deff. will be bigger then 24/lbs injectors, and I would also like the adaptor board.. So want to know more about all that etc.. Thanks
Threads Similar to: Megasquirt For 88 5.0 Mustang
The Megasquirt for Mustangs guide Matt Cramer DIYAutoTune.com 1 October 1st, 2009 05:15 PM
MegaSquirt II V3.0 For sale IcantDo55 Audio/Electronics 0 October 1st, 2008 03:53 PM
Megasquirt to EEC-IV adapter: How to make your own Matt Cramer DIYAutoTune.com 0 September 16th, 2008 03:23 PM
Looking For Megasquirt? TurboLX 2.3 Mustangs 5 December 2nd, 2007 09:07 PM
So Md Mustang Club 3rd Annual Mustang & Ford Show Hwyman Southeast 0 August 8th, 2006 04:39 PM
