How To: Fix VVME HIDs High/Low Beams
Go Back   Forums at Modded Mustangs > Mustang Forums > General Tech > Electrical & Wiring
LinkBack (4) Thread Tools
Old July 17th, 2009, 09:45 PM   4 links from elsewhere to this Post. Click to view. #1
Moderator
03SonicBoom's Avatar
2003 Grand Cherokee
03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of03SonicBoom has much to be proud of
Many people on the forum have HIDs from VVME. The bi-xenon kits are CHEAP (~$100), bright, and allows you to keep both the high and low beams w/ true HIDs. The only problem is that the high and low beams are sometimes swapped.
So many people have/had this problem that I'm doing a write up. Maybe the mods will make it a sticky so others can find it easy.
When the signal plug comes out of the package, the wires may look like this (sorry I don't have a good picture; mine has been changed so I can't take a picture).
Notice that the order is brown, white, blue. None of these wires are in the correct location. Yeah, that's what you get for ordering Chinese.
The first step is to pull the pins out of the plug. To do this you need to push a small prong back into the pin. Once this is done, you can pull on the wire and the pin will come out. See below for a picture of a pin:
Pin Top (prong circled):
Pin Side (prong circled):
Once all the pins are out, take the tip of a knife (or something else thin) and bend the prong back out (like seen in the picture above). Then, push the pins back into the plug. The wires should be blue, brown, white. See below for correct wire order in plug.
That's it, you're done. Now the low beams should be low beams and the high beams should be high beams. Here's some pictures of the high and low beam difference.
Low Beams (6000k):
High Beams (6000k):
Distance from car to garage:
6000k HIDs:
Old July 17th, 2009, 10:06 PM   #2
zippeewannabee
ZoomZoomMFer's Avatar
06' Mazda Speed6
ZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura aboutZoomZoomMFer has a spectacular aura about
iTrader: 17 reviews
Send a message via AIM to ZoomZoomMFer
thanks broseph, now i know what your talking aboot
Cobb SRI | Eibach ProKit | JBR Short Shift Plate | JBR Rear Motor Mount
Old July 18th, 2009, 11:08 AM   #3
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Mine are shipping from China as we speak.
Old July 20th, 2009, 02:06 PM   #4
Moderator
wraitherx's Avatar
'99 SVT Cobra
wraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud ofwraitherx has much to be proud of
iTrader: 11 reviews
nice write up... might have to get a set
BUILD 2 IN PROGRESS
Old July 21st, 2009, 01:39 PM   #5
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Just got mine today at lunch. Sonic I sent you a PM an hour or so ago...
But this thread; is this something I *HAVE* to do or is this just if shit isn't working...?
Old July 21st, 2009, 01:41 PM   #6
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Edit; I'll just look and see how the wires are out of the box when I get home.
Old July 21st, 2009, 01:47 PM   #7
1999 Mustang GT
Regulator is on a distinguished road
Send a message via AIM to Regulator Send a message via Yahoo to Regulator
Do they have a foglight kit to go with the headlights?
'99 GT FS/FT. Click here for details!
"And I heard a voice in the midst of the four beasts, I looked and behold: a pale horse.
And his name, that sat on him, was Death. And Hell followed with him."
Old July 21st, 2009, 02:01 PM   #8
2003 v6
03stanggg will become famous soon enough
wow THANKS SOOOOOO MUCH... ive had these reversed on my car for about a year now and i can finally fix it!
http://i723.photobucket.com/albums/ww234/wendell1988/sss.jpg
Old July 21st, 2009, 03:09 PM   #9
Moderator
2003 Grand Cherokee
You don't have to do this. I usually install them as they come just so I'm sure they are backwards. But, I've heard that some people get them wired correctly (w/ all the installs I've done, I've never been so lucky). If you wire them up and they are backwards, it only takes 2 minutes to fix.
I believe any of the 800 bulbs will work as fog lights. I don't have HID fogs and have never done them so I'm not 100% sure. Other people on here have done it so try searching?
Old July 21st, 2009, 03:19 PM   #10
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
weems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud ofweems has much to be proud of
Thread stuck
Old July 21st, 2009, 05:45 PM   #11
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
Originally Posted by weems View Post
Thread stuck
Sweetness
Old August 7th, 2009, 03:04 PM   #12
akvanden's Avatar
akvanden is on a distinguished road
Send a message via Skype™ to akvanden
Thank you! Fixing when I get home from work.
K&N CAI
DiabloSport Predator tune
Bassani o/r x pipe
Borla cat back
Eibach Pro kit
Nitto 555r on Cobras
Old January 24th, 2010, 02:49 PM   #13
14.2
_Red_Rocket_ is on a distinguished road
yes, they do. Just order a set of HID 893 bulbs. You may want to consider the slim kit as the ballasts are smaller and probably easier to mount.
I just ordered my set of 15k (purple) HIDs for my 4'' round fogs (2000 cobra R bumper on 2004 Mustang)
Old May 13th, 2010, 02:52 AM   #14
2001 Mustang GT
bootychowda is on a distinguished road
THANK YOU!!!!!!!!!!!!!!!! ive been riding for like the last 2 years with my lights backwards until now. muchos gracias
Old May 13th, 2010, 07:35 PM   #15
2002 GT
poranksta is on a distinguished road
I just put in 8k lights and they are normal colored lights, but when I turn on my bright lights they turn to 8k? How do I solve that.
Old May 13th, 2010, 09:43 PM   #16
Moderator
2003 Grand Cherokee
Are they VVME HIDs? Do you have a halogen and HID bulb per side? Or is the HID on a servo that moves it?
VVME HIDs are true bi-xenon kits. It doesn't sound like you bought a VVME kit.
Old May 19th, 2010, 01:48 AM   #17
Look Ma! My First Post!
anglotisa is on a distinguished road
Really a educative and informative post, the post is good in all regards,I am glad to read this post.
Acai berry detox
Force Factor
Old September 26th, 2010, 03:09 AM   #18
aderzhang's Avatar
Mustang 09
aderzhang can only hope to improve
Send a message via MSN to aderzhang Send a message via Skype™ to aderzhang
thanks for sharing it here, very useful for someone
from then on , they will not reverse the wire for hi and low beam again....
09 Ford Mustang black
VVME H13-3 bi-xenon HID kit 6k
Old September 26th, 2010, 03:16 AM   #19
aderzhang's Avatar
Mustang 09
maybe he took some pictures from others as he mentioned above....
the VVME Hi/Low HID KIT is one beam for hid and one beam for halogen....most time when people install hi/low hid kit, they often reverse the hi and low beam wire.... so that is why after installation, the lights cant work .....
VVME does not only have bi-xenon kits, and single beam and hi/low beam.. as for whether he bought vvme kit or not i am not so sure....
but i bought bi-xenon hid kit from VVME website ( one of friend recommend to me ,he once bought 2 sets hid kits from VVME) last year, that is H4 digital bi-xenon hid kit that still works well now.....
LinkBack to this Thread: http://www.moddedmustangs.com/forums/electrical-wiring/130584-how-fix-vvme-hids-high-low-beams.html
HID Install Problem - Grand Prix Net This thread Refback March 17th, 2012 11:38 PM
HID Install Problem - Grand Prix Net This thread Refback September 2nd, 2011 01:14 PM
HID Install Problem - Grand Prix Net This thread Refback August 27th, 2011 09:04 PM
HID's installed, now help/ advice needed. - Nissan Juke : Juke Forums This thread Pingback March 8th, 2011 03:37 PM
Threads Similar to: How To: Fix VVME HIDs High/Low Beams
How to keep fog lights with high beams on finally03gt Audio/Video 25 May 1st, 2012 03:30 AM
no low beams??? johnr2001 99-04 4 August 23rd, 2008 02:20 PM
high beams arent working ROUSHME661 Audio/Video 8 February 24th, 2008 05:04 PM
high beams Random-Hero Audio/Video 2 August 29th, 2007 07:34 AM
High Beams quit working what do i do? Pclacross 99-04 5 February 9th, 2007 08:10 PM
