How To Install An Aftermarket Tach
Go Back   Forums at Modded Mustangs > Mustang Forums > General Tech > Electrical & Wiring
LinkBack (50) Thread Tools
Old December 25th, 2007, 03:06 PM   50 links from elsewhere to this Post. Click to view. #1
TurboLX's Avatar
1988 Mustang LX Turbo
Thanks To MustangMatt96GT for the awesome write up!
Originally Posted by MustangMatt96GT View Post
It is common knowledge that the stock Oil Pressure gauge and Water temp gauges are completley inaccurate. But who would have thought the Tachometer. It is completely in accurate. Some times i would bounce off the limiter at the track at 5500 RPM and next time around 5700 RPM. It made me concentrate, and not get as good of times, because i bounced off the limiter because of inaccurate gauges!
I bought a Autometer aftermarket 5 inch tach with Shift light. I also bought a UPR tach bracket. Both are very high quality. The instructions didnt come with it because i bought it used. But i have found a great set of instructions.
Here is the link. http://www.egauges.com/pdf/AutoMeter/859e.pdf
1. Unscrew the Gauge Cluster bezel and take the headlight knob off. (i just pull really hard and it comes off everytime)
2. Take the two torx screws out of the center dash portion above the CD player, and then take the CD player and Radio out.
3 Behind the Radio, there is a torx screw back in there holding the bezel on. Take the screw out and then pull on the bezel. It will come off.
4. Now take the two torx screws out on the left of the AC controls. Not take the tach, and its bracket, and screw the screws back in. Now reassemble the center dash, and plug the radio and CD players back in.
(If mounting the tach elsewhere disregard steps 2-4)
Now your dash should look something like this.
Next step is to wire it up.
Take the actual gauge cluster out. There are 4 torx screws holding it in. You will have to unplug two plugs from it too.
5. There is a black and a white plug.
Take the white plug. And find the Tan and yellow wire, in pin 8. That is the tach signal wire. That is what the tach wire will be connected to. In my case, it was a green wire. I used scotch locks to tap into the wires.
Now all you need is a power source for the tach itself, a ground, and a power source for the light. You dont want the light on all the time, so you have to tap into a wire that will only give power to that when the lights are on. This wire can be found, along with the power wire for the tach, and the ground, from the rear defroster switch.
In my picture there are already wires tapped into it, because i have my other gauges running off of the same wires. The Rear Defroster Switch is protected by a fuse.
This is a picture of the wiring of the Rear Defroster Switch
The Pink/Light blue (Pin 3) wire is the power wire to the tach. In this case, that was my red wire. So I scotch locked it in place there.
The Black wire in (Pin 4) is the ground. You can scotch lock to that, but i just found a new ground under the dash.
The Light blue/Red switch (Pin 5), is the power for the Lighting, so i connected my white wire to that.
Now reconnect the wires to the back of the gauge cluster, and reinstall it. all the wires should be hidden behind the cluster now. So put the bezel back on.
Turn on the lights, and see if the power to the light is working.
If that checks out, put the car on the Start Position. If it goes to 0 and the light lights up then everything is checking out.
Next fire up the car, and see if the tach works! If it does, set the shift points and have fun!
Completed Pictures!
Completed Movie! Make sure it worked! Compare to my Stock tach.
How my car idles!
A 96 GT with stock computer tune Bounces off the limiter at 5900 RPM
And the stock tach was completely inaccurate.
Good luck!
and Ujslost thanks for the help with the wiring diagrams!
Any questions just let me know!
Old March 8th, 2008, 03:11 AM   #2
thaited is on a distinguished road
Bounce House
Kinda reminds me of that time I put together one of those inflatable bounce house things, but that didn't go so well. Well, no not actually I just though that was funny.
Nice and thank you for the great writeup.
Old May 31st, 2010, 09:41 PM   #3
cobrastang_07's Avatar
1999 Mustang GT
12.4@ 109
cobrastang_07 is on a distinguished road
can this be used to install a tach in 1999 mustang GT?
Old July 8th, 2011, 11:02 PM   #4
killapits is on a distinguished road
and what about 2002 is it the same
Old March 8th, 2012, 11:53 PM   #5
Look Ma! My First Post!
1986 ford mustang gt
fordgt86 is on a distinguished road
will this set up be the same for a 86 gt
LinkBack to this Thread: http://www.moddedmustangs.com/forums/electrical-wiring/48019-how-install-aftermarket-tach.html
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback April 26th, 2012 07:01 PM
Tach WIRING FOR 94 LT 1_Internet Wiki Knowbase This thread Refback March 31st, 2012 04:48 PM
fallas en mustang - Page 2 - www.v8Power.org.mx This thread Refback March 17th, 2012 06:54 PM
aftermarket tachometer - Google Search This thread Refback January 16th, 2012 09:54 PM
Installing MSD window switch | Mustang Forums at StangNet This thread Refback December 23rd, 2011 06:31 PM
1986 ford mustang lx electrical digram This thread Refback December 14th, 2011 03:06 AM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback November 21st, 2011 05:20 AM
fallas en mustang - Page 2 - www.v8Power.org.mx This thread Refback October 29th, 2011 10:10 PM
fallas en mustang - Page 2 - www.v8Power.org.mx This thread Refback October 29th, 2011 10:02 PM
Lets see those shift lights. - SVTPerformance This thread Pingback October 28th, 2011 01:41 AM
Tach adapter - Montreal Mustang This thread Refback July 7th, 2011 07:43 PM
Tach adapter - Montreal Mustang This thread Refback July 7th, 2011 03:31 PM
Tach adapter - Montreal Mustang This thread Refback July 7th, 2011 12:17 PM
Tachometer Question This thread Refback May 1st, 2011 01:46 AM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback April 17th, 2011 10:56 PM
Ford-Club Finland • katso viestiketjua - Mondeoon lisä rpm mittari This thread Refback February 26th, 2011 09:59 AM
Tach adapter ? - STLMustangs Forums This thread Refback February 3rd, 2011 01:18 PM
Need a new tachometer - Page 2 - CMC Forums This thread Refback January 3rd, 2011 04:29 PM
Need a new tachometer - Page 2 - CMC Forums This thread Refback January 2nd, 2011 11:04 AM
Tachometer Question This thread Refback December 28th, 2010 07:49 PM
Tachometer Question This thread Refback December 28th, 2010 11:17 AM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback October 29th, 2010 02:01 PM
How to Install a Vintage 3 Wire Tachometer on My Car | eHow.com This thread Refback October 22nd, 2010 02:11 PM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback October 8th, 2010 06:09 PM
Ford-Club Finland • katso viestiketjua - Mondeoon lisä rpm mittari This thread Refback September 10th, 2010 11:28 AM
Installing MSD window switch - Mustang Forums at StangNet This thread Pingback September 1st, 2010 06:37 PM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback July 27th, 2010 01:04 AM
Macgor's NZ Speedway - HELP! This thread Refback July 21st, 2010 06:20 AM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback July 6th, 2010 10:19 AM
mustang tach This thread Refback May 28th, 2010 09:11 PM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback May 1st, 2010 05:59 PM
ßÜíÜÝ ÊÜõÜÚÜÑÝ æÊÜÕæä æÊäÙÝ ÍÓÂ Ó ÇáÎãæá æÍÓÂ Ó åæÇÁ ÇáËÑÊá ÈÏí ÈÓíÂÑÊß ÇáÌÏíÏÉ ¿¿¿ - ãäÊÏíÇÊ ãßÔÇÊ This thread Refback May 1st, 2010 11:04 AM
Tacometro Para Mustang - decibeles.com This thread Refback April 4th, 2010 04:36 PM
Auto Meter Tach Wiring Diagram - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback April 2nd, 2010 05:00 PM
Rear Defrost Switch Wiring Diagram For Mustang - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback March 10th, 2010 11:53 AM
Tacometro Para Mustang - decibeles.com This thread Refback February 4th, 2010 01:46 PM
Tacometro Para Mustang - decibeles.com This thread Refback February 3rd, 2010 02:17 AM
Tacometro Para Mustang - decibeles.com This thread Refback February 3rd, 2010 12:09 AM
Tacometro Para Mustang - decibeles.com This thread Refback February 2nd, 2010 07:29 PM
Ford-Club Finland • katso viestiketjua - Mondeoon lisä rpm mittari This thread Refback January 4th, 2010 08:22 AM
Sunpro Tach Wire Diagram - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback December 25th, 2009 11:17 AM
Mustang Tach Install on Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback August 15th, 2009 04:43 PM
Wiring Diagram for Sunpro Tach on Kosmix This thread Refback May 17th, 2009 04:26 PM
Autometer Tach Wiring Diagram on Kosmix This thread Refback May 15th, 2009 08:33 PM
Autometer Tach Wiring Diagram on Kosmix This thread Refback May 15th, 2009 08:24 PM
Wiring Diagram for Sunpro Tach on Kosmix This thread Refback April 28th, 2009 08:39 PM
Wiring Diagram for Sunpro Tach on Kosmix This thread Refback April 24th, 2009 04:35 AM
Ford-Club Finland • katso viestiketjua - Mondeoon lisä rpm mittari This thread Refback March 21st, 2009 09:59 AM
Ford-Club Finland • katso viestiketjua - Mondeoon lisä rpm mittari This thread Refback December 9th, 2008 01:51 PM
Ford-Club Finland • katso viestiketjua - Mondeoon lisä rpm mittari This thread Refback December 9th, 2008 07:44 AM
Threads Similar to: How To Install An Aftermarket Tach
How To install an Aftermarket Tach in a 96-98 MustangMatt96GT 96-98 30 May 5th, 2008 09:22 AM
tach driver install Blk01ponyGT 99-04 4 November 17th, 2007 06:10 PM
anyone ever install a tach on a 99-04 v6? PLEASE HELP! ricerraper33 Audio/Video 8 September 20th, 2007 09:35 PM
Tach install Quick question please!! Troyzstang Modular Mustangs 8 November 17th, 2006 05:40 AM
sun pro tach install terribleonexx88 5.0 Mustangs 1 October 19th, 2006 01:18 PM
