3.9L V6
Maguires Claybar
i took about an hour and a half after i washed my car to claybar it...finished it off w/ some Maguires Gold Class Wax....i don't have any pics uploaded yet so ill need to do that soon...but for anyone who's never claybar'd their stang...Highly worth the work and leaves the paint as smooth as glass.
[SIGPIC][/SIGPIC] 6k HIDs - Rear Sway Bar - Mac Prochamber - Goodridge Gstop SS Lines - Lots of Visual Fun - Go Fast Mods (no point in buying...it's a v6) Want to see your car as art...ask me how |
2000 gt
yes it's hard work but it is worth it.
Procharged 2000 5 Speed BAB GT, built motor, blower cams, speedy dyno tune 412 hp, 450 rw tqHARDCORE CREW BRIGHT ATLANTIC BLUE CREW #1 MEMBER |
2000 V6
First time is very hard and takes a long time. After that, do it about every 2 weeks or so (depending on how often your car leaves the garage). It becomes very easy to mantain that perfect finish.
For a smoother finish, polish, glaze, and wax it. |
#4 | |
2011 Mustang GT
12.1 @ 116
Claybarring is only needed roughly every 4-6 months IF THAT. It all depends on how hard the elements are on your car and where you live. Waxing should be roughly ever 4-6 weeks, but again depends on how bad the weather and heat is in your area. When you're car starts lose the water beading action it's time to rewax. You can preserve the wax a tad bit longer by using a quick detailer after washes.
Mods in garage. New mods, new track times soon. |
Wax on, Wax off
I claybar about every 6 months. I usally do it in December and June. I would say 2-3 times a year max.
i would only clay a white car, possibly a silver or gold. reason being is if you rub your car out about once a year if that, and polish it every month or 2, and wax it every other week, you will have no crap built up on your paint.
clay is great for removing rail dust on white cars. but rubbing gets it all done so much faster and has the same results, smooth wet looking paint(after you polished and waxed it to seal the effects)
98 GT, Cold Air Intake, Flowmasters, off road H-pipe, Predator Tuner, MIL Eliminators, BBK 70mm Throttle Body, Stack upper intake, plenum Spacer, t2 rear dif, moser axles, ford racing aluminum driveshaft, 4.10's, steeda tri axe short throw shifter |
Blown 03 GT
I bet if you clay any car after a year youll clean alot of crap off it.
#8 | |
Wax on, Wax off
How can you say clay is only good for White, Sliver, and Gold cars? Clay removes impurites from the CLEAR coat of the car. No color associated with a clear coat therefore it does not matter what color your car is. It could be poke-a-dotted from every color of the rainbow and still a clay bar would work just as good because it works on the clear coat.
#9 | |
Tech Exchange Head Honcho
2003 SVT Cobra
11.70 @ 121
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 3 reviews
Wax on, Wax off
+1 Polishing without a clay bar means you would make even more swirls by losening the contaminates out of the clear coat and buffing them around on top of the clear.
2011 Mustang GT
12.1 @ 116
Exactly. You'd just be 'polishing' the dirt and other small imperfections into the clear coat causing more swirls than you started out with.
a wool pad and rubbing compound will get anything off of the paint, in my experiance. and clay bars like i said are great for getting rail dust off light colored cars were it shows up. claying is fine to do, im just saying what i would do. i prefer to wheel impurities away, then polish and wax over claying.
however like near the wheel wells i would clay the tar off after i washed the car(so not to waste my clay bar) on any car, but not the whole car unless there was paint, tar, or some other substance similiar to these.
2003 SVT Cobra
11.70 @ 121
There is always impurities on your car rather you can see them or not. Grab a ziploc bag and rub your car and you can feel them. You should ALWAYS, let me repeat that ALWAYS clay your car before you take any kind of machine to it with ANY type of pad.
2003 Azure Blue Mach 1
4,000 miles on the ODO
i want to try either Mothers or Maguires which is better and what does kneadling mean also is mothers cleaner wax a good follow up after i use the clay bar; i used to use it all the time on my old car but haven't waxed the stang yet and its black
FS: Mach 1 OEM Wheels 3K miles with NEW Nitto 555's 275/40/17's PM me http://www.moddedmustangs.com/forums...555s-rear.html Last edited by dannyboy281; July 17th, 2009 at 04:30 AM. |
#16 | |
FOR SALE: v6 cam SPECS: 207/215 110lsa |
Made in U.S.A.
2011 F150 FX4
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 8 reviews
Oh god ..
#18 | |
FOR SALE: v6 cam SPECS: 207/215 110lsa Last edited by WLJohnson05; July 27th, 2009 at 01:57 PM. |
Made in U.S.A.
2011 F150 FX4
I see what you did there.
3.9L V6
to Dannyboy: I prefer Maguires claybar because it is the only one ive used
...but from other people i know they also prefer Maguires...Something about feeling the paint and my hand glides across w/o feeling bumps....
Threads Similar to: Maguires Claybar
| Claybar, Polish, and Wax. (need advice) | Dansby | General Car Care & Detailing | 15 | January 27th, 2009 04:16 PM |
| Claybar Guide | travis_afx | General Car Care & Detailing | 3 | November 12th, 2008 02:16 PM |
| ICE liquid claybar and wax | Juggalo_X | The Clubhouse | 34 | September 10th, 2007 04:52 PM |
| First time claybar+polish | Reset | Visual | 6 | September 3rd, 2007 09:14 PM |
| Claybar question? | adam0421 | 2005 - 2010 | 4 | May 21st, 2007 02:31 PM |
