Removing Window Tint The EASY Way!
Go Back   Forums at Modded Mustangs > Mustang Forums > General Car Care & Detailing
LinkBack (1) Thread Tools
Old November 18th, 2009, 09:38 PM   1 links from elsewhere to this Post. Click to view. #1
1987 GT
13.19 @ 107.02 (street tires)
chrisbmx is on a distinguished road
Wink
The easiest way to remove window tint from a car window is to use a simple clothes steamer. I picked mine up from Target for about $20. This was from my Mercury Cougar. It had bubbled up purple tint on it and I thought it would be impossible to remove. I even called a tint shop and they wanted $200 + to do it. So I started looking around and found this way. WOW, was I surprised. Total of 1 hour to remove the rear window tint with NOTHING left behind. Don't use razer blades, you can damage rear defroster lines! Anyhow, you take the steamer and start steaming the shit out of a corner of the tint. Now here is the important part: GO SLOWLY!! I can't stress this enough. If you go too fast, the glue and the tint may separate and you'll have a mess to clean up. Trust me, it's worth it to go slow. Turn on some music, crack open a beer, and TAKE YOUR TIME. Best part is, if you get some overspray, no biggie, it's just water! It will proabably take at least a half hour per window to get the tint off. After you're done, you may have some glue left on the window, but not much. Take some Laquer thinner and use this to clean anything that's left on the window. After it's clean, use either some ammonia free cleaner if you're retinting the window, or just some windex if you're not to get the laquer smell out. Now you can see the Chevy's out of the rear window better as you pull away from them!!! Just wait until you sober up first
Old November 19th, 2009, 07:52 AM   #2
It's in the details Mod!
M.P. Cobra Fan's Avatar
01 Cobra Vert
Nov 09/10 ROTM!
M.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond reputeM.P. Cobra Fan has a reputation beyond repute
I have always found the best way is a nice cold day. Last 2 cars I stripped took 15 minutes to do the whole car. Did not heat the tint at all. Came off in big sheets.
Pinup in signature by loish.net
Modded Mustangs Cobra Club#007
Military Crew E5
VOTED MM's BEST SIGNATURE 2010. THANKS STANGGTR07
Old November 19th, 2009, 08:18 AM   #3
slow as sin....
pyschopath76 will become famous soon enoughpyschopath76 will become famous soon enough
thats what i did when my back window bubbled was waited for a cold day......and grabbed the corner and pulled slow. came off in a big sheet then just used some good old elbow grease where some of the glue stuck and some windex and it came right off.
JLT Ram Air Intake/Accufab 70mm Throttle Body & Upper Plenum/SLP Longtube Headers/SLP Catted X-pipe/SLP LM1/4.10 gears
Military Crew - AZ2(AW)
Black Stang Member #6
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-car-care-detailing/143912-removing-window-tint-easy-way.html
Car Tint Blogs (Tinting, Window, Car Window Tint) @ Exporting.name This thread Refback November 26th, 2009 08:29 PM
Threads Similar to: Removing Window Tint The EASY Way!
Removing tint glue Firaga All Other Vehicles 9 September 16th, 2009 11:25 AM
removing tail light tint... ZoomZoomMFer The Clubhouse 18 March 24th, 2009 02:36 PM
removing window tint tom2000r 99-04 20 April 13th, 2008 07:47 PM
Removing Window Tint ZoomZoomMFer 96-98 53 April 3rd, 2008 05:05 PM
What Is Excellent On Removing The Glue From Old Tint? bzeboymenz 99-04 14 December 27th, 2007 01:47 AM
