waxing question - Forums at Modded Mustangs
post #1 of 33 Old June 15th, 2010, 02:56 PM Thread Starter
cbrown54's Avatar
waxing question
this might be a bad question, but can you wax your car too often?
cbrown54 is offline
post #2 of 33 Old June 15th, 2010, 10:50 PM
dannyboy281's Avatar
Yes you can wax it too often and it will build up residue rewax when you feel and see your mustang isnt repelling water as well. And its not a bad question man.
2003 Azure Blue Mach 1
MGW, MAC Offroad X, Flowmaster Original 40's, Maganaflow 3.5" Tips, Anthracite 18x9's & 18x10's FR 500's wrapped with Nitto 555's, Eibach Pro Kit,
dannyboy281 is offline
post #3 of 33 Old June 16th, 2010, 02:15 AM
Wax on, Wax off
Zatrekaz's Avatar
iTrader: 17 reviews
+1
If you wax without removing the old wax you begin to get a build up. What will happen is this: say your wax last 3 months. You rewax your car once a month without removing the current wax. 3 months down the road when your bottom layer (first layer) of wax fades, so does ALL the layers on top of it, leaving you with no wax until you wax again.
Either wait till your current wax fades, or do a IPA (rubbing alchohol) wipe down before applying new wax. I personally like to wash the car with Dawn Dish Soap followed by a IPA wipe down.
Chemical Guys also sells a wash soap that can be used the strip wax off the car.
2013 Hyundai Genesis Coupe 2.0T
2006 Lexus 250 IS - Sold
2003 Mustang V6 - Sold
Zatrekaz is offline
post #4 of 33 Old June 21st, 2010, 04:13 PM
too much waxing can cause hazing
19stang88 is offline
post #5 of 33 Old June 21st, 2010, 04:27 PM
One overlap of wax isn't bad. Everytime I wax (and the pros will tell you the same), a good conmbination of two waxes will go along way. And some of my favorite waxes require minium of two coats too.
Perfectcircle is offline
post #6 of 33 Old June 21st, 2010, 05:00 PM
Wax on, Wax off
Zatrekaz's Avatar
iTrader: 17 reviews
I don't know where you heard that, but I belive you are mistaken. I have never hard of to many coats of wax causing haze...
Two waxes? I think you mean a combination of a Wax and a Synthetic Sealant. The most effective way to do it is to lay down a coat for Natural Carnuba based Wax followed by a coat of Synthetic paint sealant. That gives you roughly 4-5 months of protection depending on your location, wash habits, and driving conditions.
Zatrekaz is offline
post #7 of 33 Old June 22nd, 2010, 06:56 PM
Compeltely wrong.
Originally Posted by Zatrekaz View Post
+1
No.
Completely wrong.
Winner.
Nope some waxes blend together. Look at Dodo Juice for once. Mixing Purple Haze and Supernatural is pretty common.
ALOT of people will do 2 coats of a wax. There is no set standard where it HAS to have a sealant AND a wax. you can do 2 coats of a nuba without any ill effects excepet the durability and even then by the time you rewax you should still have PLENTY of protection left.
As it stands I have Collinite 845 and a layer of Natty's Red on my car. It's held up since April and still beads and neither one of those are sealants.
zinc02GT is offline
post #8 of 33 Old June 22nd, 2010, 07:36 PM
Wax on, Wax off
Zatrekaz's Avatar
iTrader: 17 reviews
I never said that its not common to do two coats of wax. Simply that I had never heard of mixing two DIFFERENT coats of wax. I stand corrected, just never heard of that.
Also, beading is not a indication of a wax/sealants status... you should know that
Zatrekaz is offline
post #9 of 33 Old June 22nd, 2010, 07:50 PM
Technically it is.... How else do we judge protection? You can't "SEE" the wax, and wax beads water. A good eye can tell the difference between regular water bead and wax bead.
zinc02GT is offline
post #10 of 33 Old June 22nd, 2010, 07:54 PM
Wax on, Wax off
Zatrekaz's Avatar
iTrader: 17 reviews
Well, some waxes sheet water more than bead. Plus a smooth clean surface will bead water. It is a good way to judge it, but its not fail proof.
Oh ya, finally got some MF from Pak Shak... got 12 of the Ultra-Plush 16x16 and a free 16x24 one.
Zatrekaz is offline
post #11 of 33 Old June 23rd, 2010, 12:16 AM
Compeltely wrong.
Am I really completely wrong I got my information from reading an article from Detailed Image maybe my wording came out wrong sorry. I should have posted these links instead of doing the explanation. These are the links I got my information from. One of the articles even states "you dont want to layer wax on top of old wax" thats what i meant i didnt mean not to apply coats sorry for the bad wording.
How Long Do Waxes Last and When Should I Reapply? – Detailed Image
http://www.detailedimage.com/Auto-De...arnauba-Waxes/
post #12 of 33 Old June 23rd, 2010, 10:44 AM
00redgt's Avatar
iTrader: 5 reviews
Send a message via Yahoo to 00redgt
by washing the car with dawn will it remove the old wax by its self or dawn and rubbing alcohol remove it better.
00redgt is offline
post #13 of 33 Old June 23rd, 2010, 10:55 AM
Bangarang's Avatar
So four coats of wax throughout the summer would be overkill? For example?
1999 Jeep Cherokee 4.0 Classic - New modder
2000 Mustang GT - SOLD (I will have another one day)
Bangarang is offline
post #14 of 33 Old June 23rd, 2010, 12:58 PM
Wax on, Wax off
Zatrekaz's Avatar
iTrader: 17 reviews
It will help, by Dawn will not remove it all. do an IPA wipe down to be sure.
As long as you remove the old wax first, your ok. However a typical carnuba wax will last you 3 months.
Zatrekaz is offline
post #15 of 33 Old June 23rd, 2010, 12:58 PM
hey guys, this is eric who posted the article on DI
what I meant by the comment of "you dont want to just layer..." was this:
layering wax upon wax upon wax will still only have one true layer of wax bonded to the paint. The rest of the layers are going to be removed more easily since they arent bonding to anything solid, just removable wax. So those people who say they have 13 layers of wax on the car, they dont. They just applied it 13 times, but removed a little of the previous layer by adding the second layer. I am not talking a lot of removal, but a tad.
Waxing once a month, you are not giving the wax a true bond to the paint. Think of all the washings, the driving conditions, the environmental fallout that is on the car that has bonded to the paint (the stuff that just doesnt come off the paint with ease while washing). where do you think that is going if you dont "prep" the car for wax? Its going to stay on the car while you wax over the top of it, leaving the wax still not bonding to the paint. Thats is why a pre-wax cleaner is a good option for those who have the time. The general rule is waiting 12 hours or so between layers and layer them back to back for a "good 3 layers protection".
Hope that clears some things up for ya...
Eric
Envious Eric is offline
post #16 of 33 Old June 23rd, 2010, 01:13 PM
Hey Eric thanks for the clarification and advice. I am sure the guys are going to be as stoked as I am to see that you posted here on MM. I hope to see more of you here thanks again and
post #17 of 33 Old June 23rd, 2010, 07:01 PM
what carnuba is giving you 3 months? most I get out of them is about 4 week-6weeks
post #18 of 33 Old June 23rd, 2010, 07:39 PM
OFM
OFM's Avatar
What are some good Wax Wash Remover you can get at locals stores ?
OFM is offline
post #19 of 33 Old June 23rd, 2010, 11:23 PM
Dawn would be your best bet. To my knowledge there is not OTC stuff that could do what you want. I own Chemical Guys Citruswash + Gloss and if it is diluted correctly it can remove old wax.
Detailing Crew Member
North Carolina Modded Mustangs #5
00BlueMustang is offline
post #20 of 33 Old June 24th, 2010, 03:33 AM
Wax on, Wax off
Zatrekaz's Avatar
iTrader: 17 reviews
Notice I used the word "Typical".
How many miles you get from any LSP depends on many factors. Such as your location, driving conditions, washing style, ect. Now.. if you are only getting 4-6 weeks (1 - 1 1/2 months), then you are either washing incorrectly or are stripping it before it really IS gone.
What makes you say you only get that long? How do you know its gone in 4-6 weeks?
Zatrekaz is offline
Human Verification
