Need a quick response... In between sealant layers question.
Go Back   Forums at Modded Mustangs > Mustang Forums > General Car Care & Detailing
Old October 22nd, 2011, 04:10 PM   #1
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
So I put on a layer of Powerlock last night, plan on putting another one on today. But I drove it a bit today. What should I use to clean it in between. Normally I IPA wipedown before an LSP, but doesn't IPA stip your LSP?
I have some Mother's Showtime and Meguiar's Quick Detail. Should I use that?
Or do I need to wash the car again?
MM Cobra Club #66
Old October 22nd, 2011, 04:50 PM   #2
dannyboy281's Avatar
2003 Azure Blue Mach 1
5,000 miles on the ODO
dannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to all
You can use Mothers Showtime or Meguiars Quick Detailer thats fine man or a distilled water wipe down just use very light pressure as always when quick detailing. Dont do an IPA wipedown or you will strip off the first coat. Apply Powerlock to the entire vehicle and then let it cure to the clear for 1 hour. Then remove it, if you let it cure for this time frame your bonding will be alot better and it will provide longer protection. Also is still just as easy to remove as if you just waited 15 minutes. You can even leave it curing overnight in the garage and Powerlock will still be very easy to remove in the morning.
MGW, MAC Offroad X, Flowmaster Original 40's, Maganaflow 3.5" Tips, Anthracite 18x9's & 18x10's FR 500's wrapped with Nitto 555's, Eibach Pro Kit,
Old October 22nd, 2011, 05:07 PM   #3
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
Thanks for the response, I let the first coat cure for about 30 minutes before buffing it off. I'll try to wait a little longer on this one. Then a coat of AGHD. I can't wait to see this finish
MM Cobra Club #66
Old October 22nd, 2011, 05:38 PM   #4
I like the way Blackfire Wet Diamond looks topped with Autoglym High Definition I have it on our ML 350 right now (see link) I am sure Powerlock will look just a sick I have yet to try it but I am going to since I have 8 oz of Powerlock left my brothers Jeep wrangler will be the tester!
2010 Mercedes ML350 Strip / Re-Protect
Threads Similar to: Need a quick response... In between sealant layers question.
super quick response need branden0502 V6 Mustangs 13 May 12th, 2010 02:16 PM
need quick response Drew S. V6 Mustangs 2 July 3rd, 2009 10:04 PM
Need help a quick response will be much appreciated. bbrewer03 96-98 1 August 16th, 2007 08:37 AM
