RLY SRS
Buffer/Product Info (Speeds And The Like)
I cant ever find the info on buffers/products that are out there in one place...So lets make this happen...If you have any info please follow the format below and post and I will add it...If you have a certain OPM that a product seems to give best results at please add that as well...
I know this much: 7424: 3.7 amp Motor 2,500 OPM to 6,000 OPM Speeds: Speed Setting 1 - 2500 OPMs Speed Setting 2 - 3200 OPMs Speed Setting 3 - 3900 OPMs Speed Setting 4 - 4600 OPMs Speed Setting 5 - 5300 OPMs Speed Setting 6 - 6000 OPMs 7424XP: ![]() 4.5 amp motor 2,500 OPM to 6,800 OPM Speed Setting 1 - 2500 opm Speed Setting 2 - 3360 opm Speed Setting 3 - 4220 opm Speed Setting 4 - 5080 opm Speed Setting 5 - 5940 opm Speed Setting 6 - 6800 opm Flex 3401 7.5 amps 900w Motor Speed 1 160 rpm / 3200 opm Speed 2 200 rpm / 4000 opm Speed 3 270 rpm / 5400 opm Speed 4 330 rpm / 6600 opm Speed 5 400 rpm / 8000 opm Speed 6 480 rpm / 9600 opm flex does not play as well with the MF pads as do the traditional DA's Griots 6" DA Lifetime warranty no questions asked 7 amp 850w Motor Speed Setting 1 - 2500 opm Speed Setting 2 - 3300 opm Speed Setting 3 - 4200 opm Speed Setting 4 - 5100 opm Speed Setting 5 - 6000 opm Speed Setting 6 - 6800 opm Megs DA 110v2 4.2 amp 430w Motor Speed Setting 1 - 1800 opm Speed Setting 2 - 2800 opm Speed Setting 3 - 3800 opm Speed Setting 4 - 4800 opm Speed Setting 5 - 5800 opm Speed Setting 6 - 6800 opm Tips 4800 for DA MF cutting discs and DA Compound 3800 for DA MF finishing discs and DA Finishing wax M105 - 6 M205 - 6 85RD - 5/6 EZ-Creme Glaze - 4/5 Glossworkz Glaze - 4/5 BFWD - 3/4 Powerlock - 3/4
2008 Acura TL Type-S - 2008 EB Ford Expedition - 2002 Boosted GT - Sold Google+
More show than Go
2003 mustang mach 1
subbed to learn
Authorized Vendor
![]() Join Date: Feb 2011
what exactly did you want to know.
Here is a kit we sell that has been very successful. Scroll down to find the PC videos and Menzerna Polishes. Click here
Phil@DetailersDomain.com Detailer's Domain Like us on Facebook Discount code 10% off: MUSTANG |
RLY SRS
Mainly just wanting some all around info for myself and others...
The OPM for the buffers the guys use here The OPM that a product best works at Stuff like that...Like this weekend I am going to use Mez PO85RD...Whats the best OPM for that product? |
2010 GT
Flex 3401
Speed 1 160 rpm / 3200 opm Speed 2 200 rpm / 4000 opm Speed 3 270 rpm / 5400 opm Speed 4 330 rpm / 6600 opm Speed 5 400 rpm / 8000 opm Speed 6 480 rpm / 9600 opm flex does not play as well witht he MF pads as do the traditional DA's Griots 6" DA Lifetime warranty no questions asked 850w motor 7amp Speed Setting 1 - 2500 opm Speed Setting 2 - 3300 opm Speed Setting 3 - 4200 opm Speed Setting 4 - 5100 opm Speed Setting 5 - 6000 opm Speed Setting 6 - 6800 opm Megs DA 110v2 4.2amp 430watt Speed Setting 1 - 1800 opm Speed Setting 2 - 2800 opm Speed Setting 3 - 3800 opm Speed Setting 4 - 4800 opm Speed Setting 5 - 5800 opm Speed Setting 6 - 6800 opm
wiggety wiggety whack!
More specs:
Porter Cable 7424 review with specs (kind of old): http://www.roadfly.com/magazine/7/po..._buffer.1.html The Flex XC 3401 is 900 watts at 7.5 amps 8mm orbit Weight: 5.75 lbs Review with specs: http://paintcare-n-detailing.com/review/flex/ Also, the Meguiar's G110: Weight: 5.5lbs Decibels: 55
#TFM
I own the 7424XP, when it comes to standard correction - speed setting 5 at 5940 OPMS always seems to yield very good results for me. I will tell you, on vehicles with much tougher clear coats or with lots of marring, I will go ahead and up it up to speed setting 6 for a full 6800 OPMS, however this is not something I do frequently as it's not always needed and I worry about the stress on the machine. It's VERY well built, I just don't like to run it at it's full capacity if I don't have to. If you use proper technique with the 7424XP and account for the pads you are using, then Setting 5 is almost always enough to yield really great results when compounding or polishing.
![]() 2002 Mineral Gray Mustang GT Slow. Sexy. MM's Car Salesman Club MM's Resident Actor ΠΚΦ For life. ![]() |
Wax on, Wax off
For correction, almost all polishes need to be used at Speed 6 for the 7424XP. When doing a finishing polish/glaze you could bump down to 5, and for sealants 3 or 4.
Here is what I know off the top of my head:
This gives you a basic idea of what type of products are used at what speed on the 7424XP. After you know what these products work at, you can guesstimate where to start with similar products.
![]() Black Bullitt Rims FT/FS Looking to Sell or Trade for Silver FR500s Looking to buy a lot of 99-04 Interior Pieces If you have any for sale, PM me |
2003 Azure Blue Mach 1
5,000 miles on the ODO
For the PCXP speed 6 arm speed and pressure is what varies for any compound excluding the megs mg system. Speed 5.5 for medium polishes arm speed and pressure also varies on the polishes used. I don't apply glazes, carnaubas or sealants via machine you get better coverage by hand. I can post rotary rpm's if someone wants them. If you guys want specific
2003 Azure Blue Mach 1 MGW, MAC Offroad X, Flowmaster Original 40's, Maganaflow 3.5" Tips, Anthracite 18x9's & 18x10's FR 500's wrapped with Nitto 555's, Eibach Pro Kit, |
More show than Go
2003 mustang mach 1
dannyboy i wish you lived closer to me, you do badass detail work
#TFM
Maybe if I bumped it up to 6 instead of 5 my jobs wouldn't take as long. hahahaha. I like to go slower and make more passes at an even pace. Meh, next time I use my machine I'll probably take your advice and see if it cuts down my time.
Thanks man where do you live?
More show than Go
2003 mustang mach 1
close to the new braunfels/ san antonio area
Come down here for a weekend I will help you out man
More show than Go
2003 mustang mach 1
tempting ! i might have to next semester, this semester i work every weekend, but pretty soon i will have a lot more free time. |
Bump for a good thread, and also since autozone started carrying these: ($130 I think)
Threads Similar to: Buffer/Product Info (Speeds And The Like)
| Getting a Buffer for Christmas | carney | General Car Care & Detailing | 4 | November 23rd, 2010 07:24 PM |
| First time with a rotary buffer | zinc02GT | Pictures | 6 | January 17th, 2010 09:05 PM |
| Buying a Buffer need help | AMmuslGT | General Car Care & Detailing | 25 | July 19th, 2009 02:30 PM |
| Harbor Freight's Buffer? | sudbury33 | General Car Care & Detailing | 28 | July 3rd, 2009 05:10 PM |
| Anyone Good With A Buffer In The Area? | ChrisJ | Southeast | 2 | March 11th, 2008 07:34 PM |
