Quick Wetsanding Question For You Guys
Go Back   Forums at Modded Mustangs > Mustang Forums > General Car Care & Detailing
Old January 20th, 2012, 01:15 AM   #1
#TFM
NoColoradoGT's Avatar
NoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of lightNoColoradoGT is a glorious beacon of light
I was just asked to do a cut and polish job on a fairly new paint job the other day, however today I spent some time in my garage organizing all of my detailing products and noticed that my Makita Rotary is not working (It's a 9227C). I bought this sucker used on Craigslist (started using it on test panels to learn how to properly use a rotary, and got to try it on one customer car) and it was good for the couple times I've been able to use it, but it just flat out won't turn on right now. I don't know what's wrong with it.
In any case, I think I already know the answer to my question, but:
The only other polisher I own is my Porter Cable. That thing is probably way too weak to remove 2000/3000 grit wet sanding marks, am I right? Also I'd imagine with even the proper backing plate on the PC and a Wool Foam pad, that would just haze the paint with most compounds, yes?
Recommendations?
2002 Mineral Gray Mustang GT
Slow. Sexy.
MM's Car Salesman Club
MM's Resident Actor
ΠΚΦ
For life.
Old January 20th, 2012, 09:07 AM   #2
wiggety wiggety whack!
brokenweasel's Avatar
brokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of lightbrokenweasel is a glorious beacon of light
M105 is "rated" at taking out anything as deep as 1200 grit and most compounds I have used are "rated" at anything from 1500-2000. Depending on the paint you should be fine with the PC. It will take more time and a few more passes.
You have nothing to lose by giving it a shot, right?
Originally Posted by dr.gonzo? View Post
Monkeys wear spandex with hotdog legs because race car.
Originally Posted by IndianaJoe View Post
yesterday was shorter because of the massive burnout i did, it spun the earth faster.
Old January 20th, 2012, 09:55 AM   #3
#TFM
Except a customers trust....
Yeah, with the Makita I was working with a Wool Pad and M84.
You think even with the Foam Pad, M105, and 6,800 OPMS it should take it out?
I just have yet to attempt to remove wet sanding scratches with the PC yet (never really thought it would be powerful enough), and I don't want to order the wool pads and new backing plate for the PC unless you guys recommend I should.
Slow. Sexy.
MM's Resident Actor
ΠΚΦ
For life.
Old January 20th, 2012, 10:42 AM   #4
I'm saying the PC definitely won't make the car any worse, that's what I mean by nothing to lose.
I see what you're saying - if you get the car and you can't get the wetsanding marks out with the PC, then you'd have to have the customer come back to get them out with the correct tools. What kind of car is it? I guess that doesn't really matter since you said it is a recent paint job - how recent? I'm assuming you will seal/wax it afterwards if its not within a few weeks?
I'd think if the wetsanding is done correctly you can get it out with the PC, M105 or another aggressive compound, and a heavy cut foam pad. This would be an excellent chance to try out surbuf pads as well. I was under the impression that wool pads generally aren't recommended on DA's as well?
Old January 20th, 2012, 11:03 AM   #5
#TFM
Oh yeah, the PC is safe as can be. It's the training wheels bicycle of polishers but I love it! The work is on a 2005 Mustang GT. hahaha. The paint is exactly two weeks old, and has 2 coats of clear on it (not a ton to work with, but enough). The job is a ways away so that I can seal the paint afterwards without burning it.
I was just worried that even a strong foam cutting pad, may not have enough cutting power combined with the PC and a mid-abbrasive compound.
I may just pony up and buy some stuff on AG and then use it on my test panel at home in my garage.
Slow. Sexy.
MM's Resident Actor
ΠΚΦ
For life.
Old January 20th, 2012, 12:23 PM   #6
Wax on, Wax off
Zatrekaz's Avatar
2003 Mustang V6
16.8@83.3
Zatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud ofZatrekaz has much to be proud of
iTrader: 15 reviews
M105 + Yellow Pad will take out 3,000 for sure. I know this for a fact, I did it to my car on the driver fender.
Black Bullitt Rims FT/FS
Looking to Sell or Trade for Silver FR500s
Looking to buy a lot of 99-04 Interior Pieces
If you have any for sale, PM me
Old January 20th, 2012, 01:46 PM   #7
#TFM
Maybe I'll just do that. I can make a couple extra passes with 3,000 to ensure the orange peel is gone, and then I'll take that combo to it at 6,800, hit it with M205 to polish it out, and then glaze and seal it.
I'm freaking pissed that my Makita is broken though.
Slow. Sexy.
MM's Resident Actor
ΠΚΦ
For life.
Old January 20th, 2012, 03:16 PM   #8
Sucks about the Makita. I have a PC7424XP and I think it does good work. I'd be surprised if you couldn't get out 3000 wetsanding with it. Make sure you're using pressure with M105.
My roommate takes delivery of a 2012 mazda3 tomorrow and my mustang is getting a hood, fender and bumper this coming week, so I have some polishing coming my way as well.
Noco, what kind of temps are you working in these days? Its below freezing today and tomorrow here in Ohio. I'm not looking forward to attempting to wash and wax my girlfriends car tomorrow, and polishing isn't going to be much fun either next weekend.
Old January 21st, 2012, 12:06 AM   #9
dannyboy281's Avatar
2003 Azure Blue Mach 1
5,000 miles on the ODO
dannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to alldannyboy281 is a name known to all
Sorry to hear about your Makita 9227C,, but I can almost garantee that it is the carbon brushes I say buy a pair and replace them. You can get a pair on Ebay for like $10 or $15, if its not that it might be the electrical cord you can also find a replacement on ebay. Also you can easily get the sanding scratches out as long as you finish off with 2500 to 3000 grit I use Meguiars Unigrit papers since they are alo easier to remove defects and compound out scratches easiily. Use M105, Menzerna Powergloss, or Mother Professional Compound. Use them with Surbuf R pads they will give you the most cut on a D/A polisher and work amazing with M105. I have some for sale if you interested I have only use them once then I sold my PC, they have been wash and are stored in a clean detailing bag that I have my pads in.
MGW, MAC Offroad X, Flowmaster Original 40's, Maganaflow 3.5" Tips, Anthracite 18x9's & 18x10's FR 500's wrapped with Nitto 555's, Eibach Pro Kit,
Old January 21st, 2012, 02:03 AM   #10
\/ Hidden Bewbs \/
sikedsyko's Avatar
01 Cobra Vert
sikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to beholdsikedsyko is a splendid one to behold
Quick question for you guys who wetsand and use rotaries on customer cars. Do y'all carry any kind of liability insurance, or do you just bank on not making a mistake? I've been wanting to step into rotary and wetsanding, but honestly it scares me to do it on customer cars.
MM Cobra Club #66
Threads Similar to: Quick Wetsanding Question For You Guys
Quick question guys. silverbulletstang 99-04 3 October 16th, 2011 04:55 PM
Quick question for you guys fmxona500 General Tech 0 December 10th, 2010 07:27 PM
Just a quick question for you detail guys JerseyTrueBlue 99-04 29 June 2nd, 2010 07:42 PM
ok quick question guys natedawgishot 99-04 11 February 4th, 2008 05:22 PM
quick question guys. natedawgishot 99-04 15 January 14th, 2008 03:21 AM
