Repairing scratches
Go Back   Forums at Modded Mustangs > Mustang Forums > General Car Care & Detailing
Old November 8th, 2008, 01:51 PM   #1
Rebel Of The Sacred Heart
travis_afx's Avatar
'02 GT
travis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of lighttravis_afx is a glorious beacon of light
Repairing Rock Chips
I have used this method of repairing paint chips many times with great results. It will work alot better for solid colors, but sometimes you can get lucky and get metalic colors like silver to work for you also.
95% of the time you can't notice it unless your right on top of it. If you want to make sure the color will match better, you can go to you local paint jobber and have them use "the magic eye" on your car to eliminate the cahnce of having the paint not match. What i mean by magic eye is, it is a box that you hold on the paint on your car and it reads the actual color to account for fading, color variences, already repainted surfaces that do not match the factory color perfect, etc... I have painted many cars that when i went to mix the formula there will be nine or ten different color variences from the factory, so just because you have the same paint code as the car next to you, it doesn't mean that you have the exact same color from the factory. That is the main reason pre packaged touch up paint doesn't match exactly most times. I also use one of my old pinstriping brushes(0000) to apply the paint.
Get some single stage paint for your cars color. Then just clean the area real good, you can use wax and grease remover and a fibrglass prep pen if you want to get real picky about it. After you clean, apply the single stage to the chip putting just enough paint on there to have it slightly raised above the surfacce of the paint.
After the paint has fully cured take some 2000 grit wet or dry sand paper and wet sand the "bump" smooth with the surface of the paint. The easiest way to do this would be to find a small piece of wood or something to use as a tiny block. I take coffee stirrers and cut it into about a 1" piece. Then cut s small piece of paper to wrap around the block. Don't press to hard, just place enough pressure on the block to sand the bump down. Just don't get in a hury and pay attention and you can block it down with barely sanding the origanal paint surface, which in turn will make it easer to buff . (Always let your paper soak in the water for at least five minutes before use)
After you have sanded it down, the area will be small enough that you can buff it by hand(or with a buffer if you have access to one and can use it. I have a 3" air buffer i use) with a soft cloth and compound, it will take a couple times with the buffing but if the color is a good match then once you have buffed the shine back you will barely notice it
Travis Billings
May 6, 1982 - July 5, 2011
Rest In Peace brother, you will be missed.
Old November 10th, 2008, 01:56 AM   #2
travis_afx's Avatar
'02 GT
Repairing scratches
Here is a very good article on repairing scratches and chips that i found. I have done this on many things and it does work if you do it right.
Travis Billings
Old November 12th, 2008, 11:50 PM   #3
Lt_Crazy is on a distinguished road
Cool but seems long........
The difference between Fiction and Reality???
Fiction has to make sense.
-Tom Clancy
Old November 13th, 2008, 01:19 PM   #4
travis_afx's Avatar
'02 GT
it does take time, but look at it this way, hundreds of dollars to get a panel repainted or a few hours of work to get rid of the scracth.
Travis Billings
Old November 13th, 2008, 02:50 PM   #5
Resident DJ
Lefty's Avatar
'01 Cobra Vert.
iTrader: 12 reviews
^ the man has given a valid point
Threads Similar to: Repairing scratches
Rim Repairing????? help plzzzzzz StangGurl Visual 2 July 24th, 2008 11:55 PM
How much would repairing this cost? Dansby The Clubhouse 29 January 28th, 2008 06:01 PM
Repairing A Rim Question 1996gt 96-98 6 November 15th, 2007 10:44 AM
Rim Scratches crossfire876 99-04 3 February 8th, 2007 05:37 PM
