Resident DJ
'01 Cobra Vert.
Buff/Sand Your Clear Coat by Hand
This is courtesy of Travis_Afx
This is for getting rid of light scratches that cant be brought out by buffing alone. For those of you who are "hands-on" and don't like the DA Sander: First your gonna want to soak all your paper for at least 15 minutes before using it. Put a few drops of dawn liquid dishsoap in your water to help lubricate the water. I like to use a soft foam sanding pad so i dont get any finger grooves while sanding. Try to sand with the "direction" of the panel using oppsing angles. Start with some 1500, you will use this until the scratches are gone. Go slow with this step, because you sure dont want to sand to much clear off. I have a little rubber squege that i use to dry the panel off every so often, because it is easier to see the scrathes when the panel is dry and the water isnt "filling in" the scratch. After you get a sutible surface switch to the 2000 grit. The point of the 2000 is to get rid of the 1500 scratches. Its not for leveling out the paint really, that was supposed to be acomplished with the 1500. I like to always have my clear finished when i get done with the 1500, so after that i am just refining scratches. Okay after the 2000, go to 2500. Alot of people would say its not neccesary to use anything above 2000, but i know you want it to be the best it can be so use the 2500, I mean really whats an extra 10 or 15 bucks, its your baby. Then its ready for buffing
![]() ![]() 2008 Acura TL Type-S (the daily) 2006 Yamaha R6 50th Anniversary Edition (the other toy) Last edited by travis_afx; January 17th, 2009 at 07:02 PM. |
I'm Hella From Nor*Cal
2008 GTI
14.65 @ 99.83
Good info ima try this on the roof of my wife's xterra.
The Curse 600 CFM Edelbrock, Hookers, Pertronix billet dizzy, Accel coil, GT40 heads, 5.0 h.o, dynomax exhaust, SSBC, FRPP 9mm wires, tci |
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
I go beyond 2500 and step to 3000 grit. Yeah, I want that bitch to be perfect.
Отряд милиции особого назначения White Mustang Crew Co-Founder |
2008 GTI
14.65 @ 99.83
could someone explain what going in the direction of the panel means?
Threads Similar to: Buff/Sand Your Clear Coat by Hand
| clear coat? | ZoomZoomMFer | The Clubhouse | 38 | August 4th, 2008 04:41 PM |
| Powder coat? | whtpny | Visual | 0 | October 7th, 2007 12:49 AM |
| color sand, buff, and stripes | 69fastback | Pictures | 19 | April 4th, 2007 11:04 PM |
| Clear Coat on RIM peeling | 00SoSlow | Visual | 2 | November 30th, 2006 03:06 PM |
| Off To The Sand Box... | REBELPONY | 5.0 Mustangs | 18 | September 29th, 2006 08:39 PM |
