Suspension that sticks!
Ok next thing on my list is definetly my suspension. I have an 04 Mustang Gt. As far as race suspension would go, would a set of cut Foxbody 4 cyl springs do the trick? along with adjustable shocks and control arms of course, but my question is really on the springs,i can get some for 15 bucks, so should i jump on these? And what makes these so great?
thanx
11.47@120.58
I run fox 4cyl's up front and strange 10-way struts.
What makes them so great is that the springrate and height is close to what you would get out of a drag spring. It's handle about like stock but you'll get a lowered nice look and good weight transfer. |
#3 | |
11.47@120.58
I like my setup, looks sweet and handles as well as stock considering I don't have a swaybar (the adj struts are key to this). They won't transfer as well as those drag springs but its a good compromise I think.
Ok so then i should run cut 4cyls in the front, how much coil do you have cut off? and then for the back should i use 4cyls also? and how much were those adjustable shocks??
oh and forgot to add,are you still runningthe stock lsd and driveshaft, Joe?
11.47@120.58
You may not have to cut the fronts at all, depends on how low you want it. They'll lower a stock GT just by putting them on. I cut my fronts 1/4 coild and don't run any isolators. For the rear you'd use fox V8 rears. My shocks aren't adjustable, their Monro Sensi-tracs (el cheapo's from Advance Auto). The adj struts were $230 shipped from Jeg's.
I'm running 31 spline Moser's w/ a stock used 31 spline carrier out of a Ford Explorer. |
#7 | |
11.47@120.58
no just any old 50/50 shock, just a stock replacement type. Oh btw, my shocks/struts are fox body type.
#9 | |
11.47@120.58
26" tires, 26x10x10 to be exact on 15x7 V6 rims (yes the tire fits fine).
#11 | |
Threads Similar to: Suspension that sticks!
| best suspension set-up for a 2.3 | MSO | General Tech | 7 | July 6th, 2007 08:38 PM |
| suspension | 95 mustangmiz | V6 Mustangs | 6 | June 13th, 2007 02:34 PM |
| Suspension | dr.gonzo! | 5.0 Mustangs | 0 | January 24th, 2007 01:58 PM |
| suspension | 9stang1 | 5.0 Mustangs | 2 | January 3rd, 2007 10:20 PM |
