turbo feed line ran from oil press. unit???
Old January 5th, 2009, 07:41 PM   #1
bretts95gt's Avatar
95 mustang gt
bretts95gt will become famous soon enough
ok so i heard ur suppose to run the feed line from the oil pressure sending unit....so its probably this easy...im jus tryin to make it hard but...you take the sending unit off.
you put a T fitting on were the sending unit used to be.
you put the sending unit on the end of the T fitting
you attach the feed line to the side of the T fitting....so am i done??? with that anyway???
any help is greatly appreciated
95 gt vert-custom fenders 03 cobra front end,twin garret turbos,ported trickflow trackheat heads, hks blowoff valve,spyder efi intake, underdrives,built c4, 4000 stall converter,reverse manual valvebody,4.10 gears
Old January 6th, 2009, 04:10 AM   #2
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Arctic Fox will become famous soon enough
Sounds about right.
Old January 6th, 2009, 10:08 AM   #3
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
Yes, it really is that easy. Getting the oil back into the engine is sometimes a bit harder.
Old January 16th, 2009, 12:54 AM   #4
bretts95gt's Avatar
95 mustang gt
got it done today now i gotta tap the pan i heard ur suppose to tap it on the passenger side near the front of the engine about a 1/4 from the top???
Old January 17th, 2009, 09:27 AM   #5
Arctic Fox's Avatar
1989 GT
KB 2.1L Flowzilla
Old January 18th, 2009, 07:45 PM   #6
bretts95gt's Avatar
95 mustang gt
yeah thats it i knew it had somethin to do with the first bolt on that side its right behind abunch of wiring i gotta pull out the way
Old January 20th, 2009, 10:40 AM   #7
black5.0's Avatar
90 mustang notchback
black5.0 is on a distinguished road
is the motor out. When you get it all in you might want to put a different gears in like 3.73 or 3.55.
306 Turbo Notch D&G Tuned
1999 Chevy Silverado 5.3
Old January 20th, 2009, 02:52 PM   #8
bretts95gt's Avatar
95 mustang gt
the motors in an im prob gona run down the strip once with the 4.10s an see what it runs then im throwing some 3.73s. the cars not gona see the road much at all maybe to go down the block to my friends house but no long hauls what so ever
oh an heres the oil sending unit done an a pic of the motor
turbo feed line ran from oil press. unit???-oil-sender.jpg   turbo feed line ran from oil press. unit???-motor-almost-donejpg_1570910_510.jpg
Old January 20th, 2009, 03:33 PM   #9
black5.0's Avatar
Yeah i dont take my on long drives longest drive i did was like 35 miles or something. If you get a good tune it will drive just like dd car until you get in it.
Old January 20th, 2009, 03:36 PM   #10
bretts95gt's Avatar
95 mustang gt
awesome im prob tuning it with the anderson pms
Threads Similar to: turbo feed line ran from oil press. unit???
feed line, return line? 91cobra5.0 5.0 Mustangs 2 March 10th, 2008 12:45 AM
Oil Sending Unit? silver99gt 99-04 3 January 10th, 2008 12:44 AM
Turbo Oil Feed Lines v6modder V6 Mustangs 1 November 19th, 2007 09:36 AM
oil press. terribleonexx88 5.0 Mustangs 12 July 15th, 2007 10:04 PM
Installing Oil Sending Unit For 96 Mustang GT gtdan 96-98 4 September 6th, 2006 06:40 PM
