Check Engine Light
Old January 17th, 2006, 09:56 AM   #1
zhunter is on a distinguished road
Send a message via MSN to zhunter
Check Engine Light
im sure this is just a glitch in the electrical system, but i had the diagnostics ran on my '95 and they came back clean, yet the check engine light stays on, how can this be taken care of
Old January 17th, 2006, 10:01 AM   #2
lemon's Avatar
1999 GT Rag
lemon is on a distinguished road
gas cap ... sometimes it can make the light turn on
Old January 17th, 2006, 11:09 AM   #3
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
If your CEL is illuminated you are probably thowing some sort of code, I would take it back to have the code re-scanned, if there is no code they should be able to clear it.
Old January 17th, 2006, 04:04 PM   #4
if the light stays on, there should be a dtc. either in memory or as a hard-fault. disconnect the neg battery cable for a few minutes and then drive the car and see if the light comes back on.
88 Mustang Coupe
www.rickscarcare.net
Old January 19th, 2006, 02:10 PM   #5
87vert is on a distinguished road
Send a message via AIM to 87vert
'96 Exploder XLT 5.0 AWD
"turbos coming soon"
Old September 12th, 2006, 11:54 AM   #6
bayareastangs is on a distinguished road
Can someone help I have a 98 3.8 and the check engine light is on I cheked the codes and is giving me po171 system too lean bank 1 and po174 system too lean bank 2
I already replaced all 4 h02 sensors and did a tune up including new fuel filter but I still get the check engine light even after resetting it will light up after driving it for about 2 or 3 miles
Old September 12th, 2006, 12:03 PM   #7
vacuum leak or a bad maf sensor
88 Mustang Coupe
Old September 12th, 2006, 12:05 PM   #8
that was what I was afraid off cause maf sensor is expensive and I dont know how to check for a vacuum leak
Old September 15th, 2006, 02:09 AM   #9
ok I replaced the MAF sensor and the light stayed off for about 2 days but it all of a suden turned on again.
Old September 21st, 2006, 11:35 PM   #10
jealousy is on a distinguished road
90% of the time your light comes on its something to do with air polution control. ide suggest checking for vaccum leaks
Old October 20th, 2006, 03:32 AM   #11
Well its still giving me a code that reads system too lean bank 2 how do I fix this?
Threads Similar to: Check Engine Light
check engine light 02ATIstang 99-04 24 May 22nd, 2007 05:03 PM
Check Engine Light brose1388 2005 - 2010 4 April 28th, 2007 03:26 PM
95 3.8L check engine light nikbait V6 Mustangs 3 February 24th, 2007 02:57 PM
Check engine light ByPopularDemand V6 Mustangs 18 January 9th, 2007 01:50 PM
Check Engine Light? GreenFaleen V6 Mustangs 13 November 20th, 2006 02:26 AM
