BOV on a Supercharged engine?
Old January 18th, 2006, 09:40 PM   #1
97TunedMustang's Avatar
97TunedMustang is on a distinguished road
Send a message via AIM to 97TunedMustang
Ive already read practically everything on how BPV's function and what their purpose is and how BOV's also function. Now if you hang with me on this i want to know if this sounds feasible. There is an outlet on the Air intake for extra air to travel to the BPV when the throttle abruptly closes correct. same idea with a turbo setup. Now the line off the intake goes to the BPV. Say you removed the BPV and connected the bottom of a BOV to that instead. Now the other tube off the side of the bypass is going back into the supercharger as recirculated air. not enough pressure behind it anyway when its exhausted into the super to considerably speed it up or slow it down. It seems plausible you could seal off this connection with no adverse effects to the supercharger. its just extra air anyway. Now at this point you have an extra vaccum line originally off the top of the BPV which you really dont need at this point. again i dont believe it would adversely affect the supercharger. Now at this point you have a BOV attached to the output for excess air on the intake. if the BOV is set to release that air into the atmosphere at 7psi or higher as a stock BPV would back into the supercharger it should serve the same purpose. At this point youd have a supercharged engine with a Vrmmm PShhhh of a turbo'd setup. i just got to thinking so... does it sound reasonable ... or am i totally insane?
Even turbod engines can have CBV's to return the excess air to the turbine rather then vent it in a BOV setup so why cant the same thing work with a s/c? or can it..
Old January 18th, 2006, 11:00 PM   #2
mdvaldosta's Avatar
11.47@120.58
A BOV is simply a bypass valve that gets vented to the atmosphere. They do the same thing, only one vents to the atmosphere the other back to the intake tract. You can put a blowoff valve on a supercharged car so long as the mass air meter is setup for blow through, that way you don't vent off metered air.
Old January 19th, 2006, 02:02 PM   #3
87vert is on a distinguished road
Send a message via AIM to 87vert
if you want it to act like a turbo just get a turbo
'96 Exploder XLT 5.0 AWD
"turbos coming soon"
Old April 14th, 2006, 07:49 PM   #4
JunkyardTurbos is on a distinguished road
It looks like you are draw-through. You can't do a BOV. Like mdval said, a BOV vents into the atmosphere. You'll be blowing metered air out. You need a bypass valve that routes the metered air back into the intake. It still goes psssssshhhh though.
http://www.JunkyardTurbos.com
DIY and Junkyard Turbo Discussion
Old May 26th, 2006, 11:54 PM   #5
Grinster24 is on a distinguished road
From what I've heard most s/c don't make enough boost to have a BOV become efficient. But just passing info I have heard.
Old June 17th, 2006, 07:32 PM   #6
03blownmach1 is on a distinguished road
I thought 8lbs of boost from a S/C is same as 8lbs from a turbo?
Old June 17th, 2006, 07:40 PM   #7
mdvaldosta's Avatar
11.47@120.58
Doesn't work that way, the only difference between the two is where they vent too. Other than that their identical pieces.
You get the same amount of air flowing through both ways, but a S/C requires power from the crank to spin it (costing horsepower), whereas a turbo uses spent exhaust gas (which only causes a slight restriction) to power it.
Therefore, a turbocharger will produce more power than a supercharger at all boost levels.
Old June 18th, 2006, 04:04 AM   #8
ttop5.0's Avatar
ttop5.0 is on a distinguished road
this guy knows his stuff man i'm tellin you, my god....
Old July 25th, 2006, 07:45 PM   #9
BriansTib's Avatar
BriansTib is on a distinguished road
a BOV probably wouldnt work on a S/C. Turbos force in air, so when the TB closes, there is a build up of pressure and it opens the BOV and vents out. On a super charger (roots type), its sucking in air, plus the supercharger itself if behind the TB. So unless its a centrifugal supercharger, you wont see a build up of pressure before the TB when its closed.
You could do it on a centrifugal because the supercharger is before the TB and there would a pressure build up between shifts or when the TB closes.
Old July 25th, 2006, 07:47 PM   #10
RLY SRS
ChrisJ's Avatar
iTrader: 10 reviews
Go towards the bottom of the page...
Facebook
Google+
Threads Similar to: BOV on a Supercharged engine?
supercharged Black Five 0h 5.0 Mustangs 3 July 23rd, 2007 02:52 PM
Supercharged shadowgames81 General Tech 4 February 8th, 2007 07:36 PM
Supercharged? kerry V6 Mustangs 10 November 21st, 2006 11:57 PM
supercharged mustangdrvr2019 V6 Mustangs 1 September 12th, 2006 12:49 AM
tuning a supercharged car John C 96-98 1 September 9th, 2006 06:22 PM
