#21 |
prolly jus as long as i dont go to far over 400hp though. dont want a cracked block :wink
#22 |
1998 Mustang GT
Need to hit the track
well how do you lower the compression after a full PI swap on a 98 GT?
i've been wanting to know this forever but no one has ever answered it |
#23 |
Resident Bubblehead
after a PI swap with the stock pistons, you should be looking at about a 10.5:1 compression ratio, assuming your bore is still stock. going to a larger size piston dish will lower your compression ratio, as will having the heads worked to include a larger size combustion chamber.
#24 |
1998 Mustang GT
so a more cc, so to say, piston? like 18cc, 19cc, etc. get what i'm saying? and working the heads? porting?
#25 |
Resident Bubblehead
yeah, the non PI stangs had 11cc pistons with a 51cc combustion chamber that made for a 9.3:1 compression ratio. with the PI heads, you have a 42cc combustion chamber which, when combined with the 11cc dish pistons yield a compression ratio of 10.52:1, assuming a standard bore of 3.551 inches. if you went to a 17cc dish piston like stock on the PI stangs, you'd be looking at about a 9.7:1 compression ratio...
#26 |
1998 Mustang GT
ah marvelous. after 20 times of asking that question it's finally answered. and would that be a good CR for goin blown? also, if i decide that i wanna go nitrous, would any more compression blow my engine? cause i heard nitrous loves compression
#27 |
Resident Bubblehead
i talked to the guys at Sean Hyland Motorsport about 2 weeks ago. i told the guy my plans for the build included a centri blower going on the car, but not for about another year or so. i told him i was looking to make about 500rwhp. he recommended going 17cc on the pistons, which is actually the same size dish on the stock PI motor pistons. it really depends on th amount of boost you plan on running. as for the nitrous, i'm not really sure. i don't plan on messing around with spray on a daily driver...
i'll see what i can find out for you... |
#28 |
1998 Ford Mustang GT
well after calculation my car supposedly has 10:7.1 compression cause i install flattop pistons. i only get detonation when im really pulling hard. btu i have a paxton supercharger and this car really pulls hard. i was able to pull 427 ft. lbs. of torque at 3900 rpm and 6 p.s.i.
#29 |
Penetration before detonation
2001 Mustang GT
13.85 @ 100.5 w/3800 ft. DA
Real quick and easy way to lower your compression a few points is to install a thicker head gasket... not sure of all the options though.
#30 |
A few points? Uhh, NO. Besides, you dont run thicker head gaskets to drop your compression anyways, thats a no-no.
#31 |
anyone know what my compression ratio would be after i installed flattop pistons into my 1998 ford mustang gt with stock heads? i got mls head gaskets and xe268h-14 comp cams with springs.
#32 |
1998 Mustang GT
while everyone's on compression, what's a Mach 1's stock compression?
#33 | |
yeah i just bought c-16 for 7
Considering selling my car to fund my race car: take a look and tell me what you think. http://www.moddedmustangs.com/forums...ml#post1041280 |
#34 |
Threads Similar to: is 10.5:1 compression too high for a supercharger?
| High vs. Low Compression | 87StangLX | General Tech | 14 | November 17th, 2007 10:42 PM |
| A Question About Prochager With High Compression | blue03mach1 | 99-04 | 15 | November 9th, 2007 02:46 PM |
| Compression ratio w/supercharger | TheBusher | 99-04 | 19 | September 16th, 2007 02:10 PM |
| High Compression and FI | blk98gt | 96-98 | 6 | July 3rd, 2007 10:27 AM |
| compression too high for a supercharger? | 94' Cobra 351 | Drag | 3 | January 10th, 2007 11:05 PM |
