ride quality of springs
Old January 23rd, 2006, 11:47 PM   #1
artisan00 is on a distinguished road
ok, so im starting to think about lowering springs(not sure if i want them yet but trying to do some homework first i guess)
right now i have the stock springs, with heavyduty bilstein shocks and struts.
i also have an STB and SFCs.
and its a vert.
soif you havent figured out by now, its ok on smooth roads but on bumps? whoa man forget about it.
anyway, are there any lowering springs (moderate ones, not slammed) that can actually improve my ride q.?
or is lower pretty much always going to come with some added harshness.
after some looking around i was interested in the eibach prokits or maybe the H&Rs.
but just looking for opinions here
Old January 24th, 2006, 06:45 AM   #2
1Clean6 is on a distinguished road
Anytime you lower the ride height, you're going to sacrafice quality. I have H&R Supersports and Tokico shocks and struts, and I'm not going to lie to you, its not a smooth ride at all. But the car stucks to the road like it was glued to it.
I might suggest a set of MM Full Length Subframe connectors first, especially since youre a vert.
Old January 24th, 2006, 08:07 AM   #3
99mustang232's Avatar
1999 Ford Mustang V6
99mustang232 is on a distinguished road
you got a lot of options out there;
here is what i used: Tokico Advanced Handling Package
#HPK237
-Tokico HP Struts
-Tokico HP Shocks
-Tokico 1.5" sport lowering springs
I used mine as a daily driver and it is not that bad, maybe on the highway speedbumps we have around here, but no scrapage on real speed bumps. Just keep in mind that any lowering over 1.4" is gonna require the use of caster/camber plates to obtain a proper alignment. I recommend getting the MM 4-bolt cc plates regardless of drop anytime you are gonna remove the struts anyways, just for the adjustablity you wouldn't believe what a little lowering and cc adjustments will do for you on the corners, add a rear swaybar to the mix and you can banging out some corners or autoX. Also be aware that there are differant spring ratings and some are matched for differant struts/shocks so not picking the right mix of parts is also key in the ride comfort.
this is what i have my c/c and toe set at:
Toe In: 1/16"
Camber: -1°
Caster: +2.6°
Old January 24th, 2006, 11:01 AM   #4
i already have subframes - thats what i meant when i said "SFCs".
i figured id lose quality, but i was hopoing that the stock springs were so bad that maybe itd improve anyhow..
#HPK237
-Tokico HP Struts
-Tokico HP Shocks
Toe In: 1/16"
Camber: -1°
Caster: +2.6°
i already have the bilsteins, i dont plan on going with a whole new set of shocks and struts, i just want springs
Old January 24th, 2006, 11:28 AM   #5
then read this; http://www.miracerros.com/mustang/springs.htm
Old January 24th, 2006, 11:46 AM   #6
ill check it out
edit * that explains what he did to get his car at 1" but doesnt really go into any review of what any specific spring feels like..
Old January 24th, 2006, 12:38 PM   #7
look for a set of progressive rate springs. That will be smoother than a set of fixed rate springs.
88 Mustang Coupe
www.rickscarcare.net
Old January 24th, 2006, 01:35 PM   #8
thats part of the reason i was looking at the eibachs. any experience withthem?
Old January 24th, 2006, 02:04 PM   #9
this is a link from that page, which is to a chart of various oem and aftermarket spring rates and how to calculate them.
Old January 24th, 2006, 02:25 PM   #10
i must have missed that, thanks taht is a good reference
Old January 24th, 2006, 02:32 PM   #11
#HPK237
-Tokico HP Struts
-Tokico HP Shocks
Toe In: 1/16"
Camber: -1°
Caster: +2.6°
I guess thats what I get for posting when I just woke up
Also; [Shameless Plug]H&R Supersports > Eibach [/Shamless Plug]
On some other websites, youll see they have somewhat of a cult following, similar to Zaino
Old January 24th, 2006, 03:33 PM   #12
why do you say the HR are better than the eibach?
looking at that link posted before, the HR super sports are rated at 700-760 275-300, front and rear respectively.
the eibachs are at 425-530 200-300, respectively.
i dont know if i would enjoy going as stiff as 700. the way my car is now, i feel like going to 700 would make it really painful to drive
btw if i decide i do want to get springs, and it looks like if i do ill be going down an inch or so, (based on the fact that i dont want to go much lower than that anyhow), will i need to get CC plates (or any other fancy suspension gizmos) or will a normal alignment be ok
Old January 24th, 2006, 04:38 PM   #13
AtlanticBlue99's Avatar
14.79 @ 92.15
your alignment will be not far off (less than half a degree) catser or camber with a drop of 1". i have ford racing C springs which drop 1.2" and i got an alignment and it is nearly perfect factory alignment specs. but with any drop, you will need c/c plates to align perfectly, but it isnt necessary until 1.5" drop or more
ModdedAutos
1999 Mustang V6
Old January 24th, 2006, 04:47 PM   #14
ok then, in that case i wont worry about it. the eibachs for example, advertise a 1.5" but im assuming it wouldnt even be that much since so many people say their cars dont lower by the amount the companies say they do...
my other uestion is, how hard is it to do springs on ones own without any fancy tools?
Old January 24th, 2006, 04:55 PM   #15
14.79 @ 92.15
a few hours. an hour per side if you've never done anyhting like it before. i just dropped my car off at a muffler/brake/suspension shop and put down 200 bucks and went out for lunch. i could have done it with help of a friend, but it was during a busy work/school schedule for me.
ModdedAutos
1999 Mustang V6
Old January 24th, 2006, 05:14 PM   #16
i figured that, but im getting to the point where all the money the car has eaten is noticeable, and im starting to think like this: if 200 bucks is what it costs to have X installed, then i could do it myself and buy a new Y"
so for example, installing springs could "pay" for new headers (or something like that )
and plus for something so simple, why not?
Old January 24th, 2006, 06:20 PM   #17
14.79 @ 92.15
exactly
ModdedAutos
1999 Mustang V6
Old January 24th, 2006, 10:05 PM   #18
Suspension installs are very straightforward and a good place to start working on your own car. Thats what I did, just plan a solid day, grab as many different sets of instructions as you can, and make sure you have all the tools they'll say youll need.
Old January 24th, 2006, 10:12 PM   #19
ive seen random how tos all over the place, but id rather get a write up from someone i know knows what they are doing..
Old January 24th, 2006, 11:14 PM   #20
Look for one by a man called Spreadman, he has a yellow 99-04 GT, youll see lots of pics and really quality instructions from him. Theyre the ones I used for my install.
Threads Similar to: ride quality of springs
Quality 5.0 Casper98GT 5.0 Mustangs 24 October 12th, 2007 10:41 PM
Ride height Ford Racing springs M5300 C Baby96 General Tech 1 August 23rd, 2007 09:52 PM
Roush quality? Wiley V6 Mustangs 7 April 1st, 2007 01:51 PM
pics of my ride.... quality isnt 100% tho 02ponypackage Pictures 17 March 16th, 2007 10:40 PM
Anyone have bad ride quality with Nitto 555 MustangMatt 2005 - 2010 3 December 17th, 2006 06:28 AM
