supercharger questions
Old February 18th, 2009, 05:35 PM   #1
bob1june@yahoo.com's Avatar
bob1june@yahoo.com is on a distinguished road
can some one please answer some supercharger questions for me?
Old February 18th, 2009, 05:40 PM   #2
Whatever it originally would be
Seabee's Avatar
05 Saleen #824
Fast as fuck
Seabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to beholdSeabee is a splendid one to behold
Send a message via AIM to Seabee
search threads for certain questions that have probobly been answered already, and second, what are they?
MILITARY CREW
ANTI ILLEGALS CREW FOUNDER
Old February 18th, 2009, 05:42 PM   #3
i am trying to find out if a all superchargers are suppose to have a blow off valve? and are they suppose to have a gasket between the compresser housing and the charger?
Old February 18th, 2009, 05:44 PM   #4
Seabee's Avatar
05 Saleen #824
Fast as fuck
Centri's can, some do, some dont. Some have bypass valves. Are you talking about those or a root style, like a kenne bell?
MILITARY CREW
Old February 18th, 2009, 05:53 PM   #5
it is a centri, i have instructions but it does not say anything about a pressure relief valve. my car is stock right now , and this charger has a 9# pulley
Old February 18th, 2009, 05:59 PM   #6
Seabee's Avatar
05 Saleen #824
Fast as fuck
which centri? I have a bypass valve that was going to go on mine, you can just have it release into the atmosphere. Not sure if theres much else, but you CAN have a bov, but i dont think you specifically need one, could be wrong. Someone else can chime in, but your stock, with a 9lb pulley? no other mods?
MILITARY CREW
Old February 18th, 2009, 06:04 PM   #7
yes i am stock now , but i have not yet installed the charger, but it is a powerdyne, i do not know if stock is suficent to run a 9# pulley or not, i bought this kit used but all of the parts seem to be here.
Old February 18th, 2009, 06:47 PM   #8
bottlefed02gt is on a distinguished road
You have to have a bov or bypass valve (essentially the same thing, a bypass can be run just like a bov). If you don't, as soon as you let off the gas and the throttle body closes, you are going to get a lot of compressor surge.
If you are running a draw-thru (maf before the supercharger), you will have to recirculate the air back in after the maf. This is usually done with a bypass valve. You have to recirculate with a draw-thru setup since the air is metered and the bypass valve is after the maf.
If you are running blow thru (maf after the supercharger), then you can vent to the atmosphere or bypass it back in. You can do this as long as your bov/bypass valve is placed before the maf air sensor.
Old February 18th, 2009, 07:10 PM   #9
Trick Tuners's Avatar
KB'd GT
that man speaks the truth! (but if you run blow thru, always vent)
Old February 18th, 2009, 07:15 PM   #10
what do i do drill and tap my power pipe?
Old February 18th, 2009, 07:23 PM   #11
is there suppose to be a gasket between the compresser housing and the charger
Threads Similar to: supercharger questions
Supercharger Questions mp4 player V6 Mustangs 2 July 3rd, 2008 02:56 AM
Supercharger Questions motorhead6776 General Tech 7 December 1st, 2007 02:48 PM
Supercharger Questions!! StangFreak4 General Tech 6 May 29th, 2007 10:15 PM
New supercharger Questions mb03stang 99-04 17 February 4th, 2007 03:54 AM
Supercharger Boost Questions 2much4u 99-04 12 November 27th, 2006 04:35 PM
