![]() iTrader: 1 reviews
Do i need a new tune?
The first time i got my car dyno tuned was when i installed the supercharger. Everything else was stock. I have now a O/R X pipe and a roush side exhaust and a MAFIA. I also went from a 3.6 pulley to a 3.33. Adding a 75mm throttle body and plenum. Do i need a whole new tune or do i just need the existing one adjusted or just a wide band? I just dont want to get screw as far as price goes.
thanks
Well a wideband is always recommended, because you never know what kind of effect the weather and other things will have on the tune. I would think your tuner would be able to just tweak the current tune, which shouldn't be too much. I would definitely stay out of boost until you get a wideband and/or retune since you have added quite a bit of stuff since your first tune.
~C~, The Other White Meat!
Whoa dude. You did all that with out a new tune? How's she running?
Yes you need a tune. If you are running a chip then you need it retuned but if you have a tuner, go to the place you had it done and have them update it. You need the tune updated with the pulley, and everything else......
BLOWN Bumblebeast! 370 rwhp / 381 ft lbs ![]() ~Tuned by JJ at WMS ![]() "Like the blind man says......We shall see...."
#4 | |
KB'd GT
The mafia should be the only part that needs a tune. If there was sufficient range during the dyno tuning, you may be able to add more boost without retuning, but you need a wideband for sure to know. DO NOT add the mafia without retuning or it will jack everything up! I set up my tunes so that if the customer does add more boost than it was tuned for, it will be on the rich side instead of the lean side. But then there is the danger of a pegged maf if they were already close to the limit.
good to know, thanks guys
Threads Similar to: Do i need a new tune?
| Tq tune outperforms race tune at the 1/8 mile track. | gragra73 | 2005 - 2010 | 5 | July 28th, 2008 04:16 PM |
| Dyno tune vs Sniper email tune | itschristorres8 | The Clubhouse | 72 | May 22nd, 2008 04:27 AM |
| dyno tune or downloaded custom tune | silvergtstang99 | 99-04 | 2 | January 31st, 2008 10:49 AM |
| 07 Mustang K&N intake tune or no tune | Mustangsally91 | V6 Mustangs | 10 | January 23rd, 2008 03:11 PM |
| dyno tune & flash tune | miafan | 2005 - 2010 | 4 | May 31st, 2007 04:05 AM |
