Discussing bad idle and no low range power in the General Tech Forum. Sounds like either a few loose pan bolts or a tailshaft seal. Either one will ...
Old January 31st, 2006, 12:09 AM   #21
Sounds like either a few loose pan bolts or a tailshaft seal. Either one will be an easy fix.
Old January 31st, 2006, 07:53 AM   #22
The Nice Guy
AtlanticBlue99's Avatar
1999 Ford Mustang V6
14.79 @ 92.15
ill take a look at it this afternoon and get back to you.
ModdedAutos
1999 Mustang V6
Old January 31st, 2006, 08:46 AM   #23
99mustang232's Avatar
our engines have a notrious pcv oiling issue, often cleaning the TB and IAC is required and at your milage im sure you have a nice build up of sludge in your upper intake. check out your pcv valve too. you might want to pull the rear two plugs to see if you have any deposit buildup maybe even replace because those will show it first.
could be the rear main seal leaking?
Old January 31st, 2006, 06:17 PM   #24
The Nice Guy
14.79 @ 92.15
i got the idle close to not surging as much. i guess i could clean it again and it would be perfect. the no low range power problem still exists and i think it is related to my transmission. i probably leaked that 1.5 qts of tranny fluid in 3 days or so. my transmission from the oil pan back is covered in sludge and tranny fluid. here is a pic with the bottom being toward the front of the car:
i wiped the tranny down to take a picture of this dent i found. would a dent like this cause this sort of problem? would a leaking transmission (auto by the way) cause this loss of low range power? how would you fix something like this?
ModdedAutos
1999 Mustang V6
Old January 31st, 2006, 06:38 PM   #25
vivoronte's Avatar
Sounds to me like you might have some clogged injectors. That would keep you from having the abuilty to take off froma stop. Try useing some injector cleaner in your gas and if that doesn't work and you rule out all other posibuilties, sometimes the injectors get so clogged the only way to unclog is to take them out and clean them by hand.
Old January 31st, 2006, 07:29 PM   #26
...even fire and single cammin
Old January 31st, 2006, 08:36 PM   #27
vfast's Avatar
yes..........when was the last transmission fluid changed?..I believe the gasket is one of those reuseibles.....I hope the trans never got a qt low before you checked it.....as for the intake build up seafoam will do the tricks
Old January 31st, 2006, 08:37 PM   #28
The Nice Guy
14.79 @ 92.15
that is actually normal?! hmm. well i ran a bottle of stp fuel injector cleaner in half a tank of gas and it is driving the same horrible way again. i checked the air filter, spark plugs/wires, fuel filter.
i get horrible gas milage as well. do you think long tube headers on a tune for all my other mods excpet the long tubes would cause this air/fuel issue? it does seem like an air/fuel issue though right? i will call my uncle and have his mechanic friends look at it soon.
ModdedAutos
1999 Mustang V6
Old January 31st, 2006, 08:38 PM   #29
The Nice Guy
14.79 @ 92.15
i havent checked the tranny fluid in 10k miles. it was 1.5 qts low yesterday...
ModdedAutos
1999 Mustang V6
Old January 31st, 2006, 08:42 PM   #30
vfast's Avatar
not good I would change it and the filter..see if the convertor has a drain plug...you need to invest in a transcooler ASAP.
when is the last time or ever changed the PVC valve?..maf? throttle body?
bg products make the best IMO fuel injection clean about 14.00 a can
Old January 31st, 2006, 08:57 PM   #31
The Nice Guy
14.79 @ 92.15
i didnt clean the the mass airflow sensor , but i did clean the throttle body and iac valve. the pcv valce looks okay, i changed about all the small stuff, so i will set up an appt. with my uncle's mechanic friend to have him check it out.
ModdedAutos
1999 Mustang V6
Old January 31st, 2006, 09:39 PM   #32
vivoronte's Avatar
Before the actual problem started, did you get on the gas alot? A really bad clogged Cat converter can cause poor gas mileage. Due to redlineing the rpms' alot. And it can also kill an injector. My bros v6 explorer used to roll up to stop signs then when you take off it would stall or hesitate. I had to take the injectors out and clean them throughly and put new caps on them.
Lucas Fuel injector cleaner is prolly the best i recommend......if you wanna give it a try again. Make sure you have a full tank of gas with a full bottle of Lucas. If all else fails go to your local autozone and see if somethin shows up on their computer when they hook it up to your car(they'll do it for free).
Old January 31st, 2006, 09:48 PM   #33
Air Embolism Assassin
Cricket's Avatar
8.876@80.013 1/8th
I coulda tried to help since my grandpa designed that transmission, but when he died my grandma didn't think anyone would want the schematics and threw them out. They were having a lot of problems with them over in china about a year ago.
Have we officially crossed the line now? I just got Douche chills. Thanks a lot JP.
I gave zippee douche chills
Blue Mustang Society
Modded Mustangs Breast Cancer Awareness Bike Thread
Old January 31st, 2006, 10:01 PM   #34
vivoronte's Avatar
hey man whats your Grand dads last name? just wonderin
Old January 31st, 2006, 10:02 PM   #35
Cricket's Avatar
8.876@80.013 1/8th
Dohm
Old January 31st, 2006, 11:10 PM   #36
The Nice Guy
14.79 @ 92.15
i have off road exhaust- long tube headers and magnaflow mufflers all in stainless steel 2.5" mandrel bent tubing. so the catalytic converter thing (or any exhaust restriction) is ruled out. also, i checked the cel codes with my xcal 2 and only got one code for hot air intake temperature- which led me to believe the air filter might be clogged or something. i cleared the code and it never came back. anyways my uncle is coming tomorrow to take a look at it, hopefully it is nothing serious
ModdedAutos
1999 Mustang V6
Old February 1st, 2006, 07:14 AM   #37
few things that i think of are MAF, PVC valve, O2's, vac leak.... if the PVC valve is stuck closed and you pressurize the crankcase you can pop out your rear main seal, but with that many miles and some harder driving seems about normal seepage. also with that many miles your 4r70w it is well due trans filter replacement.
Old February 1st, 2006, 08:08 AM   #38
The Nice Guy
14.79 @ 92.15
i do need to get the transmission serviced. hopefully today we can diagnnose the exact problem(s) and i will get back to yall on what it turns up being. thanks for all the help thus far guys.
ModdedAutos
1999 Mustang V6
Old February 1st, 2006, 11:35 AM   #39
1998 Mustang 3.8L
It could be the torque converter baecause that would explain why it is slow off the start but then is of in higher rpms. Id look into it man, after that many miles some things just fail not totaly due to aggressive driving just lots of miles and lots of motion just takes a toll.
Old February 1st, 2006, 04:09 PM   #40
a lot of transmission problems are related to fluid levels, should always be one of the first things you check
Threads Similar to: bad idle and no low range power
loss of power//ruff idle and engine shut down.// no start dj hexadron 99-04 1 July 25th, 2007 01:41 AM
Question About 40's + this price range pHANTUz Exhaust 1 May 25th, 2007 07:13 PM
No Mid-Range In Second 5.0_H.O 5.0 Mustangs 0 October 12th, 2006 02:45 PM
Idle Problems Code 1506, Idle Overspeed Error jagstang96 96-98 3 August 29th, 2006 05:11 AM
tps out of range ? 5litercobra 5.0 Mustangs 15 April 11th, 2006 04:37 PM
