Danger in up shifting without the clutch?
I've got a '97 Mustang GT.. I've been told I can up shift without the clutch.
I tried it a little bit today on the freeway and after some red lights and I got it to work smoothly most of the time, I grinded a little a couple times but nothing huge. As long as you do it right, does it cause any damage? And what about down shifting? |
Moderator
2003 Grand Cherokee
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: 0 reviews
It can be done either way. You just have to match the engine revs to the gear speed. If you're off by a little bit then you're going to grind. If done properly, then it doesn't cause any damage and is actually better for the tranny b/c you don't need the syncros. If done incorrectly, it's terrible.
Why run the risk of causing damage when you have a perfectly good clutch?
03 gt, 95 740i, 96 disco
![]() ![]() iTrader: 2 reviews
your better off using the clutch. in a car whats the big deal? as part of my job i have to drive a 24' truck, and its manual transmission is designed to be shifted without the clutch, so you use it in that its harder to shift, but in a car, whats the point? its so easy anyways and you dont risk damaging the gears...the risks out weigh the possible benefits.
KB'd GT
No grind = no problem. You can do it up or down, but if you do it a lot, chances are you will end up grinding the gears and hurting the syncros. just use the clutch. I'll do it sometimes if i have my hands full and i'm driving with my knee and need to shift without taking my knee off the wheel.
Threads Similar to: Danger in up shifting without the clutch?
| shifting without a clutch | ford6693 | 99-04 | 61 | November 8th, 2010 11:58 AM |
| Shifting Without Using Clutch | White 89 | 5.0 Mustangs | 129 | February 17th, 2008 10:58 AM |
| The Danger Ranger | bacon | Videos | 5 | December 15th, 2007 01:56 PM |
| My Danger Ranger Vid | bacon | Multimedia | 13 | October 11th, 2005 06:15 PM |
