Water/Coolant shooting through tail pipes.
Old February 1st, 2006, 11:26 AM   #1
fallstar01 is on a distinguished road
This is unreal. My entire intercooler system's coolant has exited through my tail pipes. I'm assuming that there is a crack in the heat exchanger which is inside the intake manifold and the car is passing all of that fluid through. The car seems to be working fine but I've heard that water/coolant tends to bend valve and cause other bad issues. I've pulled the fuse on the intercooler until I fix it but I'd like to know if there are any measures I should take to make sure nothing gets messed up. The car passed quite a bit of coolant/water through it. The radiator water levels are fine so it doesn't seem to be coming from anywhere else.
Old February 2nd, 2006, 10:30 AM   #2
JRuckas is on a distinguished road
damn, sounds pretty nasty.. i would only suggest to not run it and start tearing her down to find the problem. i'd have that shit apart real quick like.
Old February 2nd, 2006, 10:50 AM   #3
87vert is on a distinguished road
Send a message via AIM to 87vert
Re: Water/Coolant shooting through tail pipes.
the bearings would be my main concern. Like stated, pull it apart and fix it before you drive it any more.
'96 Exploder XLT 5.0 AWD
"turbos coming soon"
Old February 4th, 2006, 06:30 PM   #4
IcantDo55 is on a distinguished road
If it got in through the intake it would not have got to any bearings.
-Mike
Link to My Site
Want to Play Some Pool???
Stroked and Blown!
Old February 4th, 2006, 06:35 PM   #5
vivoronte's Avatar
vivoronte is on a distinguished road
Sounds like you have a blown intake gasket. Take a can of carberator cleaner and let your car idle spray around the intake. If it revs higher you have a bad intake gasket. If nothing happens then your best bet is to take it apart and figure out whats goin wrong.
Threads Similar to: Water/Coolant shooting through tail pipes.
94-98 tail pipes droppedbass87 General Tech 1 May 24th, 2007 02:46 PM
large amounts of water out of pipes JASonic V6 Mustangs 12 May 18th, 2007 01:42 PM
VT Shooting Cricket The Clubhouse 58 April 17th, 2007 12:19 PM
Shooting Cars Race2theFinish The Clubhouse 1 October 11th, 2006 05:55 PM
