´07 Roush Stage 1
turbo bypass from exhaust
Ok here´s the deal.
I have the Livernois 298 stroker block, Hellion 62mm turbo kit plus Brenspeed turbo tune. Now after installing the rebuilt motor, new oil pump and rebuilding the turbo (with the Turbonetics rebuild pack) I´m still getting heavy oil smoke from the exhaust after runs at WOT when I let off the throttle. It does not smoke unless I pull hard and let the turbo spin. What me and my mechanic want to do is try to bypass the turbo system by removing the exhaust from the headers so the turbo wont get any air or oil. Then take a short run at WOT and see if it still smokes. The reason we want to try this is so we can be absolutely sure the turbo is causing the smoke but not things like valve seals or cylinder rings, and I don´t want to start shredding the motor to pieces unless I knowit´s motor related. Would this be dangerous for the motor with the exhaust bypassed on my current tune? Are there any things I should take in to consideration ?
Ford Mustang Roush Stage 1 w/Livernois forged 298 stroker short block (compression 9.1:1) , Hellion Turbo System (62mm Turbonetics @9psi) + more & more to come |
i would think u would be ok unless you put down some power... thats what im thinkin
Отряд милиции особого назначения White Mustang Crew Co-Founder |
your mechanic didnt say anything??
´07 Roush Stage 1
Nahh we have been scratching our heads trying to figure it out what causes the smoke..
turbo oil drain, pcv valve, valve seals, cylinder rings....endless possibilities
Have you guys pulled the sparkplugs out after a WOT run to see what they look like? That would be the 1st thing I would check.
talked to my friend and he asks if its external or internal wastegate.
´07 Roush Stage 1
It´s the Turbonetics Evolution wastegate (external)
bump
thats pretty sick ive never seen it done let me know how it works out i want to boost
thanks
Threads Similar to: turbo bypass from exhaust
| turbo help with exhaust | 95StangSVT | General Tech | 1 | March 20th, 2008 12:54 AM |
| Planning On Turbo. Exhaust Help | tehdwarvenn | 5.0 Mustangs | 13 | December 2nd, 2007 08:00 PM |
| Axleback exhaust and turbo? | energiesource | 99-04 | 8 | August 4th, 2007 11:44 PM |
| turbo exhaust | WLJohnson05 | V6 Mustangs | 15 | June 26th, 2007 02:52 PM |
| Turbo-Exhaust Question | Brianzeke007 | V6 Mustangs | 7 | November 20th, 2006 12:20 AM |
