LinkBack (1) | Thread Tools |
#1
How to Seafoam Your Mustang
So you have decided to Seafoam your 99-04 V8 mustang to clean out all the carbon in the motor, but your not sure what to do? Don't worry about, I got your back.
The first thing you are going to do is drive to your local auto store and pick up a can of Seafoam. Next you would you car to run for about 5-10mins to get it up to temp, (if you just got back from the auto store you should be all set, but check the temp to be sure). You want the car to be at temp so that when the Seafoam goes in it will better break up any carbon that's in the motor. Pop the hood and find the Vacuum line. ![]() Now that you know where the vacuum line is, you should pop it off and turn the elbow up. ![]() Find or make a funnel that will fit into the vacuum elbow. ![]() Now you are ready to add the Seafoam to your car! ![]() *IMPORTANT* If you plan to do this on your own, listen up. Before you unplug the vacuum line you will want the car to be running. Be ready to use your thumb to cover the vacuum line to keep the motor running. Have the funnel and Seafoam ready to go. (If you got a friend handy, have them sit in the car to start it up. This way you can have the vacuum line off and plugged for the start up.) Have the Seafoam can opened and the funnel ready. You are going to use your thumb inside the funnel to control the flow of Seafoam. ![]() *DO NOT USE GLOVES* If you use a glove you run the risk of the rubber/dirt coming off your thumb and getting sucked into the motor. That = BAD. With the motor running, the funnel and Seafoam ready, start to pour 1/3 of the can into the vacuum line SLOWLY and without having the motor stall. ![]() After you pour in 1/3 of the can into the motor, shut the car off and hook the vacuum line back up. Let the car sit for about 10mins and then for the fun part. *You might want to video tape this* Start the car and let it run for a while in a well ventilated area (AKA outside). Give it some gas. The more smoke you have coming out of the tail, the more carbon you had in the motor. Hope this helps you out with Seafoaming the motor of your car. Please note that this is just for how to add Seafoam to the vacuum line only. Seafoam can also be added to the gas and oil of your car, but that's the easy thing to do. Last edited by BlackedOut04GT; March 19th, 2009 at 01:19 AM. |
Forgot to say this. Pics are for a 2004 Mustang GT, but you get the idea.
Does this stuff actually work? Is the smoke coming from the carbon, or is it the seafoam that's smoking?
I'm considering it, and i guess it probably wont hurt anything.
![]() Cammed 2v Built By MustangMatt More mods than times your daughter has slept around |
Baby Punchin' Champ
2008 Mustang GT
I have a toy Pony. He takes Big shits
its probably the sea foam. ive never heard of this before lol
![]() Mods In garage |
It's a bit of both. The Seafoam it self will make smoke come out the tail pipe, but there is also carbon in the smoke as well. If you watch the video I put up you will see white smoke first (mostly the Seafoam) and then it gets a little darker (thats the carbon). It does do a good job of cleaning out carbon from the motor.
Thanks for the info! Did it today and it is idling smoother
"If everything seems under control, you`re just not going fast enough." -Mario Andretti |
ditto....smoothed out my idle....now i amdoing it in all my vehicles....bought a gallon of the stuff
Black and White Crew ![]() Crew Member # 3 centerforce dual friction,.100 shot freeflow exhaust,70mm accufab tb,professional products plenum, tri ax,3.90s amazing how fast you can go when the road never curves .....lighting up the Canadian prairie |
at work when we seafoam a car we just pull a vac line and stick it into the can of seafoam. it sucks it up into the car and you just pull it out every once in a while and see how much you've used. much easier than pooring it into the vac lines.
![]() '00 GT, hp 292's, full bolt ons, built/stalled auto, 4.10's, 150 shot-new times to come. '95 GT, 347, tko, etc-11.8@116-sold. ![]() WTT-my mildly built 4r70 for t56/tko. |
#9 | |
I'm doing it wrong
04 Grand Cherokee
How do you just leave the vac line in the can of seafoam? Doesn't the car stall?
Formerly known as Demon_54 "I feel the same way about disco as I do about herpes." - Hunter S. Thompson
i used a funnel and quick hands to keep the car from stalling. It's best to get a friend (that knows cars or can do what you say) to help you. i would put my thumb over the vac to keep it from stalling out. It was tough to do, but i got it done.
![]() Black Stang Crew #007 Car Built By Me and CraigsList.com Mods: MGW, Bassani Catted X, Flowmaster's, Accufab 70MM TB, Stack Racing Plenum + spacer, JLT CAI, Diablo Tune, Slotted rotors + ceramic pads. More to come! I hope.
I'm doing it wrong
04 Grand Cherokee
Thats what I do whenever I seafoam, I put the seafoam in a cup and put the vac line in for a second pull it out and put my thumb over it.
Btw Blacked out, I am getting LT's mad soon
#12 | |
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/115474-how-seafoam-your-mustang.html
| Thread How to Seafoam Your Mustang | Forums at Modded Mustangs | BoardReader | This thread | Refback | July 9th, 2011 08:27 AM | |
Threads Similar to: How to Seafoam Your Mustang
| Seafoam? | 6stang | V6 Mustangs | 10 | October 27th, 2008 12:29 AM |
| seafoam | burin_rubber | V6 Mustangs | 11 | April 3rd, 2008 10:12 PM |
| Seafoam | blazor | V6 Mustangs | 7 | January 11th, 2008 03:59 PM |
| seafoam | SilverGT04 | 99-04 | 11 | September 12th, 2007 01:48 PM |
| Seafoam | mustangmanic | 99-04 | 25 | July 17th, 2007 01:24 AM |
