2002,Mustang GT
Engine specs 2002 GT
I was wondering my engine specs by ford like how much compression what kind of block and so fourth. Does anyone know an email address I can find the infromation out on?
alright....here's the specs..:
4.6L Cast Iron V8 3.552(bore)x5.543(stroke) SOHC 2v/cyl 260hp@5200rpm 302lb-ft@4000rpm 9.4:1 compression anything else you need to know? |
good man stangaddiction, hit it right on the head
2002,Mustang GT
Just wondering about it thanks don't know about the cast iron block mine looks like its aluminum . Maybe I'm wrong .
if youve got a 02 gt its iron, its strong as hell too
2002,Mustang GT
How much hp can I get out of it stock? Without blowing up the motor.
and how much can you move the rpms up till they blow. Thinking about a cam install first to improve the breathing part. And with putting a new tb on one should you have a tune I know I probably want a tune after I but a cam into it Just want to try to get as many hp out of it right now N/A . The motor only has 41k on it . |
you're good until about 400 HP to the wheels anything more and i'd start beefin up the bottom end a bit.
11.47@120.58
I made 412 to the wheels for about 2 years. Rev limiter set to 6k and and I shifted off it quite regularly. NA you won't get past 300 rwhp without cams / heads or a poweradder. I know a guy that's got a cammed / ported head setup on the stock bottom end and has been running it hard to 6800 rpm's for at least a year. As the power comes up the revs have to go down until you've got forged rods / pistons.
your stock internals will hold up to 450hp i believe, but i wouldn't push it to that limit..
RLY SRS
400/400
You can get away with up to 420rwhp from what i have seen but 400/400 is safe and still fun... |
there's a guy that post on modulardepot that has run his at around 500 rwhp on the stock shortblock for 20,000+ miles, the tune is golden though
Threads Similar to: Engine specs 2002 GT
| V6 Engine Specs | turp | V6 Mustangs | 53 | February 24th, 2011 12:00 AM |
| 2002 GT VERT / 2003/04 MACH 1 Engine Swap | JBasco20 | Modular Mustangs | 5 | February 10th, 2011 11:23 PM |
| Stock engine specs | hubba076 | 99-04 | 2 | August 17th, 2007 06:36 PM |
| factory engine specs on 87 5.0? | marks87gt | 5.0 Mustangs | 2 | June 12th, 2007 08:00 AM |
| Will a 2002 Gt Engine Directly Replace a 2000GT engine? | Bigb2000GT | 99-04 | 7 | April 22nd, 2007 06:09 PM |
