Piston removal
LinkBack (1) Thread Tools
Old May 29th, 2009, 01:38 PM   1 links from elsewhere to this Post. Click to view. #1
elund126's Avatar
2003 Mustang GT vert
elund126 is on a distinguished road
Piston removal
03 GT convertible. My passenger side would lift up very slow, and now I see fluid all over the piston and it's actually leaking right down by my rear pass side tire.
I've searched forever trying to find directions on how to replace, no luck. Can anyone point me in the right direction or have any tips?
90 degrees today here in Seattle, which doesn't happen too often. Need that damn top to work.
2003 GT Convertible
K&N
Flowmaster 40 series
Little by little......
Old May 29th, 2009, 01:47 PM   #2
elund126's Avatar
ok, piston is the wrong word. Hydraulic cylinder is the official term. And, boy did I get heat for posting in the Tech forum. Geeze
2003 GT Convertible
K&N
Old May 29th, 2009, 02:27 PM   #3
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Take out the back seats. It should be behind there right in front of you then.
Old May 29th, 2009, 02:27 PM   #4
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
It's in the center, right behind where the seats would be.
Old May 31st, 2009, 07:11 PM   #5
elund126's Avatar
Got it fixed. It wasn't too hard. Just some basic hand tools, a lot of rags, and your wife's tupperware and turkey baster.
Here's what I did....
1. Remove back seat cushion and back rest. Cushion is easy, there are some push button releases. Seat back requires socket (sorry, didn't write down what size)
2. Removed plastic panel that covers the rear speakers. Just need to pull the plastic push pins. (I think there are 4).
3. Unscrew speaker box. 3 screws. Unplug both speakers.
4. Hydraulic cylinder is now right in front of you. It is held on by one bolt near the middle of the cylinder, and there is another bolt holding the top of the rod. (Need a big star drive bit).
5. Removed both hydraulic lines, this is where the rags and tupperware come in handy.
6. Went to Ford, bought new cylinder ($150 freaking dollars).
7. Installed cylinder.
8. Used turkey baster to add Dexron III ATF fluid into the reservoir.
9. Enjoying my top down once again.
By the way, make sure you periodically check your cylinders to see if the seals are leaking. I find that it's easiest to have the top half way open and you can see right down to the cylinders. The one that leaked looked like it had grease all over it. Mine leaked fluid and it soaked into the sound deadening material, and the bottom of my seat cushion. Made a huge mess.
I wish I would have taken pictures. It took me about an hour, tops, and I'm not a mechanic.
2003 GT Convertible
K&N
Old June 2nd, 2009, 09:29 AM   #6
The Doctor
Lefty's Avatar
'01 Cobra Vert.
iTrader: 11 reviews
Glad to see you got it figured out!
Old July 27th, 2009, 09:29 AM   #7
~C~
~C~, The Other White Meat!
~C~'s Avatar
Y2K YellowJacket GT
~TBD~
~C~ is just really nice~C~ is just really nice~C~ is just really nice~C~ is just really nice
Send a message via AIM to ~C~
nice. my top is working fine knock on wood, but i need to check them out regardless.
BLOWN Bumblebeast!
370 rwhp / 381 ft lbs
~Tuned by JJ at WMS
"Like the blind man says......We shall see...."
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/125180-piston-removal.html
Convertible top mechanics help - Ford Mustang Forums This thread Refback March 19th, 2010 10:05 AM
Threads Similar to: Piston removal
Piston problem JBIGBOOTSY 5.0 Mustangs 9 April 27th, 2008 02:54 PM
Piston Stop 68 dlxcoupe 96-98 6 March 26th, 2008 06:17 PM
2 piston calipers cj1220 99-04 4 March 16th, 2008 12:04 PM
Whats the best piston to have? powersrj 5.0 Mustangs 3 August 21st, 2007 10:50 PM
PISTON ? 89GTCONV 5.0 Mustangs 1 June 14th, 2006 10:44 PM
