Explain this to me
![]() Pretty.............................Slow Mods: Apparently more than 250 characters |
The Razor's Edge
Looks like bs. If it really worked it would cost more. 200 bucks and saves 30 to 90 percent....
Moderator
2003 Grand Cherokee
Just a standard HHO converter. I built one awhile back b/c I said they don't work and a couple of my buddies said they would work. Put it on my Cavalier and it didn't do anything except take up space. No suprise to me.
Haha thats what I was thinking but ppl that I've talked to said they've built it too and it did work. That was the only one I've seen marketed so I figured I'd ask when I had the chance
Authorized Vendor
![]() Join Date: Sep 2008
Well, you burn gasoline to drive the engine to drive the alternator to make electricity to power an electrolysis cell to make hydrogen to burn to drive the alternator to.... and round and round it goes...
And if that explanation makes your head hurt, it should! It's a bunch of nonsense. They had one of these on Dateline a while back in what may have been the only time anyone's ever given an HHO system an EPA-certified mileage test. The car got 1/2 mpg better with the system SWITCHED OFF - it was making things worse. Most of the "success stories" out there, I suspect, were when somebody added a couple "supporting mods" to their HHO generator, and the supporting mods were actually valid mods to improve mileage. |
#6 | |
Moderator
2003 Grand Cherokee
Imagine this. You have a diesel truck and when you step on the gas it blows black smoke. All this smoke is excess fuel that's not burned off. Before the normal injection cycle, one injects a little bit of diesel it starts to ignite. Then the normal injection cycle hits and it burns the fuel more completely. By adding a little bit of gas to each combustion, one will get more fuel efficiency. Why? B/c you have a more through and complete burn. Less wasted fuel. Jump to HHO converters. You're simplifying the argument WAY too much. Say the standard motor only burns 80% of the fuel in the combustion. The remaining 20% is exhausted and not used for power. Now, if you use a little electricity to make hydrogen and oxygen, inject it into the air/fuel mixture, it could cause 95% of the fuel to burn in combustion. This would mean more power per combustion and less fuel to do the same work. One isn't coming out ahead (not a perpetual motion machine). They are just making higher efficiency.
#7 | |||
Authorized Vendor
Fuel saving gadgets - a professional engineer's view |
#8 | |
Moderator
2003 Grand Cherokee
The diesel thing is true. There was a thing on TV about it. Use more fuel per combustion (at strategic times) and get better fuel efficiency. Seems counter intuitive but it's true.
Authorized Vendor
The thing is, if you could go from burning 98% of the fuel to 99.5%, that's not much more than a 1.5% improvement, and most of the HHO guys are insisting they can get anywhere from 50% to 150% improvement. Every time I've seen someone put one to a reasonably well designed and rigorous test, it failed completely.
There are ways a determined tuner can squeeze more MPG out of an engine, but I have seen no evidence to date that HHO systems are one of them, or any convincing explanation why they should be one of them. Even the name sounds implausible, like you've got some misshapen water molecule with one of the hydrogen atoms having jumped from the oxygen atom to the other hydrogen. |
Threads Similar to: Explain this to me
| how do i explain | gooberhead320 | The Clubhouse | 0 | June 10th, 2008 03:08 AM |
| Can someone explain????? | turismo374 | V6 Mustangs | 0 | May 12th, 2008 02:26 PM |
| Can someone explain this to me?? | Drtbkercr5 | The Clubhouse | 19 | May 5th, 2008 11:58 PM |
| Explain Something To Me | Mach Boy | 4V / SVT | 8 | March 19th, 2008 07:14 PM |
| Can't Even Explain It | Cricket | Videos | 1 | November 18th, 2006 10:29 AM |
