Octane booster vs race fuel
Old June 11th, 2009, 11:44 AM   #1
StarCity is on a distinguished road
Namely Torco mach accelarator. I was thinking of running this in addition to my methanol injection or possiblly by itself vs race fuel. If I'm running 110or torco I think it would be over kill to run the meth injection. Also with the torco or racefuel it will give me a little peace of mind over running meth inj on my racetune.
Old June 11th, 2009, 12:18 PM   #2
Trick Tuners's Avatar
KB'd GT
what is your combo? Typically its safer to run race gas and no meth. This is due to the issue with proper distribution of the meth, and the chance of burning a couple pistons while everything else looks great. The torco stuff works pretty well. How much octane do you need? What is your timing and boost?
Old June 11th, 2009, 04:03 PM   #3
Authorized Vendor
Matt Cramer's Avatar
Matt Cramer is on a distinguished road
Generally when octane booster claims it'll raise your octane by a point, they mean 0.1. A lot of the octane booster out there is rather overpriced for what it is. Some of it is just JP5 jet fuel, for example, sold for $5 for a tiny bottle.
One cheap octane booster we've used has been toluene, available at paint stores. A gallon of that retails for about as much as you'd buy two or three itty bitty bottles of most octane booster, and it's more effective than some of the octane boosters out there as well.
Old June 11th, 2009, 04:15 PM   #4
2.3l turbocoupe, single 60t turbo, 20 psi for now but plan to take it up to 30 with a 35-50 shot of n2o on a window switch spraying between 2000-4500 rpm. Timing is set at about 24* on 93 with 450 nozzle on a devils own stage two meth injection no nitrous.
I'm really not sure what oct to run in addition to the n2o. I would feel more comfortable running straight 110 but I've already bought the meth kit and got it hooked up.
The reason for the n20 is I have serious lag below3000rpm and is killing me. My turbo is way oversized. It is a frankenstein stage 2 turbo. Awesome top end though.
Old June 11th, 2009, 04:54 PM   #5
KB'd GT
Thats a pretty wild setup. I would run race gas and no meth. Have you tried retarding the timing a ton to shoot some heat into the turbo below 3000rpms? Many engines have been burned due to meth and its non homogeneous distribution (mainly due to flowing thru a manifold designed for air instead of fuel). It would be great if there was a port injection meth kit. Be careful out there!
Old June 11th, 2009, 08:27 PM   #6
Interesting... I will def give it a try when I put it on the dyno. I need to invest in a map sensor to get some boost readings.
Old June 12th, 2009, 01:26 PM   #7
KB'd GT
you should datalog boost on a turbo setup like that so you can watch for boost creep and spikes. Check out these gauges i sell that can line graph boost. This is egt, but boost works the same.
Old June 12th, 2009, 03:19 PM   #8
YouTube - PLX Graphing mode (EGT) from TrickTuners.com
What does that go for?Do you have a website?
Old June 12th, 2009, 05:26 PM   #9
KB'd GT
see here for more info on the plx gauges.
PLX Gauges explained - Trick Tuners Forums
Threads Similar to: Octane booster vs race fuel
race gas 110 octane 93lx306dev 5.0 Mustangs 15 October 14th, 2008 01:38 PM
octane booster tehdwarvenn 5.0 Mustangs 9 February 28th, 2008 10:13 PM
octane booster ford6693 99-04 47 February 3rd, 2008 10:03 PM
Octane booster mustangjeff1997 V6 Mustangs 16 January 6th, 2008 05:32 PM
NOS Fuel Octane Booster? fomocoro 2005 - 2010 21 December 12th, 2007 08:21 PM
