LinkBack (1) | Thread Tools |
#1
1998 Mustang V6
gas tank size
so im trying to calculate my fuel milage on my 98 V6 but i have no idea how big my tank is. how many gallons does it hold?
try edmunds.com they have all the specs for your car
Alternatively, you could check your driver's manual.
15.7 Gallons as per specs listed by autotrader.com.
Technical Specifications: 1998 Ford Mustang 2dr Cpe COUPE - AutoTrader.com Useful site to look up general car specs by the way.. Edmunds is also good but their site seems a little cluttered... I've found the most accurate way to calculate fuel mileage (which doesn't even require that you know the fuel capacity) is to simply top off your tank, drive in city/highway whichever you're checking, until you're about to 1/4 tank, then top it off again, use your trip meter to see how far you've gone and do the math based on how much fuel it takes to top it off again! You can do the same thing with an entire tank over a longer period of time, but neither requires that you know the fuel capacity.
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/128612-gas-tank-size.html
| Calculate Tank Size Gallon | Directhit.com | This thread | Refback | November 5th, 2010 02:57 PM | |
Threads Similar to: gas tank size
| Gas Tank Leaking?? How to Drop your Fuel Tank / Replace the Filler Neck Gasket | gills99stang | 99-04 | 68 | May 4th, 2013 04:24 PM |
| Gas Tank | Rattltrunk | 2005 - 2010 | 17 | March 24th, 2009 02:30 PM |
| Stock Gas Tank Size | TyCouey2000GT | 99-04 | 13 | June 3rd, 2008 03:24 PM |
| gas tank size | 6banger96 | V6 Mustangs | 2 | March 24th, 2008 12:30 AM |
| gas tank size? | jessy_is_rad | Classic Mustangs | 7 | August 30th, 2007 07:08 AM |
