01 gt, 03 v6
help with my 2003 v6, sounds like tickin when stepping on gas
Ok so I am the only owner since new of my 2003 v6 I traded it in on my gt an then 4 yrs later they still had it so bought it back but everytime I drive an start it up theirs a ticking, first it was the header gasket but that didn't fix it totally, I had a few exhaust leaks an got them taken care of an that didn't fix it. Could it be an engine knock w only 35k on my car?? I need help on wat to do. I tried seamfoaming to see if it would help an it made car ran better but def didn't help ticking. Sounds like valves tickin or something. Should I try an octane booster? I just run the lowest grade octane 89. Anyone please help thanks
ice, mine does the same thing sometimes, but only when its cold. Does it do it after you've driven for awhile?
lowest grade octane in bridgeville is 87 btw |
Priest of the Car Gods
Does it go away if you run premium? (I'm guessing no, and for the record, octane booster is a joke)
Have you checked the clearance on the valves?
octane booster raises the octane level of your gasoline 1 point, all for 8.95 to go from 93 to 94.
No, a "point" in octane-booster speak is 0.1 octane (i.e point 1), NOT 1.0. So it raises 93 to 93.1.
lol, i meant 10 points. At least thats how much 104 octane booster performs.
Still, $8.95 for 1 octane difference, when the difference in price between 2 different grades of fuel for a 15 gallon tank is $3.00 at most.
yeah, exactly.
Threads Similar to: help with my 2003 v6, sounds like tickin when stepping on gas
| Cops stepping things up... | goren813 | The Clubhouse | 4 | June 23rd, 2009 02:37 PM |
| Check engine light comes on when stepping on gas | MonsterSD | 5.0 Mustangs | 2 | June 15th, 2007 05:43 PM |
| Tickin Problems | fallen | V6 Mustangs | 2 | November 5th, 2006 10:18 AM |
| Ford Stepping Down as Automaker’s Chief Executive | 99mustang232 | The Clubhouse | 6 | September 6th, 2006 01:38 PM |
