408 stroker?
Old February 2nd, 2007, 11:35 AM   #1
94' Cobra 351's Avatar
94' Cobra 351 is on a distinguished road
408 stroker?
Couldn't find any previous posts about this. I am on the fence about either stroking my 351w to a 408, or supercharging it. I was concerned with stroking it because I heard the driveability of the car goes down. I also wasn't sure what sort power gains I would see from stroking it. I am really trying to find someone who has a 408 stroker. Any advice at all would be great.
Old February 2nd, 2007, 01:23 PM   #2
03 R Code's Avatar
unstoppable @ speed of light
03 R Code will become famous soon enough
Do both.
Old February 2nd, 2007, 02:05 PM   #3
RIP Justincredible! God Speed
Justincredible's Avatar
Justincredible is on a distinguished road
Re: 408 stroker?
Driveability will not suffer with the 408 if you dont get greedy on the cam selection and have it tuned by a good tuner. (provided you keep the EFI).
With that said...the cost of the supporting hardware will add up quickly to acompany the 408 at a power level comprable to a blown 351.
A supercharger and your existing 351 will yeild more hp for the money spent untill you get into the 600+ hp range.
9.91@ 134mph 1/4 - 6.17@ 109mph 1/8th - 1.33 60' - Stock ECU & Stock Suspension......and getting faster .
BIVENS RACE CARS FTMFW!!!
Old February 2nd, 2007, 09:14 PM   #4
what do you mean by supporting software for a 408?
Old February 2nd, 2007, 09:37 PM   #5
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
Driveability does't suffer from cubic inches. A 408 will drive just fine.
Old February 3rd, 2007, 02:03 AM   #6
well i had heard the the extended stroke of the piston causes more friction and wears the block faster, and that it also doesn't rev as high with a longer stroke. any idea what kind of power gain i should see from a 408 stroker?
Old February 3rd, 2007, 07:23 AM   #7
sleepinggt is on a distinguished road
351 produces more than enough for everyday fun...if it's for racing the best thing is to get a properly tuned wet kit...weigh's alot less than a s/c or turbo set up
Old February 3rd, 2007, 09:47 AM   #8
its not a daily driver, it is going to be my weekend summer car, and i don't want any imports around town showing me up. and i don't want to go the nitrous route, not a big fan.
Old February 3rd, 2007, 10:08 AM   #9
[quote="94' Cobra 351"]what do you mean by supporting software for a 408?[/quote
I didnt say software...I said hardware. By hardware I refering to the bigger heads, cam, and intake etc. that would be needed to acompany the 408 to let it make the same power as your current 351 with just a blower bolted onto it.
Dont get me wrong...Im all about bigger cubes...but to answer your question...the blower will offer you the best hp per dollar ratio on a pump gas engine.
Old February 3rd, 2007, 10:13 AM   #10
i have GT40 heads, and a 292-292 512 max cam, you don't think they will support the 408? and i know if i go with a blower i have to lower the compression, what are different ways to go about doing that?
Old February 3rd, 2007, 12:24 PM   #11
1slo5.0's Avatar
1990 Mustang LX
9.36@143 mph
No the block doesn't wear faster and the stroke has nothing to do with the engine reving. As long as the heads can keep up and has the proper cam, the engine will have no problem making power at high rpm. I have a 4.100 stroke and spin over 8000 rpm.
Threads Similar to: 408 stroker?
Stroker Kit 101 scxc15 V6 Mustangs 5 November 4th, 2007 12:46 PM
To Stroker or Not to Stroker? That is the Question! 87StangLX General Tech 13 October 20th, 2007 10:46 AM
347 stroker mustang_s 96-98 2 August 7th, 2007 10:57 AM
347 stroker 2007calispecial 5.0 Mustangs 8 July 31st, 2007 07:55 PM
331 stroker ballzout 5.0 Mustangs 8 July 20th, 2007 04:59 PM
