Can Someone Explain How This Works?
Old July 20th, 2009, 08:57 PM   #1
Is the game, Ross is the name.
6DXR's Avatar
1998 M3,2K8 Ninja 250
Faster Than Fapsmith's Asian Girl
6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all6DXR is a name known to all
Send a message via AIM to 6DXR
I figure if it worked at all, the only thing it would do is speed up the rate at which the exhaust exited. I am sure I am wrong here, but how much would that even benefit the car.
I am sure I am wrong, so please enlighten me
I drive a 1998 BMW M3. I used to drive the sexiest Mach 1 in existence. But now I am a 3uroslut
Old July 20th, 2009, 09:02 PM   #2
MMs Ford Racing Nut Swinger
1FUN4RD's Avatar
2007 MUSTANG GT
1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold1FUN4RD is a splendid one to behold
That's pretty sweet twin turbo setup
heck of a place to hide them.
www.1fun4rd.blogspot.com
Old July 20th, 2009, 11:44 PM   #3
Flynnster's Avatar
2007 Mustang GT
14.70@97.24
Flynnster will become famous soon enough
It takes the exhaust from one chamber in the muffler to spin the turbo, and puts it back in the other chamber. Just like putting a turbo off the manifold except less efficient I would assume and I bet the tubing will be a bitch to work.
Black on Black 5spd '07 GT
FRPP Stingers
Originally Posted by king_Ahmet View Post
] but, if it tickles your sack in a funny way, have at it...
Old July 21st, 2009, 12:23 AM   #4
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
I would like to see how well he hid the charge pipe.
TT Build in progress.......
Old July 21st, 2009, 12:30 AM   #5
BlackedOut04GT's Avatar
14.21@97.93 2.107 60' (Best pass. So far.)
BlackedOut04GT has a spectacular aura aboutBlackedOut04GT has a spectacular aura about
Send a message via AIM to BlackedOut04GT
There was a Z06 vette that was next to me with a setup like that. His was under the car (STS Sytem i think). He said he didn't get that bad of turbo lag from them.
Black Stang Crew #007
Car Built By Me and CraigsList.com
Mods: MGW, Bassani Catted X, Flowmaster's, Accufab 70MM TB, Stack Racing Plenum + spacer, JLT CAI, Diablo Tune, Slotted rotors + ceramic pads.
More to come! I hope.
Old July 21st, 2009, 12:37 AM   #6
Billy Weston
C MY 4D's Avatar
2003 Cobra
11.14@124.36
iTrader: 8 reviews
Well look at it from a different point of view. Yes it isn't going to work as well as a regular turbo kit but it is going to make one hell of a sleeper if he hides the rest of it well.
Old July 21st, 2009, 01:15 AM   #7
6DXR's Avatar
Err.. I know I am retarded here, but I am learning.
Isn't the point of a turbo to allow more fuel to be burned by adding more air into the mixture?
So if the turbo is after the fuel has been burned, what is it accomplishing?
Old July 21st, 2009, 01:24 AM   #8
Imran's Avatar
01
Imran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud ofImran has much to be proud of
the exhaust is not being re-routed into the turbo. The exhaust is spinning one thing that spins the turbine that compresses the air.
Old July 21st, 2009, 01:27 AM   #9
I don't think that setup is legel because it's now inside the car, that and it looks like it will not work too well and have more weight from all the piping. If it does work it would be a sick setup.
Old July 21st, 2009, 01:34 AM   #10
6DXR's Avatar
And that compressed air is being re routed to then engine?
Old July 21st, 2009, 01:38 AM   #11
yea. Turbo is spins up from exhaust pressure, Turbo forces air into intake at a set psi. more psi=more air=more RWHP.
Old July 21st, 2009, 01:39 AM   #12
this should help.
Old July 21st, 2009, 01:40 AM   #13
6DXR's Avatar
Well that seems like there would be a shit ton of lag, if it has to be routed back up. Why not jus tmount them in the engine bay.
Old July 21st, 2009, 01:41 AM   #14
MM's Database Error
WLJohnson05's Avatar
2004 Mustang V6
322.8 rwhp
WLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud ofWLJohnson05 has much to be proud of
iTrader: 9 reviews
the more air you can fit in the cylinder the more power you can make, but with air your fuel system has to be able to provide enough full...hence boost....boost forces more into the cylinders providing for more power
yea the exhaust runs through the hot side of the turbo and the hotter the exhaust the more pressure it makes which in turns make the turbine spin faster which then sucks air thru the filter and forces it through the rest of the system into the motor.
SCT Mass Air Flow Sensor $200
Old July 21st, 2009, 01:42 AM   #15
Saves room, and hids it as well. Some people just don't want people to see what they have.
Old July 21st, 2009, 01:42 AM   #16
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
yes it would lag some but if he wrapped all the pipes and what not to keep that heat in they would prolly still spin up pretty quick
Old July 21st, 2009, 01:44 AM   #17
MM's Database Error
2004 Mustang V6
322.8 rwhp
iTrader: 9 reviews
my only thing about that is that its in the car which means its gonna be hot in there and seeing as the wastegate vents in there its gonna be really loud too. i still dont understand how he is routing the cold side.
i'd be interested in seeing how he fixed up the mufflers to work right for this
Old July 21st, 2009, 01:45 AM   #18
6DXR's Avatar
Hrmm.. Well thats pretty cool!
Reps to those who helped
Old July 21st, 2009, 01:46 AM   #19
Woot! yea reps!
Old July 21st, 2009, 01:48 AM   #20
Genibus Nitito Canus
HBK_2007's Avatar
2009 Ford Mustang GT
HBK_2007 will become famous soon enough
Send a message via MSN to HBK_2007
that is similar to the STS kits but STS totally replaces the mufflers with turbos.
think of a turbo as a vortech/procharger that is driven by the exhaust gases instead of a belt off the crank shaft
Red 1996 GT: JLT RAI, Steeda Underdrive pullies, Stewart Waterpump; nothing to brag about
Black 2009 45th aniverary edition GT 5 speed: K&N CAI, BBK Twin 62mm Throttle Body, BBK Underdrive Pullies, SLP Loudmouth
Threads Similar to: Can Someone Explain How This Works?
please explain Jucostud 2005 - 2010 26 July 23rd, 2008 03:26 PM
Can someone explain????? turismo374 V6 Mustangs 0 May 12th, 2008 01:26 PM
Somebody Please Explain Youngin V6 Mustangs 22 August 12th, 2007 01:20 PM
Explain This........ acmillr Forum Games 27 June 15th, 2007 10:17 PM
Could someone explain O/D to me? Compy386 General Tech 8 February 25th, 2007 07:24 AM
