Kenne Bell Questions
LinkBack (1) Thread Tools
Old August 13th, 2009, 01:05 PM   1 links from elsewhere to this Post. Click to view. #1
Techniq's Avatar
2004 Mustang Mach 1
Will Run After Build!
Techniq is on a distinguished road
Send a message via AIM to Techniq
Ok, just got off the phone with a rep from Kenne Bell. I'm still not happy with the answers I was given. Not so much the answer but how it was given. Hope you guys can help.
:::What I'm working with:
2004 Mach1- Iron Block - Forged Internals- It's a 4.6L Stroker
BBK 65mm Throttle Body
SCT Livewire Tuner.
::::What I'm Looking for:
450rwhp (With room to expand 600rwhp)
::::What I'm looking at:
(A) TS1000-MACH-INT KIT 140 (6799.00) 9 PSI KIT W/AC (MACH 1) INTERCOOLED INCLUDES BOOST-A-PUMP, CHIP, 42LB INJECTORS, COOL AIR KIT, 90MM METER, 2.1L
(B) TB1000-MACH+ KIT 140 (6399.00) 16-20 PSI KIT W/AC (MACH 1) INTERCOOLED INCLUDES BOOST-A-PUMP, 2.1L
(Recommend '03 Cobra style rods & pistons. 8 rib system required for 650-700+HP. Use 60lb injectors and Big Oval Throttle Body)
:::Questions:
1.)Will My TB Work?
2.)I don't need Chip with SCT Tuner, Correct?(As long as I get dyno tune duh!)
3.) How many "core" is Intercooler?
4.) In addition to TB, Injectors, and Chip/Tune, anything else required for kit (B)
I think thats all. Thanks for Info/Input.
5.0L Cast Iron block/Forged internals-Melling Oil Pump w/Billet Gears-BBK Twin 65mm Throttle Body-BBK Longtube Headers-BBK O/R "x" Pipe- Maganflow Cats-B&M Sport Short Throw-Eibach Drag-Launch Springs-And Some More...Hope to run new set-up soon.
Old August 13th, 2009, 01:19 PM   #2
Trick Tuners's Avatar
KB'd GT
If you want room to expand to 600hp you will need a bunch of other stuff. You will be better off buying a tuner kit and getting all the other stuff someplace else.
The 42s will not cut it.
The BAP is a 20A and will not work with dual pumps (like you will need along with a 40A bap). The maf will peg. You don't need the chip if you have a LW and are getting a dyno tune. I'd go with a 2.6H or the 2.8H mammoth.
Old August 13th, 2009, 01:34 PM   #3
Techniq's Avatar
2004 Mustang Mach 1
The Injectors I'm looking at are 60lbs.
"Reloaded" Showed me these:
Siemens Deka 63lb/hr USCAR Injectors (Set of 8) (Flow Matched) [LU107FM-8] - $399.00 : Performance Parts - Ford Mustang - Cobra - Dodge Viper - Chevy Corvette - C6 - LS1
Then I found these:
Ford and Mustang Performance Parts, Accessories and Service : 60lb Fuel Injectors Sieman Deka
As for the 2.6 and 2.8 Mammoth. Didn't even know it was a possibility.
Old August 16th, 2009, 12:14 PM   #4
Techniq's Avatar
2004 Mustang Mach 1
::: BUMP :::
Old January 10th, 2010, 08:16 PM   #5
cyberdude47's Avatar
cyberdude47 is on a distinguished road
I keep hearing about there lack of good customer service,
Cervini Stalker kit, Foose 18" Nitrous 265/295
Manley rods & pistons, Kellogg crank, ATI 10%OD, Fidenza flywheel, Spec3 clutch.
Kenne Bell 2.2L,8rib conversion.
Headers, Xpipe, Magnaflows
JLT, SCT
Eibach, H&R, Tokico, Maximum motorsports
LinkBack to this Thread: http://www.moddedmustangs.com/forums/general-tech/133587-kenne-bell-questions.html
Different take on an air intake - Tacoma World Forums This thread Refback June 9th, 2010 12:54 PM
Threads Similar to: Kenne Bell Questions
Kenne Bell 2.6H vs 2.8H 05mustang_TT_charged 2005 - 2010 25 June 7th, 2008 10:01 AM
2003 GT with KENNE BELL questions.. skidze 99-04 14 December 16th, 2007 03:37 PM
Questions About Engine Swapping and Kenne Bell OcOnnor220 99-04 7 September 8th, 2007 03:42 PM
